查看: 1768|回复: 0
小程序
ID:225553 发表于 2017-8-7 20:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//  GY-25
//  使用单片机:STC89C52
//  晶振:  11.0592 M
//  液晶屏:LCD1602
//  波特率:9600
#include<REG52.H>
#include<math.h>       //Keil library
#include<stdio.h>      //Keil library
#include<INTRINS.H>
#define uint  unsigned int
//****************电机定义部分******************
sbit IN1=P1^0;//左电机红线
sbit IN2=P1^1;//左电机蓝线
sbit ENA=P1^2;//左电机使能端
sbit wela=P2^7;
sbit dula=P2^6;
sbit lcden=P3^4;
sbit lcdrs=P3^5;
//********定义变量*****************************
uchar   BUF[10];          //数据缓存区
uchar   cnt=0;           //接收数据的累计值
uchar   sign=0;
int YPR[3];
float a;
float yuzhi0=0.0;
float yuzhi1=45.0;
float yuzhi2=90.0;
float yuzhi3=135.0;
float yuzhi4=180.0;
uchar s[18];
//串口中断
void serial_serve(void) interrupt 4
  if(RI==1){         //中断标志
     RI=0;
    BUF[cnt]=SBUF;
   cnt++;        //接收计数
    if(cnt==8)                //
       cnt=0;                 //
       sign=1;
//串口初始化
//9600 bps @ 11.059 MHz
void init_uart()
TMOD=0x21;
TH1=0xfd;
TL1=0xfd;
SCON=0x50;
PS=1;      //串口中断设为高优先级别
TR0=1;    //启动定时器
TR1=1;
ET0=1;     //打开定时器0中断
ES=1;
// EA=1;
//**********延时函数***************
void delay(uint z)//z毫秒延时函数
     uint x,y;
     for(x=z;x>0;x--)
       for(y=110;y>0;y--);
//写指令
void writecom(uchar com)
        lcdrs=0;
        P0=com;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
//写数据
void writedata(uchar date)
        lcdrs=1;//高电平
        P0=date;
        delay(1);
        lcden=1;
        delay(1);
        lcden=0;
//1602液晶初始化
void init()
    dula=0;
    wela=0;
    lcden=0;
    writecom(0x38);
    writecom(0x0c);
    writecom(0x06);
    writecom(0x01);
//*********串口数据发送******************
void  SeriPushSend(uchar send_data)
    SBUF=send_data;
while(!TI);TI=0;
void dis_play(int num)
if(num<0)
  num=-num;
  SeriPushSend('-');
  SeriPushSend('+');
SeriPushSend(0x30|(num/10000));
SeriPushSend(0x30|(num%10000/1000));
SeriPushSend(0x30|(num%1000/100));
SeriPushSend(0x2e);
SeriPushSend(0x30|(num%100/10));
SeriPushSend(0x30|(num%10));
SeriPushSend(',');
void dispose(float jiaodu)
           if((abs(jiaodu)>yuzhi0)&&(abs(jiaodu)<yuzhi1))
                 IN1=1;IN2=0;
                 ENA=0;
                 delay(1);
                 ENA=1;
                 delay(90);
           if((abs(jiaodu)>yuzhi1)&&(abs(jiaodu)<yuzhi2))
                 IN1=0;IN2=1;
                 ENA=0;
                 delay(35);
                 ENA=1;
                 delay(55);
           if((abs(jiaodu)>yuzhi2)&&(abs(jiaodu)<yuzhi3))
                 IN1=1;IN2=0;
                 ENA=0;
                 delay(55);
                 ENA=1;
                 delay(35);
           if((abs(jiaodu)>yuzhi3)&&(abs(jiaodu)<yuzhi4))
                 IN1=0;IN2=1;
                 ENA=0;
                 delay(90);
                 ENA=1;
                 delay(0);
void display()
   if(sign)
          sign=0;
          if(BUF[0]==0XAA&&BUF[7]==0X55)
         {                         //帧头判断
          YPR[0]=(BUF[1]<<8|BUF[2]);
          YPR[1]=(BUF[3]<<8|BUF[4]);
          YPR[2]=(BUF[5]<<8|BUF[6]);
      SeriPushSend('#');
      SeriPushSend('Y');
      SeriPushSend('P');
      SeriPushSend('R');
      SeriPushSend('=');
      dis_play(YPR[0]);
                     dis_play(YPR[1]);
      dis_play(YPR[2]);
      SeriPushSend(0X0d);
      SeriPushSend(0X0a);
       SeriPushSend('N');
void yejing(int num,int num1,int num2)
         uchar i;
         if(num<0)
              num=-num;
              s[0]=0x30+(num/10000);
              s[1]=0x30+(num%10000/1000);
              s[2]=0x30+(num%1000/100);
              s[3]=0x30+(num%100/10);
              s[4]=0x30+(num%10);
              writecom(0x80);
              writedata('-');
              for(i=0;i<=2;i++)
                 writedata(s[i]);
              writedata('.');
              for(i=3;i<=4;i++)
                 writedata(s[i]);
              s[4]=0x30+(num%10);
              writecom(0x80);
              writedata('+');
              for(i=0;i<=2;i++)
                 writedata(s[i]);
              writedata('.');
              for(i=3;i<=4;i++)
                 writedata(s[i]);
         if(num1<0)
              num1=-num1;
              s[5]=0x30+(num1/10000);
              s[6]=0x30+(num1%10000/1000);
              s[7]=0x30+(num1%1000/100);
              s[8]=0x30+(num1%100/10);
              s[9]=0x30+(num1%10);
              writecom(0x88);
              writedata('-');
              for(i=5;i<=7;i++)
                 writedata(s[i]);
              writedata('.');
              for(i=8;i<=9;i++)
                 writedata(s[i]);
              writecom(0x88);
              writedata('+');
              for(i=5;i<=7;i++)
                 writedata(s[i]);
              writedata('.');
              for(i=8;i<=9;i++)
                 writedata(s[i]);
         if(num2<0)
              num2=-num2;
              s[10]=0x30+(num2/10000);
              s[11]=0x30+(num2%10000/1000);
              s[12]=0x30+(num2%1000/100);
              s[13]=0x30+(num2%100/10);
              s[14]=0x30+(num2%10);
              writecom(0x80+0x40);
              writedata('-');
              for(i=10;i<=12;i++)
                 writedata(s[i]);
              writedata('.');
              for(i=13;i<=14;i++)
                 writedata(s[i]);
              writedata('+');
              for(i=10;i<=12;i++)
                 writedata(s[i]);
              writedata('.');
              for(i=13;i<=14;i++)
                 writedata(s[i]);
//主程序
   init_uart();
   init();                                              //初始化串口
   EA=1;                                                      //开总中断
   cnt=0;
   SeriPushSend(0XA5);
   SeriPushSend(0X52);                                        //发送1帧读取命令,连续读取
                      ENA=0;
                      display();
                      a=(YPR[2]/100.0);
                      dispose(a);
                      yejing(YPR[0],YPR[1],YPR[2]);
   }                                                           //end while
