查看: 1722|回复: 2
新手求助?*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS
ID:978933 发表于 2021-11-14 19:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. sbit RS=P2^0;
  4. sbit RW=P2^1;
  5. sbit E=P1^2;
  6. sbit DQ=P1^4;
  7. sbit buzz=P0^6;
  8. unsigned char temp0,temp1,temp2,readtemp;
  9. unsigned char s[]={"Temp:"};
  10. unsigned char str[]={0,1,2,3,4,5,6,7,8,9};
  11. //************************************************************************
  12. void delay(unsigned int n)
  13. {
  14.   unsigned i=0,j=0;
  15.     for(i=0;i<n;i++)
  16.     {
  17.       for(j=0;j<120;j++);
  18.     }
  19. }
  20. //*************************ds18b20****************************************
  21. void Write_DS18B20(unsigned char dat)
  22. {
  23.         unsigned char i;
  24.         for(i=0;i<8;i++)
  25.         {
  26.                 DQ = 0;
  27.                 DQ = dat&0x01;
  28.                 delay(5);
  29.                 DQ = 1;
  30.                 dat >>= 1;
  31.         }
  32.         delay(5);
  33. }
  34. unsigned char Read_DS18B20(void)
  35. {
  36.         unsigned char i;
  37.         unsigned char dat;
  38.         for(i=0;i<8;i++)
  39.         {
  40.                 DQ = 0;
  41.                 dat >>= 1;
  42.                 DQ = 1;
  43.                 if(DQ)
  44.                 {
  45.                         dat |= 0x80;
  46.                 }
  47.                 delay(5);
  48.         }
  49.         return dat;
  50. }
  51. bit init_ds18b20(void)
  52. {
  53.           bit initflag = 0;
  54.
  55.           DQ = 1;
  56.           delay(12);
  57.           DQ = 0;
  58.           delay(80);
  59.           DQ = 1;
  60.           delay(10);
  61.           initflag = DQ;
  62.           delay(5);
  63.           return initflag;
  64. }
  65. unsigned char Readtemp(void)
  66. {
  67.     unsigned char low,high;
  68.           char temp;
  69.           init_ds18b20();
  70.           Write_DS18B20(0xCC);
  71.           Write_DS18B20(0x44);
  72.           delay(200);
  73.           init_ds18b20();
  74.           Write_DS18B20(0xCC);
  75.           Write_DS18B20(0xBE);
  76.           low = Read_DS18B20();
  77.           high = Read_DS18B20();
  78.           temp = high<<4;
  79.           temp |= (low>>4);
  80.           return temp;
  81. }
  82. //*********************1602************************************
  83. void writedat(unsigned char dat)
  84. {
  85.   RS=1;
  86.     RW=0;
  87.     E=0;
  88.     P0=dat;
  89.     delay(5);
  90.     E=1;
  91.     E=0;
  92. }
  93. void writecom(unsigned char com)
  94. {
  95.   RS=0;
  96.     RW=0;
  97.     E=0;
  98.     P0=com;
  99.     delay(5);
  100.     E=1;
  101.     E=0;
  102. }
  103. void initlcd()
  104. {
  105.   writecom(0x38);
  106.     writecom(0x0c);
  107.     writecom(0x06);
  108.     writecom(0x01);
  109. }
  110. //*************************************************************
  111. void display()//ÏÔê¾oˉêy
  112. {
  113.         unsigned int temp0=0,temp1=0,temp2=0,i=0;
  114.         temp0=readtemp/100;
  115.         temp1=(readtemp%100)/10;
  116.         temp2=readtemp%10;
  117.         writecom(0x80);
  118.         delay(5);
  119.         while(s[i]!='\0')
  120.         {
  121.           writedat(s[i]);
  122.                 delay(5);
  123.                 i++;
  124.         }
  125.
  126.         writecom(0x80+0x40+5);
  127.         delay(5);
  128.         writedat(str[temp0]);
  129.         delay(5);
  130.         writedat(str[temp1]);
  131.         delay(5);
  132.         writedat(str[temp2]);
  133.         delay(5);
  134.         writedat(0xDF);
  135.         delay(5);
  136.         writedat('C');
  137.         delay(5);
  138. }
  139. void main()
  140. {
  141.         initlcd();
  142.         while(1)
  143.         {
  144.          readtemp=Readtemp();
  145.          display();
  146.         }
  147. }
ID:213173 发表于 2021-11-14 20:48 | 只看该作者
变量与函数同名错误:readtemp=Readtemp();
ID:978933 发表于 2021-11-14 21:17 | 只看该作者
已解决!
