该模块相对于传统的L298N效率上提高很多,体积上也大幅度减少,在额定范围内,芯片基本不发热。
TB6612FNG每通道输出最高1.2 A的连续驱动电流,启动峰值电流达2A/3.2 A(连续脉冲/单脉冲);
4种电机控制模式:正转/反转/制动/停止;
PWM支持频率高达100 kHz;
待机状态;
片内低压检测电路与热停机保护电路;
工作温度:-20~85℃;
SSOP24小型贴片封装。
引脚说明
A控制信号输入------PWMA VM ------电机驱动电压输入端(4.5V-15V)
A电机输入端2 ------AIN2 VCC ------逻辑电平输入端(2.7V-5.5V)
A电机输入端1 ------AIN1 GND ------ 接地
正常工作/待机状态控制端------STBY AO1 ------- A电机输出端1
B电机输入端1------BIN1 AO2 ------ A电机输出端2
B电机输入端2------BIN2 BO2 ------ B电机输出端2
B控制信号输入端------PWMB BO1 ------ B电机输出端1
接地------GND GND ------- 接地
接线方式
程序实现
- //motor A connected between A01 and A02
- //motor B connected between B01 and B02
- int STBY = 10; //standby
- //Motor A
- int PWMA = 3; //Speed control
- int AIN1 = 9; //Direction
- int AIN2 = 8; //Direction
- //Motor B
- int PWMB = 5; //Speed control
- int BIN1 = 11; //Direction
- int BIN2 = 12; //Direction
- void setup(){
- pinMode(STBY, OUTPUT);
- pinMode(PWMA, OUTPUT);
- pinMode(AIN1, OUTPUT);
- pinMode(AIN2, OUTPUT);
- pinMode(PWMB, OUTPUT);
- pinMode(BIN1, OUTPUT);
- pinMode(BIN2, OUTPUT);
- void loop(){
- move(1, 255, 1); //motor 1, full speed, left
- move(2, 255, 1); //motor 2, full speed, left
- delay(1000); //go for 1 second
- stop(); //stop
- delay(250); //hold for 250ms until move again
- move(1, 128, 0); //motor 1, half speed, right
- move(2, 128, 0); //motor 2, half speed, right
- delay(1000);
- stop();
- delay(250);
- void move(int motor, int speed, int direction){
- //Move specific motor at speed and direction
- //motor: 0 for B 1 for A
- //speed: 0 is off, and 255 is full speed
- //direction: 0 clockwise, 1 counter-clockwise
- digitalWrite(STBY, HIGH); //disable standby
- boolean inPin1 = LOW;
- boolean inPin2 = HIGH;
- if(direction == 1){
- inPin1 = HIGH;
- inPin2 = LOW;
- if(motor == 1){
- digitalWrite(AIN1, inPin1);
- digitalWrite(AIN2, inPin2);
- analogWrite(PWMA, speed);
- }else{
- digitalWrite(BIN1, inPin1);
- digitalWrite(BIN2, inPin2);
- analogWrite(PWMB, speed);
- void stop(){
- //enable standby
- digitalWrite(STBY, LOW);
实例效果
通电,并测量马达A与B的输出电压,基本相同,电压差在正负0.03V,输出稳定。
想必能完美解决L9110S 和 L298N两路电机输出电压误差大导致的走不到直线。
