标题: 简易电子琴制作 [打印本页]
作者: 纯属巧合 时间: 2017-12-29 16:25
标题: 简易电子琴制作
#include <reg52.h>
#define uchar unsigned char /uchar 无符号字符型 unsigned 无符号的
#define ulong unsigned long
unsigned char i=100;
unsigned char j,k,temp,key;
sbit row1=P2^5; //行端口定义
sbit row2=P2^4;
sbit row3=P2^3;
sbit row4=P2^2;
sbit col1=P1^7; //列端口定义
sbit col2=P1^6;
sbit col3=P2^0;
sbit col4=P2^1;
sbit speak=P3^2;
sbit datacs=P2^6;
sbit chipcs=P2^7;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//共阴数码管显示段码0~9
/*数码管显示函数*/
uchar th0_f; //在中断中装载的 T0 的值高 8 位
uchar tl0_f; //在中断中装载的 T0 的值低 8 位
//T0 的值,及输出频率对照表
uchar code freq[36*2]={
0xA9,0xEF,//00220HZ ,1 //0
0x93,0xF0,//00233HZ ,1#
0x73,0xF1,//00247HZ ,2
0x49,0xF2,//00262HZ ,2#
0x07,0xF3,//00277HZ ,3
0xC8,0xF3,//00294HZ ,4
0x73,0xF4,//00311HZ ,4#
0x1E,0xF5,//00330HZ ,5
0xB6,0xF5,//00349HZ ,5#
0x4C,0xF6,//00370HZ ,6
0xD7,0xF6,//00392HZ ,6#
0x5A,0xF7,//00415HZ ,7
0xD8,0xF7,//00440HZ 1 //12
0x4D,0xF8,//00466HZ 1# //13
0xBD,0xF8,//00494HZ 2 //14
0x24,0xF9,//00523HZ 2# //15
0x87,0xF9,//00554HZ 3 //16
0xE4,0xF9,//00587HZ 4 //17
0x3D,0xFA,//00622HZ 4# //18
0x90,0xFA,//00659HZ 5 //19
0xDE,0xFA,//00698HZ 5# //20
0x29,0xFB,//00740HZ 6 //21
0x6F,0xFB,//00784HZ 6# //22
0xB1,0xFB,//00831HZ 7 //23
0xEF,0xFB,//00880HZ `1
0x2A,0xFC,//00932HZ `1#
0x62,0xFC,//00988HZ `2
0x95,0xFC,//01046HZ `2#
0xC7,0xFC,//01109HZ `3
0xF6,0xFC,//01175HZ `4
0x22,0xFD,//01244HZ `4#
0x4B,0xFD,//01318HZ `5
0x73,0xFD,//01397HZ `5#
0x98,0xFD,//01480HZ `6
0xBB,0xFD,//01568HZ `6#
0xDC,0xFD,//01661HZ `7 //35
unsigned char v,b,n,m;
void delay100ms() //延时函数
Powered by Discuz! X3.1 |
