查看: 4649|回复: 0
wincc 冗余连接的代码
ID:140343 发表于 2016-9-24 20:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "apdefap.h"
int gscAction( void )
#pragma option(mbcs)
// WINCC:TAGNAME_SECTION_START
// syntax: #define TagNameInAction "DMTagName"
// next TagID : 1
#define TAG_0 "@S7-Programm(1)@AlternateConnectionAddress"
#define TAG_1 "@S7-Programm(1)@ConnectionEstablishMode"
#define TAG_2 "@S7-Programm(1)@ConnectionState"
#define TAG_3 "@S7-Programm(1)@ForceConnectionAddress"
// WINCC:TAGNAME_SECTION_END
// WINCC:PICNAME_SECTION_START
// syntax: #define PicNameInAction "PictureName"
// next PicID : 1
// WINCC:PICNAME_SECTION_END
#pragma code("msrtcli.dll")
#include "msrtapi.h"
#pragma code()
#pragma code( "kernel32.dll" )
VOID GetLocalTime(LPSYSTEMTIME lpSystemTime);
#pragma code()
static int Mld_Main = 0;
static int Mld_Res = 0;
DWORD ServiceID = 0;
static BOOL InitFirst = TRUE;
static MSG_RTCREATE_STRUCT  MsgCreate;
CMN_ERROR Error;
if ( InitFirst == TRUE )
    memset( &MsgCreate, 0, sizeof (MSG_RTCREATE_STRUCT) );
    MsgCreate.dwMsgState = MSG_STATE_COME;
    MsgCreate.wTextValueUsed = 1;
    sprintf( MsgCreate.mtTextValue[0].szText, "S7-Programm(1)" );
    SetTagChar( TAG_0, "MPI,3 0,,1,3,02" );
     InitFirst = FALSE;
if (  GetTagDWordWait( TAG_1 ) == 0  )
    Mld_Main = 0;
    Mld_Res = 0;
    return 0;
    GetLocalTime( &MsgCreate.stMsgTime );
    MSRTStartMsgService ( &ServiceID, NULL, NULL, MSG_NOTIFY_MASK_ARCHIV, NULL, &Error );
    if (  GetTagDWordWait( TAG_2 ) == 0  )
             if (  GetTagDWordWait( TAG_3 ) == 0  )
            if ( Mld_Main == 0 )
                MsgCreate.dwMsgNr = 1012222;
                MSRTCreateMsg( ServiceID, &MsgCreate, &Error );
                Mld_Main = 1;
            if ( Mld_Res == 0 )
                MsgCreate.dwMsgNr = 1012224;
                Mld_Res = 1;
                  SetTagDWord( TAG_3, 1 );
                SetTagDWord( TAG_3, 0 );
        if (  ( Mld_Main != 0 )  ||  ( Mld_Res != 0 )  )
            Mld_Main = 0;
            Mld_Res = 0;
                MsgCreate.dwMsgNr = 1012223;
                MsgCreate.dwMsgNr = 1012225;
    if ( ServiceID != 0 )
        MSRTStopMsgService ( ServiceID, &Error );
     return 1;
