查看: 5833|回复: 1
[项目分享]Arduino切线机剪线机设计与制作 附程序
制作出来的剪线机实物图如下:
设置好所需长度和数量的线材后,自动完成切割。
硬件材料
1*Arduino UNO
1*电机驱动器
1*23步进电机
1*12v转5v稳压模块
1*支架、螺钉、垫片等
2*轮胎
灵感来源
人工线轴上拉出几千根长20cm的22awg电线并不是一件有趣的事。它很无聊,而且很容易出现不准确。需要2个人花上2天才能手动拉完706个22awg电线。如果你只有一个线轴(一次拉1个线),则需要更长的时间。使用Arduino切线机,你需输入所需的长度和数量,即可预先输入所需的长度和数量,就可以自动完成。
剪线机的Arduino源程序:
  1. #include <math.h>               //#math
  2. #include <Servo.h> //From Library
  3. Servo servoMain; // Define Servo
  4. #include <SoftwareSerial.h> // soft serial for LCD
  5. #define stp 2 //define stepper
  6. #define dir 3 //define stepper
  7. #define MS1 4 //define stepper
  8. #define MS2 5 //define stepper
  9. #define MS3 6 //define stepper
  10. #define EN  7 //define stepper
  11. float a;              //variable assignment qty
  12. float b;              //variable assignment inches
  13. float c;              //variable assignment required motor steps
  14. float W;              //removed from functions for now, might need later.
  15. char junk = ' ';      //any random character input.
  16. char val;             // Data received from the serial port
  17. char user_input;
  18. int x;                //Probably over loaded on assignments, not sure. Remove later and test.
  19. int y;
  20. int state;
  21. SoftwareSerial mySerial(0, 11); // pin 11 = TX
  22. void setup()          // set up
  23. {
  24.   pinMode(15, OUTPUT); // set the pin to input
  25.   servoMain.attach(9); // servo on digital pin 9
  26.   pinMode(13, OUTPUT); // led on pin 13
  27.   pinMode(stp, OUTPUT); //B.E.D
  28.   pinMode(dir, OUTPUT); //B.E.D
  29.   pinMode(MS1, OUTPUT); //B.E.D
  30.   pinMode(MS2, OUTPUT); //B.E.D
  31.   pinMode(MS3, OUTPUT); //B.E.D
  32.   pinMode(EN, OUTPUT); //B.E.D
  33.   resetBEDPins(); //Set step, direction, microstep and enable pins to default states
  34.   Serial.begin(9600);   // set up Serial library at 9600 bps
  35.   mySerial.begin(9600); // set up serial port for 9600 baud
  36.   Serial.println("Lets Cut Some Wires!"); //welcome message in serial window
  37.   Serial.println("");
  38.   Serial.flush(); //clear the input que.
  39. }
  40. void loop()
  41. {
  42.   {
  43.   mySerial.write("                "); // clear display
  44.   mySerial.write("                ");
  45.   mySerial.write(254); // move cursor to beginning of first line
  46.   mySerial.write(128);
  47.   mySerial.write("Solution Systems  Feed n Cut!");
  48.   delay(2);
  49.   }
  50.   Serial.println("Enter Quantity, Press ENTER");        // user Input request qty
  51.   while (Serial.available() == 0) ;                     // Wait here until input buffer has a character
  52.   {
  53.
  54.     a = Serial.parseFloat();                           // new command in 1.0 forward
  55.     Serial.print("a = "); Serial.println(a, DEC);
  56.     while (Serial.available() > 0)                      // .parseFloat() can leave non-numeric characters
  57.     { junk = Serial.read() ; }                          // clear the keyboard buffer
  58.   }
  59.   Serial.println("Enter Length in Inches, Press ENTER");
  60.   while (Serial.available() == 0) ;
  61.   {
  62.
  63.     b = Serial.parseFloat();
  64.     Serial.print("b = "); Serial.println(b, DEC);
  65.     while (Serial.available() > 0)
  66.     { junk = Serial.read() ; }                          // clear the keyboard buffer
  67.     c = (float( b*26 ));
  68.     Serial.print("Motor Steps = ");
  69.     Serial.println(c, DEC); Serial.println();
  70.     }
  71.
  72.   Serial.println("Ready to Begin? Press ENTER");        // user Input request Y or N?
  73.   digitalWrite(EN, LOW);                                //Pull enable pin low to set FETs active and allow motor control
  74.   while (Serial.available() == 0);                      // If data is available to read,
  75.    {
  76.      val = Serial.read();                               // read it and store it in val
  77.      if (val == 'y')
  78.      {
  79.       Serial.println("Here We Go!");
  80.       delay(10);
  81.       for (a; a>0; a--){      // this step checks if the quantity entered (a) is greater than 0,...  and deducts 1 from a.
  82.         Feedft();             // if it is it repeats the step feed and cut function again.
  83.       }
  84.      }
  85.      else {
  86.      Serial.println("Restarting Setup...");             // otherwise restart
  87.      }
  88.    delay(10);                                           // Wait 10 milliseconds for next reading
  89.   }
  90.   { junk = Serial.read() ; }                           // clear the keyboard buffer
  91.
  92. }
  93.
  94. //Reset Big Easy Driver pins to default states
  95. void resetBEDPins(){
  96.   digitalWrite(stp, LOW);
  97.   digitalWrite(dir, LOW);
  98.   digitalWrite(MS1, LOW);  // leaving wired and in sketch for now, not using micro-step control at this time.
  99.   digitalWrite(MS2, LOW);
  100.   digitalWrite(MS3, LOW);
  101.   digitalWrite(EN, HIGH);
  102. }
  103. //Functions
  104. void Feedft(){
  105.   Serial.println("Feeding Wire at default step mode.");
  106.   digitalWrite(dir, LOW);                   //Pull direction pin low to move "forward"
  107.   for(x= 1; x<c; x++){                      //Loop the forward stepping enough times for motion to be visible
  108.     digitalWrite(stp,HIGH);                 //Trigger one step forward
  109.     delay(1);
  110.     digitalWrite(stp,LOW);                  //Pull step pin low so it can be triggered again
  111.     delay(1);
  112.   }                                         //Need to add a stepper done moving function here!!!!!!!!!!!!!<==================
  113.    ServoMainCut();                          //Run the Cut Function
  114.    delay(2000);
  115.    Serial.println("Cutting Wire!");         //Fair Warning.....
  116.   // RepeatCount();                           //Run the repeat function
  117.   { junk = Serial.read();}                  //Clear the keyboard buffer
  118. }
  119. //funtion Servo Cut
  120. void ServoMainCut(){
  121.    digitalWrite(13, HIGH);
  122.    delay(100);
  123.    digitalWrite(13, LOW);
  124.    servoMain.write(177); // CUT!! Turn Servo Left to 176 degrees
  125.    delay(750);          // Wait 1.5 second
  126.    servoMain.write(65); // Open Cutter Turn Servo Left to 65 degrees
  127.    digitalWrite(13, HIGH);
  128.    delay(100);
  129.    digitalWrite(13, LOW);
  130. }
参与人数 2黑币 +62 收起 理由
luliang02003 + 12
收藏收藏4 分享淘帖 顶顶 踩踩
ID:146204 发表于 2020-6-3 10:01 | 只看该作者
不错值得学习,实实在在做点东西出来
