uid:92918 日志
求大神讲解
已有 1045 次阅读2017-12-16 19:53
*                       普中科技
* 实 验 名 : LED点阵数字倒计时
* 实验说明       :
* 连接方式       : 见接线图
* 注    意
#include <REG51.H>
//--重定义函数变量--//
#define uint  unsigned int
#define ulong unsigned long
//--定义SPI要使用的 IO--//
sbit MOSIO = P3^4;
sbit R_CLK = P3^5;
sbit S_CLK = P3^6;
//---全局变量声明--//
ulong column;   //点阵列
ulong row;      //点阵行
ulong dt;
//--点阵显示数组--//
uchar code tab0[] =
{0x00, 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08,
 0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80,
 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00,
 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80, 0x00};
//--10字模--//
uchar code tab1[] =
{0, 0, 0, 0, 0, 0, 8, 24, 14, 36, 8, 66, 8, 66, 8, 66,
 8, 66, 8, 66, 8, 66, 8, 36, 62, 24, 0, 0, 0, 0, 0, 0};
//--09字模--//
uchar code tab2[] =
{0, 0, 0, 0, 0, 0, 24, 24, 36, 36, 66, 66, 66, 66, 66,
 66, 66, 100, 66, 88, 66, 64, 66, 64, 36, 36, 24, 28, 0, 0, 0, 0} ;
//--08字模--//
uchar code tab3[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66, 66, 66, 66, 36,
66, 24, 66, 36, 66, 66, 66, 66, 36, 66, 24, 60, 0, 0, 0, 0};
//--07字模--//
uchar code tab4[] =
{0, 0, 0, 0, 0, 0, 24, 126, 36, 34, 66, 34, 66, 16, 66, 16,
 66, 8, 66, 8, 66, 8, 66, 8, 36, 8, 24, 8, 0, 0, 0, 0};
//--06字模--//
uchar code tab5[] =
{0, 0, 0, 0, 0, 0, 24, 56, 36, 36, 66, 2, 66, 2, 66, 26, 66,
 38, 66, 66, 66, 66, 66, 66, 36, 36, 24, 24, 0, 0, 0, 0};
//--05字模--//
uchar code tab6[] =
{0, 0, 0, 0, 0, 0, 24, 126, 36, 2, 66, 2, 66, 2, 66, 26, 66,
 38, 66, 64, 66, 64, 66, 66, 36, 34, 24, 28, 0, 0, 0, 0};
//--04字模--//
uchar code tab7[] =
{0, 0, 0, 0, 0, 0, 24, 32, 36, 48, 66, 40, 66, 36, 66, 36, 66,
34, 66, 34, 66, 126, 66, 32, 36, 32, 24, 120, 0, 0, 0, 0};
//--03字模--//
uchar code tab8[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66, 66, 32, 66, 24, 66,
 32, 66, 64, 66, 64, 66, 66, 36, 34, 24, 28, 0, 0, 0, 0};
//--02字模--//
uchar code tab9[] =
{0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66, 66, 66, 66, 32, 66,
 32, 66, 16, 66, 8, 66, 4, 36, 66, 24, 126, 0, 0, 0, 0};
//--01字模--//
uchar code tab10[] =
{0, 0, 0, 0, 0, 0, 24, 8, 36, 14, 66, 8, 66, 8, 66, 8, 66, 8, 66,
8, 66, 8, 66, 8, 36, 8, 24, 62, 0, 0, 0, 0};
//--00字模--//
uchar code tab11[] =
{0, 0, 0, 0, 0, 0, 24, 24, 36, 36, 66, 66, 66, 66, 66, 66, 66, 66,
//--GO--//
uchar code tab12[] =
{0, 0, 0, 0, 0, 0, 60, 28, 34, 34, 34, 65, 1, 65, 1, 65, 1, 65, 113,
 65, 33, 65, 34, 65, 34, 34, 28, 28, 0, 0, 0, 0};
//--全局函数声明--//
void HC595SendData(  uchar BT3, uchar BT2,uchar BT1,uchar BT0);
* 函 数 名         : main
* 函数功能   : 主函数
* 输    入         : 无
* 输    出         : 无
void main(void)
int k, i, ms;
i = 60; //显示时间
//--显示10--//
for(ms = i; ms > 0; ms--)
for(k = 0; k < 16; k++)
HC595SendData(~tab1[2*k +1],~tab1[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
HC595SendData(0xff,0xff,0,0);
//--显示09--//
HC595SendData(~tab2[2*k +1],~tab2[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--显示08--//
HC595SendData(~tab3[2*k +1],~tab3[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--显示07--//
HC595SendData(~tab4[2*k +1],~tab4[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--显示06--//
HC595SendData(~tab5[2*k +1],~tab5[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
   //--显示05--//
for(k = 0; k < 16; k++) //欢
HC595SendData(~tab6[2*k +1],~tab6[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
   //--显示04--//
HC595SendData(~tab7[2*k +1],~tab7[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--显示03--//
HC595SendData(~tab8[2*k +1],~tab8[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--显示02--//
HC595SendData(~tab9[2*k +1],~tab9[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--显示01--//
HC595SendData(~tab10[2*k +1],~tab10[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
//--显示00--//
HC595SendData(~tab11[2*k +1],~tab11[2*k],tab0[2*k],tab0[2*k + 1]);
//--清屏--//
HC595SendData(0xff,0xff,0,0);        //清屏
   //--一直显示G0--//
for(k = 0; k < 16; k++) //中
HC595SendData(~tab12[2*k +1],~tab12[2*k],tab0[2*k],tab0[2*k + 1]);
* 函 数 名         : HC595SendData
* 函数功能   : 通过595发送四个字节的数据
* 输    入         : BT3:第四个595输出数值
*                  * BT2: 第三个595输出数值
*                  * BT1:第二个595输出数值
*                  * BT0:第一个595输出数值
* 输    出         : 无
uchar i;
//--发送第一个字节--//
for(i=0;i<8;i++)
MOSIO = BT3 >> 7 ; //从高位到低位
BT3 <<= 1;
S_CLK = 0;
S_CLK = 1;
//--发送第一个字节--//
for(i=0;i<8;i++)
MOSIO = BT2 >>7; //从高位到低位
BT2 <<= 1;
S_CLK = 0;
S_CLK = 1;
//--发送第一个字节--//
for(i=0;i<8;i++)
MOSIO = BT1 >> 7; //从高位到低位
BT1 <<= 1;
S_CLK = 0;
S_CLK = 1;
//--发送第一个字节--//
for(i=0;i<8;i++)
MOSIO = BT0 >> 7; //从高位到低位
BT0 <<= 1;
S_CLK = 0;
S_CLK = 1;
//--输出--//
R_CLK = 0; //set dataline low
R_CLK = 1; //片选
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
返回顶部
