查看: 3619|回复: 0
HC32L136开发板的OLED驱动及应用
ID:776997 发表于 2020-10-6 12:36 | 显示全部楼层 |阅读模式
HC32L136开发板上配有一个笔段式的液晶屏,但无奈的是厂家却没提供一个能直接调用的显示函数。
在没解决该显示屏的显示函数前,先以轻车熟路的OLED屏来实现显示的问题。
由于手头的OLED屏是一款I2C接口的单色显示屏,故另其与MCU的连接关系为:
PA11SCL
PA12SDA
使这2个引脚输出高低电平的语句定义为:
#define OLED_SCLK_Set()   Gpio_SetIO(GpioPortA, GpioPin11)
#define OLED_SCLK_Clr()   Gpio_ClrIO(GpioPortA, GpioPin11);
#define OLED_SDIN_Set()   Gpio_SetIO(GpioPortA, GpioPin12)
#define OLED_SDIN_Clr()   Gpio_ClrIO(GpioPortA, GpioPin12);
分配2个引脚为输出功能的函数为:
  1. void App_OledInit(void)
  2. {
  3. stc_gpio_cfg_t stcGpioCfg;
  4. ///< 打开GPIO外设时钟门控
  5. Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio, TRUE);
  6. ///< 端口方向配置->输出(其它参数与以上(输入)配置参数一致)
  7. stcGpioCfg.enDir = GpioDirOut;
  8. ///< 端口上下拉配置->下拉
  9. stcGpioCfg.enPu = GpioPuDisable;
  10. stcGpioCfg.enPd = GpioPdEnable;
  11. ///< GPIO IO OLED端口初始化
  12. Gpio_Init(GpioPortA, GpioPin11, &stcGpioCfg);
  13. Gpio_Init(GpioPortA, GpioPin12, &stcGpioCfg);
  14. }
实现图1显示效果的主程序为:
  1. int32_t main(void)
  2. {
  3. stc_rtc_time_t readtime;
  4. Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE);  //GPIO外设时钟打开
  5. Sysctrl_SetPeripheralGate(SysctrlPeripheralRtc,TRUE);    //RTC模块时钟打开
  6. Sysctrl_ClkSourceEnable(SysctrlClkRCL, TRUE);
  7. RTC_Cfg();                                        //配置RTC
  8. EnableNvic(RTC_IRQn, IrqLevel3, TRUE);                //使能RTC中断向量
  9. Rtc_Cmd(TRUE);                                   //使能RTC开始计数
  10. App_OledInit();
  11. OLED_Init();
  12. OLED_Clear();
  13. OLED_ShowString(0,0,"HC32L136 TEST",16);
  14. OLED_ShowString(0,2,"OLED DISPLAY",16);
  15. while (1);
  16. }
1  OLED屏显示效果
实现RTC时间设置的函数为:
  1. void RTC_Cfg(void)
  2. {
  3. stc_rtc_initstruct_t RtcInitStruct;
  4. RtcInitStruct.rtcAmpm = RtcPm;        //12小时制
  5. RtcInitStruct.rtcClksrc = RtcClkRcl;       //内部低速时钟
  6. RtcInitStruct.rtcPrdsel.rtcPrdsel = RtcPrds;  //周期中断类型PRDS
  7. RtcInitStruct.rtcPrdsel.rtcPrds = Rtc1S;      //周期中断事件间隔
  8. RtcInitStruct.rtcTime.u8Second = 0x55;
  9. RtcInitStruct.rtcTime.u8Minute = 0x55;
  10. RtcInitStruct.rtcTime.u8Hour   = 0x10;
  11. RtcInitStruct.rtcTime.u8Day    = 0x06;
  12. RtcInitStruct.rtcTime.u8DayOfWeek = 0x04;
  13. RtcInitStruct.rtcTime.u8Month  = 0x10;
  14. RtcInitStruct.rtcTime.u8Year   = 0x20;
  15. RtcInitStruct.rtcCompen = RtcCompenEnable;
  16. RtcInitStruct.rtcCompValue = 0;//补偿值根据实际情况进行补偿
  17. Rtc_Init(&RtcInitStruct);
  18. Rtc_AlmIeCmd(TRUE);                  //使能闹钟中断
  19. }
实现图3  RTC计时效果的主程序为:
  2. {
  10. App_OledInit();
  11. OLED_Init();
  12. OLED_Clear();
  14. OLED_ShowString(0,2,"OLED  &  RTC",16);
  15. delay1ms(2000);
  16. OLED_Clear();
  17. OLED_ShowString(0,0,"20  -  -",16);
  18. OLED_ShowString(0,2,"    :  :",16);
  19. while (1)
  20. {
  21. if(flag == 1)
  22. {
  23. flag = 0;
  24. Rtc_ReadDateTime(&readtime);
  25. second = readtime.u8Second;
  26. minute = readtime.u8Minute;
  27. hour   = readtime.u8Hour;
  28. day    = readtime.u8Day;
  29. week   = readtime.u8DayOfWeek;
  30. month  = readtime.u8Month;
  31. year   = readtime.u8Year;
  32. OLED_ShowNum(16,0,year/16*10+year%16,2,16);
  33. OLED_ShowNum(40,0,month/16*10+month%16,2,16);
  34. OLED_ShowNum(64,0,day/16*10+day%16,2,16);
  35. OLED_ShowNum(16,2,hour/16*10+hour%16,2,16);
  36. OLED_ShowNum(40,2,minute/16*10+minute%16,2,16);
  37. OLED_ShowNum(64,2,second/16*10+second%16,2,16);
  38. }
  39. }
  40. }
2  RTC起始界面
3  RTC计时效果
