查看: 5909|回复: 3
红外报警门铃,求助啊?看看有没有问题
ID:38473 发表于 2012-4-14 21:08 | 显示全部楼层 |阅读模式
#include #define uchar unsigned char #define uint unsigned int sbit kz=P0^1; //控制 sbit red=P2^7; sbit greed=P2^4; //绿灯 sbit ml=P2^0; //门铃 sbit bj=P2^1; //报警 sbit hw=P0^0; //红外 uchar num; uchar code table[]={0xc1,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e}; void delayms(uint); void baojin() { red=1; num++; bj=1; greed=0; ml=0; } void menling() { greed=1; ml=1; red=0; bj=0; } void shuma() { P1=table[num]; delayms(500); } void delayms(uint xms) { uint i,j; for(i=xms;i>0;i--) for(j=110;j>0;j--); } void main() { P1=0x00; P2=0x00; delayms(60000); while(1) { P2=0x00; if(hw==1) { if(kz==0) menling(); if(kz==1) baojin(); shuma(); } if(hw==0) P2=0x00; delayms(1000); } }[upload=c,毕业设计.c]viewFile.asp?ID=1041[/upload]
[此贴子已经被作者于2012-4-15 0:06:24编辑过]
ID:447828 发表于 2020-5-4 21:15 | 显示全部楼层
能不能找到你啊
ID:363812 发表于 2020-5-13 12:14 | 显示全部楼层
这咋看?
ID:1019324 发表于 2023-5-29 09:16 | 显示全部楼层
放源程序,这样看不了
