标题: 单片机课程设计电子时钟程序C [打印本页]
作者: 犬次郎0110    时间: 2018-1-9 09:34
标题: 单片机课程设计电子时钟程序C
#include<reg52.h>
sbit key1=P1^0;
sbit key2=P1^1;
sbit keyup=P1^2;
sbit keydw=P1^3;
sbit beep=P2^3;
sbit lcdrs=P1^4;
sbit lcdrw=P1^5;
sbit lcden=P1^6;
uchar table2[]={"0123456789-"};
int
m1,m2,m3,m4,m5,m6,k,n,p,q,m8,w,a,ri,yue,nian;
void delayms(int j)
int i;
for(j;j>0;j--)
for(i=125;i>0;i--);
// LCD写地址
void writecom(uchar com)
lcden=0;
lcdrs=0;
lcdrw=0;
delayms(1);
lcden=1;
delayms(1);
P0=com;
delayms(1);
lcden=0;
//LCD写数据
void writedata(uchar dat)
lcden=0;
lcdrs=1;
lcdrw=0;
delayms(1);
lcden=1;
delayms(1);
P0=dat;
delayms(1);
lcden=0;
// LCD初始化
void LCD_Init()
delayms(15);
writecom(0x38);
delayms(5);
writecom(0x38);
delayms(5);
writecom(0x38);
writecom(0x38);
writecom(0x08);
writecom(0x01);
writecom(0x06);
writecom(0x0c);
void beepinit(void)
beep=0;
delayms(100);
beep=1;
void beep2()
beep=0;
delayms(500);
beep=1;
void display()
writecom(0x80+0x02);
writedata(table2[nian/1000]);
writedata(table2[nian%1000/100]);
writedata(table2[nian%100/10]);
writedata(table2[nian%10]);
writedata(table2[10]);
writedata(table2[yue/10]);
writedata(table2[yue%10]);
writedata(table2[ri/10]);
writedata(table2[ri%10]);
writecom(0x80+0x40);
writedata(table2[m1/10]);
writedata(table2[m1%10]);
writedata(table2[m2/10]);
writedata(table2[m2%10]);
writedata(table2[m3/10]);
writedata(table2[m3%10]);
writecom(0x80+0x48);
writedata(table2[m4/10]);
writedata(table2[m4%10]);
writedata(table2[m5/10]);
writedata(table2[m5%10]);
writedata(table2[m6/10]);
writedata(table2[m6%10]);
if(k>=20)
  k=0;
  m3++;
  m8++;
if(m3>=60)
  m3=m3-60;
  m2++;
if(m2>=60)
  m2=m2-60;
  m1++;
if(m1>=24)
  m1=m1-24;
  ri++;
switch(yue)
  case 1:
  case 3:
  case 5:
  case 7:
  case 8:
  case 10:
  case 12:
   if(ri>=32)
    yue++;
    ri=ri-31;
   break;
  case 4:
  case 6:
  case 9:
  case 11:
   if(ri>=31)
    yue++;
    ri=ri-30;
   break;
  case 2:
  if((nian%100==0&nian%400==0)||(nian%100!=0&nian%4==0))
   if(ri>=29)
    yue++;
    ri=ri-28;
   if(ri>=30)
    yue++;
    ri=ri-29;
   break;
  default:
   yue=1;
   break;
   if(m6>=60)
    m6=m6-60;
    m5++;
   if(m5>=60)
    m5=m5-60;
    m4++;
   if(m4>=24)
    m4=m4-24;
//上调时钟
void keyupinit()
if(p==1) //时间上调
  if(!keyup)
   delayms(1);
   if(!keyup)
    switch(n)
     case 1: m3=m3+1;
break;
     case 2: m3=m3+10;
break;
     case 3: m2=m2+1;
break;
     case 4: m2=m2+10;
break;
     case 5: m1=m1+1;
break;
     case 6: m1=m1+10;
break;
     case 7: ri=ri+1;
break;
     case 8: ri=ri+10;
break;
     case 9: yue=yue+1;
break;
     case 10: yue=yue+10;
break;
     case 11: nian=nian+1;
break;
     case 12: nian=nian+10;
break;
     case 13: nian=nian+100;
break;
     case 14: nian=nian+1000;
break;
    beepinit();
    while(!keyup);
if(p==2) // 闹钟上调
if(!keyup)
{ delayms(1);
if(!keyup)
   switch(n)
    case 1: m6=m6+1;
    break;
    case 2: m6=m6+10;
    break;
    case 3: m5=m5+1;
    break;
    case 4: m5=m5+10;
    break;
    case 5: m4=m4+1;
    break;
    case 6: m4=m4+10;
    break;
    beepinit();
   while(!keyup);
//下调时钟
void keydwinit()
if(p==1) // 时间下调
  if(!keydw)
   delayms(1);
   if(!keydw)
    switch(n)
     case 1: m3=m3-1;
     break;
     case 2: m3=m3-10;
     break;
     case 3: m2=m2-1;
     break;
     case 4: m2=m2-10;
     break;
     case 5: m1=m1-1;
     break;
     case 6: m1=m1-10;
     break;
     case 7: ri=ri-1;
     break;
     case 8: ri=ri-10;
     break;
     case 9: yue=yue-1;
     break;
     case 10: yue=yue-10;
     break;
     case 11: nian=nian-1;
     break;
     case 12: nian=nian-10;
     break;
     case 13: nian=nian-100;
     break;
     case 14: nian=nian-1000;
     break;
    beepinit();
    while(!keydw);
if(p==2) // 闹钟下调
if(!keydw)
  delayms(1);
  if(!keydw)
   switch(n)
    case 1: m6=m6-1;
    break;
    case 2: m6=m6-10;
    break;
    case 3: m5=m5-1;
    break;
    case 4: m5=m5-10;
    break;
    case 5: m4=m4-1;
    break;
    case 6: m4=m4-10;
    break;
    beepinit();
   while(!keydw);
//选择位数
//p:模式选择
void xuanze()
n=1;
p=1;
while(p==1) //时间模式
  if(!key2)
   delayms(5);
   beepinit();
   while(!key2);
   n=n+1;
  if(n==15)n=1;
  keyupinit();
  keydwinit();
  if(m1<0) m1=m1+24;
  if(m2<0) m2=m2+60;
  if(m3<0) m3=m3+60;
  display();
  if(!key1)
   delayms(2);
   beepinit();
   while(!key1);
   p=2;
delayms(1);
n=1;
while(p==2) //闹钟模式
  if(!key2)
   delayms(5);
   beepinit();
   while(!key2);
   n=n+1;
   if(n==7)n=1;
   keyupinit();
   keydwinit();
   if(m4<0) m4=m4+24;
   if(m5<0) m5=m5+60;
   if(m6<0) m6=m6+60;
   display();
   if(!key1)
    delayms(2);
    beepinit();
    while(!key1);
    p=3;
//选择模式
void key1init()
TR0=0;
xuanze();
delayms(5);
if(p==3)
  TR0=1;
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1; //总开关
ET0=1; //定时器t0中断允许
TR0=1; //开启定时器
m1=m2=m3=q=m4=m5=m6=0;
nian=2014;
yue=01;
ri=01;
LCD_Init();
display();
  if(!key1)
   delayms(2);
   beepinit();
   while(!key1);
   key1init();
   delayms(3);
  if((m4==0)&&(m5==0)&&(m6==0)) // 初始值不计闹钟
    w=0;
   else w=1;
   if((m1==m4)&&(m2==m5)&&(m3==m6)&&w) //判断闹钟
     q=1;
     m8=0;
    if(q==1)
     if(m8<=30)
       beep2();
      q=0;
    display();
  void timer0() interrupt 1
   k++;
END
