› uid:155764 › 日志
1602整屏移动
已有 1261 次阅读2017-11-1 19:03
#include <reg52.h>
#define LCD1602_DB   P0
sbit LCD1602_RS = P1^0;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E  = P1^5;
bit flagT0 = 0;            //T0中断产生标志
unsigned char T0RH = 0;  //T0重载值的高字节
unsigned char T0RL = 0;  //T0重载值的低字节
unsigned char code str1[] = "Kingst Studio"; //待显示的第一行字符串
unsigned char code str2[] = "Let's move..."; //待显示的第二行字符串,需保持与第一行字符串等长,较短的行可用空格补齐
void ConfigTimer0(unsigned int ms);
void LcdShowStr(unsigned char x, unsigned char y, const unsigned char *str, unsigned char len);
void LcdInit();
void main ()
    unsigned char i;
    unsigned char iMove = 0; //移动索引
    unsigned int  tmrMove = 0; //屏幕移动定时器
    unsigned char pdata bufMove1[16 + sizeof(str1) + 16]; //移动显示的缓冲区
    unsigned char pdata bufMove2[16 + sizeof(str1) + 16]; //移动显示的缓冲区
    EA = 1;            //开总中断
    ConfigTimer0(10);  //配置T0定时10ms
    LcdInit();         //初始化液晶
    for (i=0; i<16; i++)  //缓冲区开头一段填充为空格
        bufMove1[ i] = ' ';
        bufMove2[ i] = ' ';
    for (i=0; i<(sizeof(str1)-1); i++) //待显示字符串拷贝到缓冲区中间位置
        bufMove1[16+i] = str1[ i];
        bufMove2[16+i] = str2[ i];
    for (i=(16+sizeof(str1)-1); i<sizeof(bufMove1); i++)  //缓冲区结尾一段也填充为空格
        bufMove1[ i] = ' ';
        bufMove2[ i] = ' ';
        if (flagT0)
            flagT0 = 0;
            tmrMove += 10;
            if (tmrMove >= 500) //每500ms移动一次屏幕
                tmrMove = 0;
                LcdShowStr(0, 0, bufMove1+iMove, 16); //从缓冲区抽出需显示的一段字符显示到液晶上
                LcdShowStr(0, 1, bufMove2+iMove, 16);
                iMove++;                              //移动索引递增,实现左移
                if (iMove >= (16+sizeof(str1)-1))     //起始位置达到字符串尾部后即返回从头开始
                    iMove = 0;
void ConfigTimer0(unsigned int ms)  //T0配置函数
    unsigned long tmp;
    tmp = 11059200 / 12;      //定时器计数频率
    tmp = (tmp * ms) / 1000;  //计算所需的计数值
    tmp = 65536 - tmp;        //计算定时器重载值
    tmp = tmp + 12;           //修正中断响应延时造成的误差
    T0RH = (unsigned char)(tmp >> 8);  //定时器重载值拆分为高低字节
    T0RL = (unsigned char)tmp;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0为模式1
    TH0 = T0RH;     //加载T0重载值
    TL0 = T0RL;
    ET0 = 1;        //使能T0中断
    TR0 = 1;        //启动T0
void LcdWaitReady()  //等待液晶准备好
    unsigned char sta;
    LCD1602_DB = 0xFF;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_E = 1;
        sta = LCD1602_DB; //读取状态字
        LCD1602_E = 0;
    } while (sta & 0x80); //bit7等于1表示液晶正忙,重复检测直到其等于0为止
void LcdWriteCmd(unsigned char cmd)  //写入命令函数
    LcdWaitReady();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_E  = 1;
    LCD1602_DB = cmd;
    LCD1602_E  = 0;
void LcdWriteDat(unsigned char dat)  //写入数据函数
    LcdWaitReady();
    LCD1602_RS = 1;
    LCD1602_RW = 0;
    LCD1602_E  = 1;
    LCD1602_DB = dat;
    LCD1602_E  = 0;
void LcdInit()  //液晶初始化函数
    LcdWriteCmd(0x38);  //16*2显示,5*7点阵,8位数据接口
    LcdWriteCmd(0x0C);  //显示器开,光标关闭
    LcdWriteCmd(0x06);  //文字不动,地址自动+1
    LcdWriteCmd(0x01);  //清屏
void LcdShowStr(unsigned char x, unsigned char y, const unsigned char *str, unsigned char len)  // 显示字符串,屏幕起始坐标(x,y),字符串指针str,需显示长度len
    unsigned char addr;
    //由输入的显示坐标计算显示RAM的地址
    if (y == 0)
        addr = 0x00 + x; //第一行字符地址从0x00起始
        addr = 0x40 + x; //第二行字符地址从0x40起始
    //由起始显示RAM地址连续写入字符串
    LcdWriteCmd(addr | 0x80); //写入起始地址
    while (len--)       //连续写入字符串数据
        LcdWriteDat(*str);
        str++;
void InterruptTimer0() interrupt 1  //T0中断服务函数
    TH0 = T0RH;  //定时器重新加载重载值
    TL0 = T0RL;
    flagT0 = 1;
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
返回顶部
