uid:208491 日志
PC控制程序
已有 578 次阅读2017-6-6 20:35
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
//以上几句是自动生成的
using System.IO.Ports;//我加的,包含串口相关的
using System.Text.RegularExpressions;//我加的
namespace WindowsFormsApplication1
    public partial class PCZigbeeLed : Form
        private SerialPort comm = new SerialPort();//我加的,新建一个串口变量
        private bool closing = false;//是否正在关闭串口,执行Application.DoEvents,并阻止再次invoke
        private bool Listening = false;//是否没有执行完invoke相关操作
        public PCZigbeeLed()//自动生成的函数
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            string[] ports = SerialPort.GetPortNames();
            Array.Sort(ports);
            comboPortName.Items.AddRange(ports);
            comboPortName.SelectedIndex = comboPortName.Items.Count > 0 ? 0 : -1;
            //初始化SerialPort对象
            comm.NewLine = "/r/n";
            comm.RtsEnable = true;//根据实际情况吧。
            //comm.DataReceived += comm_DataReceived;
    private void comboPortName_SelectedIndexChanged(object sender, EventArgs e)
        private void buttonOpenClosecom_Click(object sender, EventArgs e)
            //根据当前串口对象,来判断操作
            if (comm.IsOpen)
                closing = true;
                while (Listening) Application.DoEvents();
                //打开时点击,则关闭串口
                comm.Close();
                //this.timer1.Stop();
                closing = false;
                //关闭时点击,则设置好端口,波特率后打开
                comm.PortName = comboPortName.Text;
                comm.BaudRate = 9600;
                try
                    comm.Open();
                catch (Exception ex)
                    //捕获到异常信息,创建一个新的comm对象,之前的不能用了。
                    //现实异常信息给客户。
                    MessageBox.Show(ex.Message);
            //设置按钮的状态
            buttonOpenClosecom.Text = comm.IsOpen ? "关闭串口" : "打开串口";
        private void buttonOpenLight_Click(object sender, EventArgs e)
            byte[] SendBuf = new byte[2];
            SendBuf[0] = 0x31;
            SendBuf[1] = 0x31;
            comm.Write(SendBuf, 0, 2);
            System.Threading.Thread.Sleep(100);
        private void buttonCloseLight_Click(object sender, EventArgs e)
            SendBuf[0] = 0x31;
            SendBuf[1] = 0x30;
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
返回顶部
