单片机密码锁
1972224324
2018-1-6 17:50
单片机密码锁
#include <reg51.h>
#include <intrins.h>
sbit DX=P2^0;
sbit WX=P2^1;
sbit red=P2^2;
sbit green=P2^3;
unsigned char flag=0,esc=0;
unsigned char admin[8]={0,1,2,3,4,5,6,7};
unsigned char password[8]={16,16,16,16,16,16,16,16};//存放输入的按键,初始为16,不显示
unsigned char code table[] = {
0x3f,0x06,0x5b,0x4f,0x66,0x6d,
0x7d,0x07,0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0x00};
unsigned char code keycode[]={
0xee,0xde,0xbe,0x7e,
0xed,0xdd,0xbd,0x7d,
0xeb,0xdb,0xbb,0x7b,
0xe7,0xd7,0xb7,0x77
void delay(unsigned int xms)//延时xms 毫秒
unsigned int i,j;
for(i=0;i<=xms;i++)
for(j=0;j<=110;j++);
unsigned char cmpstr(unsigned char p[],unsigned char q[])
unsigned char j=1;
int i;
for(i=7;i>=0;i--)
if(p[i]!=q[i])
j=0;
break;
return j;
unsigned char keyscan()//4*4矩阵按键扫描函数:(要去抖) 扫描哪个键被按下。若有按键按下,返回对应的按键值(0-15),否则返回16
{ unsigned char i=16,hang,temp;//初值设置为16,目的是:没有按键按下时返回16;
//若不设初值(默认值为0) ,没有按键按下时,将返回0,会显示0,误认为0被按下
P1=0x0f;//列输出全0,行输出全1
temp=P1;//读行列输入
if(temp!=0x0f) //若无按键按下,输入仍为0x0f ;若有按键按下对应行输入变为0,其他不变
{ delay(10);//去抖
temp=P1;//再次读行列输入
if(temp!=0x0f)
{ hang=temp^0xf0;
P1=hang;//输出行扫描信号
temp=P1;//读行列输入
for(i=0;i<16;i++)
if(temp==keycode[i])
break;
P1=0x0f;//检测按键是否释放
while((temp=P1)!=0x0f);
return(i);
void display()//数码管动态显示一个字符串(不超过8位)函数*/
unsigned char i;
unsigned char wtemp=0xfe;//位选
unsigned char tag=0;//高位连续0标记
for(i=1;i<=8;i++)
P0=0xff;//位选消影
WX=1;//开位选
P0=wtemp;//送位选
WX=0;//锁存位选
wtemp=_crol_(wtemp,1);//更新位选变量
P0=0x00; //段选消影
DX=1;//开段选
P0=table[password[i-1]]; //送段选
DX=0;//锁存段选
delay(1);
void clear()
unsigned char i;
for(i=0;i<8;i++)
password[i]=16;
display();
//外部中断初始化
EA=1;//总中断允许
EX0=1;//INT0中断允许
IT0=1;//下降沿触发中断
P1=0xf0;//送测试信号,若有按键按下,与门输出0,触发外部中断,否则与门输出1,不会产生外部中断
display(); //显示输入的数据
if(flag==1)
if(cmpstr(password,admin)==1)
green=0;
red=0;
clear();
delay(3000);
flag=0;
green=1;
red=1;
if(esc==1)
clear();
esc=0;
void EX_INT0() interrupt 0
unsigned char i,y;
y=keyscan();
if(y<10)
for(i=0;i<7;i++)
password[i]=password[i+1];//左移
password[7]=y;
if(y==10)
esc=1;
if(y==11)
flag=1;
1972224324
2018-1-6 18:02
代码是对的,大家可以看看
