那我就来发表一个
MODBUS校检方法
// <summary>
///LRC错误校验用于ASCII模式
/// 取模FF(255)
/// 取反+1
/// </summary>
/// <param name="writeUncheck"></param>
/// <returns></returns>
public static string LRCheck(string writeUncheck)
char[] hexArray = new char[writeUncheck.Length];
hexArray = writeUncheck.ToCharArray();
int decNum = 0, decNumMSB = 0, decNumLSB = 0;
int decByte, decByteTotal = 0;
bool msb = true;
for (int t = 0; t <= hexArray.GetUpperBound(0); t++)
if ((hexArray[t] >= 48) && (hexArray[t] <= 57))
decNum = (hexArray[t] - 48);
else if ((hexArray[t] >= 65) & (hexArray[t] <= 70))
decNum = 10 + (hexArray[t] - 65);
if (msb)
decNumMSB = decNum * 16;
msb = false;
decNumLSB = decNum;
msb = true;
if (msb)
decByte = decNumMSB + decNumLSB;
decByteTotal += decByte;
decByteTotal = (255 - decByteTotal) + 1;
decByteTotal = decByteTotal & 255;
int a, b = 0;
string hexByte = "", hexTotal = "";
double i;
for (i = 0; decByteTotal > 0; i++)
b = Convert.ToInt32(System.Math.Pow(16.0, i));
a = decByteTotal % 16;
decByteTotal /= 16;
if (a <= 9)
hexByte = a.ToString();
switch (a)
case 10:
hexByte = "A";
break;
case 11:
hexByte = "B";
break;
case 12:
hexByte = "C";
break;
case 13:
hexByte = "D";
break;
case 14:
hexByte = "E";
break;
case 15:
hexByte = "F";
break;
hexTotal = String.Concat(hexByte, hexTotal);
return hexTotal;
public void LRCheck(byte[] code)
int sum = 0;
foreach (byte b in code)
sum += b;
sum = sum % 255;//取模FF(255)
sum = ~sum + 1;//取反+1
string lrc = Convert.ToString(sum, 16);
return lrc;
CRC校检
public static string CRCCheck(string val)
val = val.TrimEnd(' ');
string[] spva = val.Split(' ');
byte[] bufData = new byte[spva.Length + 2];
bufData = ToBytesCRC(val);
ushort CRC = 0xffff;
ushort POLYNOMIAL = 0xa001;
for (int i = 0; i < bufData.Length - 2; i++)
CRC ^= bufData[i];
for (int j = 0; j < 8; j++)
if ((CRC & 0x0001) != 0)
CRC >>= 1;
CRC ^= POLYNOMIAL;
CRC >>= 1;
return Maticsoft.DBUtility.HLConvert.ToHex(System.BitConverter.GetBytes(CRC));
/// <summary>
/// 例如把如下字符串转换成字节数组
/// AA AA AA AA 0A 00 68 00 06 03 04 54 21 28 22 E5 F3 16 BB BB BB BB 转换为字节数组
/// </summary>
/// <param name="hex">十六进制字符串</param>
public static byte[] ToBytesCRC(string hex)
string[] temp = hex.Split(' ');
byte[] b = new byte[temp.Length + 2];
for (int i = 0; i < temp.Length; i++)
b[i] = Convert.ToByte(temp[i], 16);
return b;
/// <summary>
/// 将字节数据转换为十六进制字符串,中间用 “ ”分割 如:AA AA AA AA 0A 00 68 00 06 03 04 54 21 28 22 E5 F3 16 BB BB BB BB
/// </summary>
/// <param name="vars">要转换的字节数组</param>
public static String ToHex(byte[] vars)
return BitConverter.ToString(vars).Replace('-', ' ').Trim();
cs 校检
累加和
public static string CSCheck(string str)
if (str.Length == 0) return "";
else str = str.Trim();
byte[] sss = ToBytes(str);
int n = 0;
for (int i = 0; i < sss.Length; i++)
n += sss[i];
return ToHex(n);
/// <summary>
/// AB CD 12 3B 转换为字节数组
/// </summary>
public static byte[] ToBytes(string hex)
byte[] b = new byte[temp.Length];
if (temp[i].Length > 0)
return b;
/// <summary>
/// 转换为符合本程序的十六进制格式
/// </summary>
/// <param name="var">1 2 3 等。</param>
/// <returns>返回十六进制字符串,如果是1-9的话,前面带零</returns>
/// <example>例如: 5 ="05" 12 ="0C" 无论何时,都是两位数。 </example>
public static string ToHex(int var)
int cs = var;
string tmp = "";
if (cs == 0) { tmp = "00"; }
while (cs > 0)
int ys;
cs = Math.DivRem(cs, 256, out ys);
tmp = tmp.Insert(0, string.Format(" {0}", Right("00" + Convert.ToString(ys, 16), 2).ToUpper()));
return tmp.Trim();
public static string Right(string str, int Length)
if ((Length <= 0) || (str == null))
return "";
int length = str.Length;
if (Length >= length)
return str;
return str.Substring(length - Length, Length);
