STM8红外程序(外中断接收)
liuxin549521
2017-12-29 11:04
STM8红外程序(外中断接收)
STM8红外程序
#include "stm8s.h"
#include "stm8s003f3p.h"
#include "STM8_IR.h"
#include "STM8_DELAY.h"
#define IR_READ (PC_IDR&(0x01<<7))
volatile uchar Flag_ir_start = 0;//启动标志位
volatile uint IR_time = 0;
volatile unsigned long IR_data;
volatile uchar IR_temp[4];
void LED_Init(void)
PA_DDR |= (0x01<<3);//设置PA3为输出
PA_CR1 |= (0x01<<3);//设置PA3为推挽输出,速度为2MHz
PA_CR2 &=(uchar)(~(0x01<<3));
PA_ODR &=(uchar)(~(0x01<<3)); //关闭led
void TIM1_Init(void)
TIM1_CR1 = 0x00; //向上的计数方向,中断计数不停
TIM1_IER = 0x01;
TIM1_PSCRH = 0x00; //进行16分频
TIM1_PSCRL = 0x0f; //16Mhz/(15+1)=1Mhz-->1us
TIM1_ARRH = 0x00;
TIM1_ARRL = 20; //20us
TIM1_CR1 |=0x01;
//外中断接收红外数据
void EXIT_Init(void)
//01是PA,23是PB,45是PC,67是PD引脚
//P?IS[1:0] 设置触发方式,00是下降沿触发
EXTI_CR1 &=(uchar)(~(0x03<<4)); // PC下降沿触发
EXTI_CR1 |= (0x01<<5);
void IR_Init(void)
PC_DDR &=(uchar)(~(0x01<<7));
PC_CR1 &=(uchar)(~(0x01<<7));
//PC_CR1 |= (0x01<<7);//上拉输入
PC_CR2 |= (0x01<<7);//打开外部中断
EXIT_Init();//RISING and falling EDGE
//位反转算法
uchar reverse8( uchar c )
c = ( c & 0x55 ) << 1 | ( c & 0xAA ) >> 1;
c = ( c & 0x33 ) << 2 | ( c & 0xCC ) >> 2;
c = ( c & 0x0F ) << 4 | ( c & 0xF0 ) >> 4;
return c;
void IR_rx(void)
static uchar Flag_end=0;
static uchar IR_num = 0;
uchar i,temp;
//TIM1_CR1 &=(uchar)(~(0x01<<0));//关闭计数器
TIM1_CR1 |= (0x01<<0); //开启计数器
//800us,17000us
if(IR_time<=40)////杂波
IR_data=0;
IR_num=0;
IR_time=0;
return ;
//13000us
if(IR_time >= 650)//13ms则启动成功
Flag_ir_start = 1;
IR_num = 0;
IR_data=0;
if((Flag_ir_start==1)&&(IR_time<=130))//2600us
IR_data<<=1;
if(IR_time>=85)//1700us
IR_data |= (0x01<<0);
IR_num++;
if(IR_num>31)
Flag_end = 1;
Flag_ir_start=0;
IR_time = 0;
if(Flag_end)
Flag_end = 0;
IR_temp[0] = (uchar)((IR_data>>0)&0xff);
IR_temp[1] = (uchar)((IR_data>>8)&0xff);
IR_temp[2] = (uchar)((IR_data>>16)&0xff);
IR_temp[3] = (uchar)((IR_data>>24)&0xff);
IR_data=0;
IR_num=0;
if(IR_temp[0]!=(uchar)(~IR_temp[1]))
//校验失败
//PA_ODR ^= (0x01<<3);
IR_temp[1] = reverse8(IR_temp[1]);//位反转算法
if(IR_temp[1]==0x45)//0xa2
PA_ODR |= (0x01<<3);
if(IR_temp[1]==0x46)
//PA_ODR |= (0x01<<3);
//PA_ODR &=(uchar)(~(0x01<<3));
IR_time = 0;
@far @interrupt void EXTI_PORTC_IRQHandler(void)
IR_rx();
//定时器1溢出中断服务
@far @interrupt void timer1_isr(void) //10us
//TIM1_CR1 &=~(0x01<<0); //关闭计数器
TIM1_SR1 &=~(0x01<<0); //清除中断标志
IR_time++;
//TIM1_CR1 |= (0x01<<0); //开启计数器
//return ;
void IR_rx(void)
//800us,17000us
if(IR_time<=80)////杂波
IR_data=0;
IR_num=0;
IR_time=0;
return ;
//13000us
if(IR_time >= 1300)//13ms则启动成功
Flag_ir_start = 1;
IR_num = 0;
IR_data=0;
if((Flag_ir_start==1)&&(IR_time<=260))//2600us
IR_data<<=1;
if(IR_time>=170)//1700us
IR_num++;
if(IR_num>31)
Flag_end = 1;
Flag_ir_start=0;
if(Flag_end)
Flag_end = 0;
IR_data=0;
IR_num=0;
if(IR_temp[1]==0xa2)
if(IR_temp[1]<0x7f)
IR_time = 0;
TIM1_CR1 |= (0x01<<0);//开计数器
_ooOoo_
o8888888o
88" . "88
(| -_- |)
O\ = /O
____/`---'\____
/ _||||| -:- |||||- \
| \_| ''\---/'' | |
\ .-\__ `-` ___/-. /
___`. .' /--.--\ `. . __
."" '< `.___\_<|>_/___.' >'"".
| | : `- \`.;`\ _ /`;.`/ - ` : | |
\ \ `-. \_ __\ /__ _/ .-` / /
======`-.____`-.___\_____/___.-`____.-'======
佛祖保佑 永无BUG
楠A407舍长出品
#include "stm8s.h"
_Bool Flag_ir = 0;
void STM8_CLK_Init(void)
CLK_HSICmd(ENABLE);//HSI = 16MHz
CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1); //f_psc = 16MHz/1
//--------------------主函数分割线---------------------
void main(void)
unsigned char re ;
unsigned char reg;
_asm("sim");//关全部中断
STM8_CLK_Init();//内部HSI,16MHz
LED_Init();
IR_Init();
TIM1_Init();
_asm("rim");//开全部中断
//IR_test();
STM8_IR_test.rar
(4.02 MB, 下载次数: 79)
2017-12-29 11:03 上传
点击文件名下载附件
下载积分: 黑币 -5
chengfgc
2018-4-26 10:42
学习下,不知道能不能用上
hefeng898961
2018-7-23 08:55
感谢分享
Null520
2019-5-22 15:54
楼主程序不对呀
INIT0
2019-6-1 15:48
Null520 发表于 2019-5-22 15:54
楼主程序不对呀
是不对。。定时器是不是开早了。而且没见到差值或清0 CNTR
zhjf103
2019-7-9 21:58
不错,学习学习!
