标题: arduino 蓝牙控制RGB LED灯 [打印本页]
作者: 602903230 时间: 2017-12-23 15:21
日期:2017.12.23
功能:arduino 蓝牙控制RGB LED灯
元件:
跳线公公头 * 8
rgbled, 220欧电阻
蓝牙模块
接线:
蓝牙模块VCC,GND分别接5V,GND;TX,RX分别接拓展版的IO0(RX),IO1(TX)口
LED 负极接GND 正极串联电阻接 IO5,IO6,IO7
异常:update 时如果异常信息为:"stk500_recv(): programmer is not responding"
则需要把蓝牙模块拔下来update 完了以后再插上蓝牙即可
int
ledPinGreen =
5
int
ledPinBlue =
6
int
ledPinRed =
7
void
setup() {
pinMode(ledPinGreen, OUTPUT);
pinMode(ledPinBlue, OUTPUT);
pinMode(ledPinRed, OUTPUT);
Serial.begin(
9600
void
loop() {
while
(Serial.available()) {
char
p =
Serial.read();
按下 5 键的事件
if
(p ==
5
rgbLedOn(ledPinRed, ledPinGreen, ledPinBlue);
按下 6 键的事件
if
(p ==
6
rgbLedOn( ledPinGreen, ledPinBlue, ledPinRed);
按下 7 键的事件
if
(p ==
7
rgbLedOn( ledPinBlue, ledPinRed, ledPinGreen);
RGBLED
void
rgbLedOn(
int
onLedPin,
int
offLedPin1,
int
offLedPin2) {
digitalWrite(onLedPin, HIGH);
digitalWrite(offLedPin1, LOW);
digitalWrite(offLedPin2, LOW);
Powered by Discuz! X3.1 |
