标题: startup_stm32f767xx.s启动文件 [打印本页]
作者: 啊啊啊啊灰    时间: 2017-12-14 18:55
ST官方启动文件 File Name          : startup_stm32f767xx.s
  1. ;******************** (C) COPYRIGHT 2016 STMicroelectronics ********************
  2. ;* File Name          : startup_stm32f767xx.s
  3. ;* Author             : MCD Application Team
  4. ;* Version            : V1.1.0
  5. ;* Date               : 22-April-2016
  6. ;* Description        : STM32F767xx devices vector table for MDK-ARM toolchain.
  7. ;*                      This module performs:
  8. ;*                      - Set the initial SP
  9. ;*                      - Set the initial PC == Reset_Handler
  10. ;*                      - Set the vector table entries with the exceptions ISR address
  11. ;*                      - Branches to __main in the C library (which eventually
  12. ;*                        calls main()).
  13. ;*                      After Reset the CortexM7 processor is in Thread mode,
  14. ;*                      priority is Privileged, and the Stack is set to Main.
  15. ;* <<< Use Configuration Wizard in Context Menu >>>
  16. ;*******************************************************************************
  17. ;
  18. ;* Redistribution and use in source and binary forms, with or without modification,
  19. ;* are permitted provided that the following conditions are met:
  20. ;*   1. Redistributions of source code must retain the above copyright notice,
  21. ;*      this list of conditions and the following disclaimer.
  22. ;*   2. Redistributions in binary form must reproduce the above copyright notice,
  23. ;*      this list of conditions and the following disclaimer in the documentation
  24. ;*      and/or other materials provided with the distribution.
  25. ;*   3. Neither the name of STMicroelectronics nor the names of its contributors
  26. ;*      may be used to endorse or promote products derived from this software
  27. ;*      without specific prior written permission.
  28. ;*
  29. ;* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  30. ;* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  31. ;* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  32. ;* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  33. ;* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  34. ;* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  35. ;* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  36. ;* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  37. ;* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  38. ;* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  39. ;
  40. ;*******************************************************************************
  41. ; Amount of memory (in bytes) allocated for Stack
  42. ; Tailor this value to your application needs
  43. ; <h> Stack Configuration
  44. ;   <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
  45. ; </h>
  46. Stack_Size      EQU     0x00000800
  47.                 AREA    STACK, NOINIT, READWRITE, ALIGN=3
  48. Stack_Mem       SPACE   Stack_Size
  49. __initial_sp
  50. ; <h> Heap Configuration
  51. ;   <o>  Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
  52. ; </h>
  53. Heap_Size       EQU     0x00000000
  54.                 AREA    HEAP, NOINIT, READWRITE, ALIGN=3
  55. __heap_base
  56. Heap_Mem        SPACE   Heap_Size
  57. __heap_limit
  58.                 PRESERVE8
  59.                 THUMB
  60. ; Vector Table Mapped to Address 0 at Reset
  61.                 AREA    RESET, DATA, READONLY
  62.                 EXPORT  __Vectors
  63.                 EXPORT  __Vectors_End
  64.                 EXPORT  __Vectors_Size
  65. __Vectors       DCD     __initial_sp               ; Top of Stack
  66.                 DCD     Reset_Handler              ; Reset Handler
  67.                 DCD     NMI_Handler                ; NMI Handler
  68.                 DCD     HardFault_Handler          ; Hard Fault Handler
  69.                 DCD     MemManage_Handler          ; MPU Fault Handler
  70.                 DCD     BusFault_Handler           ; Bus Fault Handler
  71.                 DCD     UsageFault_Handler         ; Usage Fault Handler
  72.                 DCD     0                          ; Reserved
  73.                 DCD     0                          ; Reserved
  74.                 DCD     0                          ; Reserved
  75.                 DCD     0                          ; Reserved
  76.                 DCD     SVC_Handler                ; SVCall Handler
  77.                 DCD     DebugMon_Handler           ; Debug Monitor Handler
  78.                 DCD     0                          ; Reserved
  79.                 DCD     PendSV_Handler             ; PendSV Handler
  80.                 DCD     SysTick_Handler            ; SysTick Handler
  81.                 ; External Interrupts
  82.                 DCD     WWDG_IRQHandler                   ; Window WatchDog
  83.                 DCD     PVD_IRQHandler                    ; PVD through EXTI Line detection
  84.                 DCD     TAMP_STAMP_IRQHandler             ; Tamper and TimeStamps through the EXTI line
  85.                 DCD     RTC_WKUP_IRQHandler               ; RTC Wakeup through the EXTI line
  86.                 DCD     FLASH_IRQHandler                  ; FLASH
  87.                 DCD     RCC_IRQHandler                    ; RCC
  88.                 DCD     EXTI0_IRQHandler                  ; EXTI Line0
  89.                 DCD     EXTI1_IRQHandler                  ; EXTI Line1
  90.                 DCD     EXTI2_IRQHandler                  ; EXTI Line2
  91.                 DCD     EXTI3_IRQHandler                  ; EXTI Line3
  92.                 DCD     EXTI4_IRQHandler                  ; EXTI Line4
  93.                 DCD     DMA1_Stream0_IRQHandler           ; DMA1 Stream 0
  94.                 DCD     DMA1_Stream1_IRQHandler           ; DMA1 Stream 1
  95.                 DCD     DMA1_Stream2_IRQHandler           ; DMA1 Stream 2
  96.                 DCD     DMA1_Stream3_IRQHandler           ; DMA1 Stream 3
  97.                 DCD     DMA1_Stream4_IRQHandler           ; DMA1 Stream 4
  98.                 DCD     DMA1_Stream5_IRQHandler           ; DMA1 Stream 5
  99.                 DCD     DMA1_Stream6_IRQHandler           ; DMA1 Stream 6
  100.                 DCD     ADC_IRQHandler                    ; ADC1, ADC2 and ADC3s
  101.                 DCD     CAN1_TX_IRQHandler                ; CAN1 TX
  102.                 DCD     CAN1_RX0_IRQHandler               ; CAN1 RX0
  103.                 DCD     CAN1_RX1_IRQHandler               ; CAN1 RX1
  104.                 DCD     CAN1_SCE_IRQHandler               ; CAN1 SCE
  105.                 DCD     EXTI9_5_IRQHandler                ; External Line[9:5]s
  106.                 DCD     TIM1_BRK_TIM9_IRQHandler          ; TIM1 Break and TIM9
  107.                 DCD     TIM1_UP_TIM10_IRQHandler          ; TIM1 Update and TIM10
  108.                 DCD     TIM1_TRG_COM_TIM11_IRQHandler     ; TIM1 Trigger and Commutation and TIM11
  109.                 DCD     TIM1_CC_IRQHandler                ; TIM1 Capture Compare
  110.                 DCD     TIM2_IRQHandler                   ; TIM2
  111.                 DCD     TIM3_IRQHandler                   ; TIM3
  112.                 DCD     TIM4_IRQHandler                   ; TIM4
  113.                 DCD     I2C1_EV_IRQHandler                ; I2C1 Event
  114.                 DCD     I2C1_ER_IRQHandler                ; I2C1 Error
  115.                 DCD     I2C2_EV_IRQHandler                ; I2C2 Event
  116.                 DCD     I2C2_ER_IRQHandler                ; I2C2 Error
  117.                 DCD     SPI1_IRQHandler                   ; SPI1
  118.                 DCD     SPI2_IRQHandler                   ; SPI2
  119.                 DCD     USART1_IRQHandler                 ; USART1
  120.                 DCD     USART2_IRQHandler                 ; USART2
  121.                 DCD     USART3_IRQHandler                 ; USART3
  122.                 DCD     EXTI15_10_IRQHandler              ; External Line[15:10]s
  123.                 DCD     RTC_Alarm_IRQHandler              ; RTC Alarm (A and B) through EXTI Line
  124.                 DCD     OTG_FS_WKUP_IRQHandler            ; USB OTG FS Wakeup through EXTI line
  125.                 DCD     TIM8_BRK_TIM12_IRQHandler         ; TIM8 Break and TIM12
  126.                 DCD     TIM8_UP_TIM13_IRQHandler          ; TIM8 Update and TIM13
  127.                 DCD     TIM8_TRG_COM_TIM14_IRQHandler     ; TIM8 Trigger and Commutation and TIM14
  128.                 DCD     TIM8_CC_IRQHandler                ; TIM8 Capture Compare
  129.                 DCD     DMA1_Stream7_IRQHandler           ; DMA1 Stream7
  130.                 DCD     FMC_IRQHandler                    ; FMC
  131.                 DCD     SDMMC1_IRQHandler                 ; SDMMC1
  132.                 DCD     TIM5_IRQHandler                   ; TIM5
  133.                 DCD     SPI3_IRQHandler                   ; SPI3
  134.                 DCD     UART4_IRQHandler                  ; UART4
  135.                 DCD     UART5_IRQHandler                  ; UART5
  136.                 DCD     TIM6_DAC_IRQHandler               ; TIM6 and DAC1&2 underrun errors
  137.                 DCD     TIM7_IRQHandler                   ; TIM7
  138.                 DCD     DMA2_Stream0_IRQHandler           ; DMA2 Stream 0
  139.                 DCD     DMA2_Stream1_IRQHandler           ; DMA2 Stream 1
  140.                 DCD     DMA2_Stream2_IRQHandler           ; DMA2 Stream 2
  141.                 DCD     DMA2_Stream3_IRQHandler           ; DMA2 Stream 3
  142.                 DCD     DMA2_Stream4_IRQHandler           ; DMA2 Stream 4
  143.                 DCD     ETH_IRQHandler                    ; Ethernet
  144.                 DCD     ETH_WKUP_IRQHandler               ; Ethernet Wakeup through EXTI line
  145.                 DCD     CAN2_TX_IRQHandler                ; CAN2 TX
  146.                 DCD     CAN2_RX0_IRQHandler               ; CAN2 RX0
  147.                 DCD     CAN2_RX1_IRQHandler               ; CAN2 RX1
  148.                 DCD     CAN2_SCE_IRQHandler               ; CAN2 SCE
  149.                 DCD     OTG_FS_IRQHandler                 ; USB OTG FS
  150.                 DCD     DMA2_Stream5_IRQHandler           ; DMA2 Stream 5
  151.                 DCD     DMA2_Stream6_IRQHandler           ; DMA2 Stream 6
  152.                 DCD     DMA2_Stream7_IRQHandler           ; DMA2 Stream 7
  153.                 DCD     USART6_IRQHandler                 ; USART6
  154.                 DCD     I2C3_EV_IRQHandler                ; I2C3 event
  155.                 DCD     I2C3_ER_IRQHandler                ; I2C3 error
  156.                 DCD     OTG_HS_EP1_OUT_IRQHandler         ; USB OTG HS End Point 1 Out
  157.                 DCD     OTG_HS_EP1_IN_IRQHandler          ; USB OTG HS End Point 1 In
  158.                 DCD     OTG_HS_WKUP_IRQHandler            ; USB OTG HS Wakeup through EXTI
  159.                 DCD     OTG_HS_IRQHandler                 ; USB OTG HS
  160.                 DCD     DCMI_IRQHandler                   ; DCMI
  161.                 DCD     0                                 ; Reserved
  162.                 DCD     RNG_IRQHandler                    ; Rng
  163.                 DCD     FPU_IRQHandler                    ; FPU
  164.                 DCD     UART7_IRQHandler                  ; UART7
  165.                 DCD     UART8_IRQHandler                  ; UART8
  166.                 DCD     SPI4_IRQHandler                   ; SPI4
  167.                 DCD     SPI5_IRQHandler                   ; SPI5
  168.                 DCD     SPI6_IRQHandler                   ; SPI6
  169.                 DCD     SAI1_IRQHandler                   ; SAI1
  170.                 DCD     LTDC_IRQHandler                   ; LTDC
  171.                 DCD     LTDC_ER_IRQHandler                ; LTDC error
  172.                 DCD     DMA2D_IRQHandler                  ; DMA2D
  173.                 DCD     SAI2_IRQHandler                   ; SAI2
  174.                 DCD     QUADSPI_IRQHandler                ; QUADSPI
  175.                 DCD     LPTIM1_IRQHandler                 ; LPTIM1
  176.                 DCD     CEC_IRQHandler                    ; HDMI_CEC
  177.                 DCD     I2C4_EV_IRQHandler                ; I2C4 Event
  178.                 DCD     I2C4_ER_IRQHandler                ; I2C4 Error
  179.                 DCD     SPDIF_RX_IRQHandler               ; SPDIF_RX
  180.                 DCD     0                                 ; Reserved
  181.                 DCD     DFSDM1_FLT0_IRQHandler            ; DFSDM1 Filter 0 global Interrupt
  182.                 DCD     DFSDM1_FLT1_IRQHandler            ; DFSDM1 Filter 1 global Interrupt
  183.                 DCD     DFSDM1_FLT2_IRQHandler            ; DFSDM1 Filter 2 global Interrupt
  184.                 DCD     DFSDM1_FLT3_IRQHandler            ; DFSDM1 Filter 3 global Interrupt
  185.                 DCD     SDMMC2_IRQHandler                 ; SDMMC2
  186.                 DCD     CAN3_TX_IRQHandler                ; CAN3 TX
  187.                 DCD     CAN3_RX0_IRQHandler               ; CAN3 RX0
  188.                 DCD     CAN3_RX1_IRQHandler               ; CAN3 RX1
  189.                 DCD     CAN3_SCE_IRQHandler               ; CAN3 SCE
  190.                 DCD     JPEG_IRQHandler                   ; JPEG
  191.                 DCD     MDIOS_IRQHandler                  ; MDIOS
  192. __Vectors_End
  193. __Vectors_Size  EQU  __Vectors_End - __Vectors
  194.                 AREA    |.text|, CODE, READONLY
  195. ; Reset handler
  196. Reset_Handler    PROC
  197.                  EXPORT  Reset_Handler             [WEAK]
  198.         ;IMPORT  SystemInit                                                ;寄存器代码,不需要在这里调用SystemInit函数,故屏蔽掉,库函数版本代码,可以留下
  199.        ;不过需要在外部实现SystemInit函数,否则会报错.
  200.         IMPORT  __main
  201.                                  IF {FPU} != "SoftVFP"                        ;通过Target选项卡的Floating Point Hardware选项来控制.
  202.        ;如果选择:Not Used,则不编译以下代码(到ENDIF结束)
  203.        ;如果选择:Use Single/Double Precision,则编译以下代码
  204.                                 ;Enable Floating Point Support at reset for FPU
  205.                  LDR.W        R0, =0xE000ED88                        ; Load address of CPACR register
  206.                  LDR        R1, [R0]                ; Read value at CPACR
  207.                  ORR        R1,  R1, #(0xF <<20)        ; Set bits 20-23 to enable CP10 and CP11 coprocessors
  208.        ; Write back the modified CPACR value
  209.                  STR        R1, [R0]                ; Wait for store to complete
  210.                  DSB
  211.        ;针对OS应用,FPU寄存器全部由OS压栈保存,关闭硬件压栈
  212.                                                 ; Disable automatic FP register content
  213.                                                 ; Disable lazy context switch
  214.                  LDR.W        R0, =0xE000EF34         ; Load address to FPCCR register
  215.                  LDR        R1, [R0]
  216.                  AND        R1,  R1, #(0x3FFFFFFF)        ; Clear the LSPEN and ASPEN bits
  217.                  STR        R1, [R0]
  218.                  ISB                                                        ; Reset pipeline now the FPU is enabled
  219.                  ENDIF
  220.
  221.                  ;LDR        R0, =SystemInit                        ;寄存器代码,未用到,屏蔽
  222.                  ;BLX        R0                                                ;寄存器代码,未用到,屏蔽
  223.                  LDR     R0, =__main
  224.                  BX      R0
  225.                  ENDP
  226. ; Dummy Exception Handlers (infinite loops which can be modified)
  227. NMI_Handler     PROC
  228.                 EXPORT  NMI_Handler                [WEAK]
  229.                 B       .
  230.                 ENDP
  231. HardFault_Handler\
  232.                 PROC
  233.                 EXPORT  HardFault_Handler          [WEAK]
  234.                 B       .
  235.                 ENDP
  236. MemManage_Handler\
  237.                 PROC
  238.                 EXPORT  MemManage_Handler          [WEAK]
  239.                 B       .
  240.                 ENDP
  241. BusFault_Handler\
  242.                 PROC
  243.                 EXPORT  BusFault_Handler           [WEAK]
  244.                 B       .
  245.                 ENDP
  246. UsageFault_Handler\
  247.                 PROC
  248.                 EXPORT  UsageFault_Handler         [WEAK]
  249.                 B       .
  250.                 ENDP
  251. SVC_Handler     PROC
  252.                 EXPORT  SVC_Handler                [WEAK]
  253.                 B       .
  254.                 ENDP
  255. DebugMon_Handler\
  256.                 PROC
  257.                 EXPORT  DebugMon_Handler           [WEAK]
  258.                 B       .
  259.                 ENDP
  260. PendSV_Handler  PROC
  261.                 EXPORT  PendSV_Handler             [WEAK]
  262.                 B       .
  263.                 ENDP
  264. SysTick_Handler PROC
  265.                 EXPORT  SysTick_Handler            [WEAK]
  266.                 B       .
  267.                 ENDP
  268. Default_Handler PROC
  269.                 EXPORT  WWDG_IRQHandler                   [WEAK]
  270.                 EXPORT  PVD_IRQHandler                    [WEAK]
  271.                 EXPORT  TAMP_STAMP_IRQHandler             [WEAK]
  272.                 EXPORT  RTC_WKUP_IRQHandler               [WEAK]
  273.                 EXPORT  FLASH_IRQHandler                  [WEAK]
  274.                 EXPORT  RCC_IRQHandler                    [WEAK]
  275.                 EXPORT  EXTI0_IRQHandler                  [WEAK]
  276.                 EXPORT  EXTI1_IRQHandler                  [WEAK]
  277.                 EXPORT  EXTI2_IRQHandler                  [WEAK]
  278.                 EXPORT  EXTI3_IRQHandler                  [WEAK]
  279.                 EXPORT  EXTI4_IRQHandler                  [WEAK]
  280.                 EXPORT  DMA1_Stream0_IRQHandler           [WEAK]
  281.                 EXPORT  DMA1_Stream1_IRQHandler           [WEAK]
  282.                 EXPORT  DMA1_Stream2_IRQHandler           [WEAK]
  283.                 EXPORT  DMA1_Stream3_IRQHandler           [WEAK]
  284.                 EXPORT  DMA1_Stream4_IRQHandler           [WEAK]
  285.                 EXPORT  DMA1_Stream5_IRQHandler           [WEAK]
  286.                 EXPORT  DMA1_Stream6_IRQHandler           [WEAK]
  287.                 EXPORT  ADC_IRQHandler                    [WEAK]
  288.                 EXPORT  CAN1_TX_IRQHandler                [WEAK]
  289.                 EXPORT  CAN1_RX0_IRQHandler               [WEAK]
  290.                 EXPORT  CAN1_RX1_IRQHandler               [WEAK]
  291.                 EXPORT  CAN1_SCE_IRQHandler               [WEAK]
  292.                 EXPORT  EXTI9_5_IRQHandler                [WEAK]
  293.                 EXPORT  TIM1_BRK_TIM9_IRQHandler          [WEAK]
  294.                 EXPORT  TIM1_UP_TIM10_IRQHandler          [WEAK]
  295.                 EXPORT  TIM1_TRG_COM_TIM11_IRQHandler     [WEAK]
  296.                 EXPORT  TIM1_CC_IRQHandler                [WEAK]
  297.                 EXPORT  TIM2_IRQHandler                   [WEAK]
  298.                 EXPORT  TIM3_IRQHandler                   [WEAK]
  299.                 EXPORT  TIM4_IRQHandler                   [WEAK]
  300.                 EXPORT  I2C1_EV_IRQHandler                [WEAK]
  301.                 EXPORT  I2C1_ER_IRQHandler                [WEAK]
  302.                 EXPORT  I2C2_EV_IRQHandler                [WEAK]
  303.                 EXPORT  I2C2_ER_IRQHandler                [WEAK]
  304.                 EXPORT  SPI1_IRQHandler                   [WEAK]
  305.                 EXPORT  SPI2_IRQHandler                   [WEAK]
  306.                 EXPORT  USART1_IRQHandler                 [WEAK]
  307.                 EXPORT  USART2_IRQHandler                 [WEAK]
  308.                 EXPORT  USART3_IRQHandler                 [WEAK]
  309.                 EXPORT  EXTI15_10_IRQHandler              [WEAK]
  310.                 EXPORT  RTC_Alarm_IRQHandler              [WEAK]
  311.                 EXPORT  OTG_FS_WKUP_IRQHandler            [WEAK]
  312.                 EXPORT  TIM8_BRK_TIM12_IRQHandler         [WEAK]
  313.                 EXPORT  TIM8_UP_TIM13_IRQHandler          [WEAK]
  314.                 EXPORT  TIM8_TRG_COM_TIM14_IRQHandler     [WEAK]
  315.                 EXPORT  TIM8_CC_IRQHandler                [WEAK]
  316.                 EXPORT  DMA1_Stream7_IRQHandler           [WEAK]
  317.                 EXPORT  FMC_IRQHandler                    [WEAK]
  318.                 EXPORT  SDMMC1_IRQHandler                 [WEAK]
  319.                 EXPORT  TIM5_IRQHandler                   [WEAK]
  320.                 EXPORT  SPI3_IRQHandler                   [WEAK]
  321.                 EXPORT  UART4_IRQHandler                  [WEAK]
  322.                 EXPORT  UART5_IRQHandler                  [WEAK]
  323.                 EXPORT  TIM6_DAC_IRQHandler               [WEAK]
  324.                 EXPORT  TIM7_IRQHandler                   [WEAK]
  325.                 EXPORT  DMA2_Stream0_IRQHandler           [WEAK]
  326.                 EXPORT  DMA2_Stream1_IRQHandler           [WEAK]
  327.                 EXPORT  DMA2_Stream2_IRQHandler           [WEAK]
  328.                 EXPORT  DMA2_Stream3_IRQHandler           [WEAK]
  329.                 EXPORT  DMA2_Stream4_IRQHandler           [WEAK]
  330.                 EXPORT  ETH_IRQHandler                    [WEAK]
  331.                 EXPORT  ETH_WKUP_IRQHandler               [WEAK]
  332.                 EXPORT  CAN2_TX_IRQHandler                [WEAK]
  333.                 EXPORT  CAN2_RX0_IRQHandler               [WEAK]
  334.                 EXPORT  CAN2_RX1_IRQHandler               [WEAK]
  335.                 EXPORT  CAN2_SCE_IRQHandler               [WEAK]
  336.                 EXPORT  OTG_FS_IRQHandler                 [WEAK]
  337.                 EXPORT  DMA2_Stream5_IRQHandler           [WEAK]
  338.                 EXPORT  DMA2_Stream6_IRQHandler           [WEAK]
  339.                 EXPORT  DMA2_Stream7_IRQHandler           [WEAK]
  340.                 EXPORT  USART6_IRQHandler                 [WEAK]
  341.                 EXPORT  I2C3_EV_IRQHandler                [WEAK]
  342.                 EXPORT  I2C3_ER_IRQHandler                [WEAK]
  343.                 EXPORT  OTG_HS_EP1_OUT_IRQHandler         [WEAK]
  344.                 EXPORT  OTG_HS_EP1_IN_IRQHandler          [WEAK]
  345.                 EXPORT  OTG_HS_WKUP_IRQHandler            [WEAK]
  346.                 EXPORT  OTG_HS_IRQHandler                 [WEAK]
  347.                 EXPORT  DCMI_IRQHandler                   [WEAK]
  348.                 EXPORT  RNG_IRQHandler                    [WEAK]
  349.                 EXPORT  FPU_IRQHandler                    [WEAK]
  350.
  351. ……………………
  352. …………限于本文篇幅 余下代码请从51黑下载附件…………
STM32启动文件 767.zip (5.61 KB, 下载次数: 8)
