uid:58583 日志
改写的液晶驱动
已有 803 次阅读2017-10-3 11:51 |个人分类:程序
Normal 0 7.8 磅 0 2 false false false EN-US ZH-CN X-NONE MicrosoftInternetExplorer4
#include  "stm32f10x.h"
static __IO uint32_t TimingDelay;
void RCC_Configuration(void);
void Delay(__IO uint32_t nTime);
#define Line1   0x80//液晶第一行
#define Line2   0x90//液晶第二行
#define Line3   0x88//液晶第三行
#define Line4   0x98//液晶第四行
#define LCD_IO  GPIOE //我用的是 E.2 E.3 E.4 E.5 E.6
#define CS      GPIO_Pin_2
#define RW      GPIO_Pin_3
#define CLK     GPIO_Pin_4
#define PSB     GPIO_Pin_5
#define RST     GPIO_Pin_6
#define SET(n)    GPIO_SetBits(GPIOE,n)     //将对应管脚输出高电平
#define RESET(n)  GPIO_ResetBits(GPIOE,n)//输出低电平
#define CMD       (uint32_t)0xf8000000 //串行 写入的是命令要先写入0xf8
#define DATE      (uint32_t)0xfa000000 // 串行 写入数据要先写入0xfa
void LCD_IOinit_OUT() //推挽输出模式 ,管脚配置,不多解释,库函数有
  GPIO_InitTypeDef GPIO_InitStructure;
  GPIO_InitStructure.GPIO_Pin =CS|RW|CLK|PSB|RST;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(LCD_IO, &GPIO_InitStructure);
void LCD_Write(uint32_t cmd,uint8_t ddata)//LCD 写函数
       uint32_t temp=cmd;
       uint32_t i;
       RESET(CS); //片选拉低
    temp|=((uint32_t)(ddata&(uint8_t)0xf0)<<16)+((uint32_t)(ddata&(uint8_t)0x0f)<<12);
       SET(CS); //片选拉高,开始传输数据
       for(i=0;i<24;i++)
              if(temp&0x80000000)SET(RW);  //取出最高位,如果是1,那么RW就写1
              else RESET(RW);  //如果是0 RW就写0
              SET(CLK);//向液晶写数据  是在下降沿写入的
              Delay(2);//稍作延时
              RESET(CLK);//拉低产生下降沿,写入数据
              temp=temp<<1;//左移一位 ,写入下一位
       RESET(CS);   //拉低片选,写入数据完毕
void Display(uint8_t addr,uint8_t *hz)
   LCD_Write(CMD,addr);
   Delay(3);
   while(*hz!='\0')
        LCD_Write(DATE,*hz);
        hz++;
        Delay(3);
void LCD_init()//液晶初始化
       RESET(CS); //拉低片选
       RESET(PSB);//PSB拉低,表示是串行,拉高则是并行
       RESET(RST);//拉低RST
       Delay(100);
       SET(RST);
       Delay(40);
       LCD_Write(CMD,0x30);//8位数据传输
    Delay(40);
    LCD_Write(CMD,0x0c);//显示开,游标开
    Delay(40);
       LCD_Write(CMD,0x01);//清屏
    Delay(40);
       LCD_Write(CMD,0x06);//进入点设定 AC+1
       Delay(40);
int main()
       RCC_Configuration();
       SysTick_Config(72000);          //配置SYSTICK时钟节拍为1ms一次
       LCD_IOinit_OUT();
       LCD_init();
          Display(Line1,"你妹");
          Display(Line2,"你妹");
          Display(Line3,"你妹妹");
          Display(Line4,"完事了,哈哈哈哈哈");
  SystemInit();
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE , ENABLE);
  TimingDelay = nTime;
  while(TimingDelay != 0);
void TimingDelay_Decrement(void)
  if (TimingDelay != 0x00)
    TimingDelay--;
st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.5pt; mso-bidi-font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:宋体; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-font-kerning:1.0pt;}
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
返回顶部
