uid:208355 日志
arduino自平衡小车
已有 643 次阅读2017-6-6 13:04 | 自平衡
#define L_max 200
#define L_min 150
#define L_a 0.5
#define filter_init 10
#define L_t 20
byte val = 0x00; //调节与控制命令字
int i, LoopCount = 0; //平衡点调整,PID各调整设定系数
int E_0 = 0, E_1 = 0, PWM_Out, Left_PWM, Right_PWM; //误差,PWM输出,左右电机PWM输出
double Kp = 0.0, Kd = 0.0; //PID系数
double Len_filter = 0, Len_0 = 180; //测距滤波,机械平衡距离
unsigned int TrigPin = 4, EchoPin = 5, Len_Echo = 0; //HC-SR04触发信号,回波检测,回波时间
unsigned int M_IN1 = 6, M_IN2 = 7, M_IN3 = 8, M_IN4 = 9; // L298:IN1-IN4
unsigned int M_ENA = 10, M_ENB = 11; // L298:ENA-ENB
unsigned long systime0; //系统时间
//电机输出
void SetMotorVoltage(int Left_MotorVol, int Right_MotorVol) {
  if(Left_MotorVol >= 0) {
    digitalWrite(M_IN1, LOW);
    digitalWrite(M_IN2, HIGH);
  }else {
    digitalWrite(M_IN1, HIGH);
    digitalWrite(M_IN2, LOW);
    Left_MotorVol = -Left_MotorVol;
  if(Right_MotorVol >= 0) {
    digitalWrite(M_IN3, LOW);
    digitalWrite(M_IN4, HIGH);
  }else {
    digitalWrite(M_IN3, HIGH);
    digitalWrite(M_IN4, LOW);
    Right_MotorVol = -Right_MotorVol;
  if(Left_MotorVol > 255) Left_MotorVol = 255; //防止PWM值超过255
  if(Right_MotorVol > 255) Right_MotorVol = 255; //防止PWM值超过255
  analogWrite(M_ENA, Left_MotorVol);
  analogWrite(M_ENB, Right_MotorVol);
//初始化
void setup() {
  Serial.begin(115200);
  pinMode(M_ENA, OUTPUT); //电机控制
  pinMode(M_IN1, OUTPUT);
  pinMode(M_IN2, OUTPUT);
  pinMode(M_ENB, OUTPUT);
  pinMode(M_IN3, OUTPUT);
  pinMode(M_IN4, OUTPUT);
  pinMode(EchoPin, INPUT); //超声波测距
  pinMode(TrigPin, OUTPUT);
  digitalWrite(TrigPin, LOW);
  i = 0;
  systime0 = millis();
//主循环程序
void loop() {
  if(millis() - systime0 >= L_t) {
    digitalWrite(TrigPin, HIGH); //发送超声波测量触发脉冲
    delayMicroseconds(15);
    Len_Echo = pulseIn(EchoPin, HIGH); //回波时间测量
    if((Len_Echo < L_max) && (Len_Echo > L_min)) {
      Len_filter *= L_a; //一阶滤波
      Len_filter += (1 - L_a) * Len_Echo;
      i ++;
      if(i > filter_init){
        i = 100;
        LoopCount ++;
        E_0 = Len_0 - Len_filter;
        PWM_Out = Kp * E_0 + Kd * (E_0 - E_1);
        E_1 = E_0;
        Left_PWM = PWM_Out;
        Right_PWM = PWM_Out;
        SetMotorVoltage(Left_PWM, Right_PWM);
    }else {
      SetMotorVoltage(0, 0); //超出平衡范围,停止PWM输出
      i = 0; Len_filter = 0;
  //处理串口指令,发送相应数据
  if (Serial.available() > 0) {
    val = Serial.read();
    //参数调节
    if(val == 0x01) Kp += 0.01;
    if(val == 0x02) Kp -= 0.01;
    if(val == 0x03) Kd += 0.01;
    if(val == 0x04) Kd -= 0.01;
    if(val == 0x05) Len_0 ++;
    if(val == 0x06) Len_0 --;
    if(val == 0x07) {
      Serial.print(Len_0); Serial.print("        ");
      Serial.print(Kp); Serial.print("        "); Serial.println(Kd); //查看设置参数
    if(val == 0x08) {
      Serial.print(Len_filter); Serial.print("        "); Serial.println(PWM_Out); //
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
返回顶部
