查看: 6933|回复: 1
单片机+DAC0832波形显示器Proteus仿真程序
单片机控制DAC0832产生正弦波、方波、三角波、梯形波和锯齿波。单片机的P1.0~ P1.4脚接有5个按键,当键按下时,分别对应产生正弦波、方波、三角波、梯形波和锯齿波。
DAC0832
  1. #include<reg51.h>
  2. sbit wr=P3^6;
  3. sbit rd=P3^2;
  4. sbit key0=P1^0;
  5. sbit key1=P1^1;
  6. sbit key2=P1^2;
  7. sbit key3=P1^3;
  8. sbit key4=P1^4;
  9. unsigned char flag;
  10. unsigned char const code
  11. SIN_code[256]={0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,
  12. 0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,0xd8,0xda,0xdc,0xde,
  13. 0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf4,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,
  14. 0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfd,
  15. 0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,
  16. 0xe3,0xe1,0xde,0xdc,0xda,0xd8,0xd6,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,0xbc,0xb9,0xb6,
  17. 0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x92,0x8f,0x8c,0x89,0x86,0x83,0x80,0x7d,
  18. 0x79,0x76,0x73,0x70,0x6d,0x6a,0x67,0x64,0x61,0x5e,0x5b,0x58,0x55,0x52,0x4f,0x4c,0x49,0x46,0x43,
  19. 0x41,0x3e,0x3b,0x39,0x36,0x33,0x31,0x2e,0x2c,0x2a,0x27,0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,0x17,
  20. 0x15,0x14,0x12,0x10,0xf,0xd,0xc,0xb,0x9,0x8,0x7,0x6,0x5,0x4,0x3,0x3,0x2,0x1,0x1,0x0,0x0,0x0,0x0,
  21. 0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0x1,0x2,0x3,0x3,0x4,0x5,0x6,0x7,0x8,0x9,0xa,0xc,0xd,0xe,0x10,0x12,
  22. 0x13,0x15,0x17,0x18,0x1a,0x1c,0x1e,0x20,0x23,0x25,0x27,0x29,0x2c,0x2e,0x30,0x33,0x35,0x38,0x3b,
  23. 0x3d,0x40,0x43,0x46,0x48,0x4b,0x4e,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x73,
  24. 0x76,0x79,0x7c};
  25. unsigned char keyscan()
  26. {
  27.     unsigned char keyscan_num,temp;
  28.         P1=0xff;
  29.         temp=P1;
  30.         if(~(temp&0xff))
  31.         {
  32.                  if(key0==0)
  33.              {
  34.                  keyscan_num=1;
  35.              }
  36.              else if(key1==0)
  37.              {
  38.                  keyscan_num=2;
  39.              }
  40.              else if(key2==0)
  41.              {
  42.                  keyscan_num=3;
  43.              }
  44.              else if(key3==0)
  45.              {
  46.                  keyscan_num=4;
  47.              }
  48.              else if(key4==0)
  49.              {
  50.                  keyscan_num=5;
  51.              }
  52.              else
  53.              {
  54.                  keyscan_num=0;
  55.              }
  56.             return keyscan_num;
  57.         }
  58. }
  59. void init_DA0832()
  60. {
  61.       rd=0;
  62.           wr=0;
  63. }
  64. void SIN()
  65. {
  66.      unsigned int i;
  67.          do{
  68.               P2=SIN_code[i];
  69.                   i=i+1;
  70.            }while(i<256);
  71. }
  72. void Square()
  73. {
  74.       EA=1;
  75.           ET0=1;
  76.           TMOD=1;
  77.           TH0=0xff;
  78.           TL0=0x83;
  79.           TR0=1;
  80. }
  81. void Triangle()
  82. {
  83.       P2=0x00;
  84.           do{
  85.                     P2=P2+1;
  86.             }while(P2<0xff);
  87.                 P2=0xff;
  88.           do{
  89.                     P2=P2-1;
  90.             }while(P2>0x00);
  91.                 P2=0x00;
  92. }
  93. void Sawtooth()
  94. {
  95.       P2=0x00;
  96.           do{
  97.                     P2=P2+1;
  98.             }while(P2<0xff);
  99. }
  100. void Trapezoidal()
  101. {
  102.      unsigned char i;
  103.          P2=0x00;
  104.          do{
  105.                   P2=P2+1;
  106.          }while(P2<0xff);
  107.          P2=0xff;
  108.          for(i=255;i>0;i--)
  109.          {
  110.              P2=0xff;
  111.          }
  112.      do{
  113.                   P2=P2-1;
  114.          }while(P2>0x00);
  115.          P2=0X00;
  116. }
  117. void main()
  118. {
  119. init_DA0832();
  120. do
  121. {
  122.       flag=keyscan();
  123. }while(!flag);
  124.    while(1)
  125.   {
  126.       switch(flag)
  127.           {
  128.           case 1:
  129.           do{
  130.                   flag=keyscan();
  131.                   SIN();
  132.               }while(flag==1);
  133.                 break;
  134.           case 2:
  135.                           Square();
  136.           do{
  137.                   flag=keyscan();
  138.               }while(flag==2);
  139.                       TR0=0;
  140.                 break;
  141.           case 3:
  142.           do{
  143.                   flag=keyscan();
  144.                   Triangle();
  145.               }while(flag==3);
  146.                 break;
  147.           case 4:
  148.           do{
  149.                   flag=keyscan();
  150.                   Trapezoidal();
  151.               }while(flag==4);
  152.                 break;
  153.           case 5:
  154.           do{
  155.                   flag=keyscan();
  156.                   Sawtooth();
  157.               }while(flag==5);
  158.                 break;
  159.                 default:
  160.                    flag=keyscan();
  161.                    break;
  162.           }
  163.   }
  164. }
  165. void timer0(void) interrupt 1
  166. {
  167.   P2=~P2;
  168.   TH0=0xff;
  169.   TL0=0x83;
  170.   TR0=1;
  171. }
波形发生器.zip (68.64 KB, 下载次数: 171)
收藏收藏2 分享淘帖 顶顶2 踩踩
ID:840552 发表于 2020-11-8 14:55 | 只看该作者
请问一下你的那个运放使用的啥运放,求告知
