求助,电机角度测量
Ryannnnn
2018-1-10 09:38
求助,电机角度测量
利用单片机控制伺服电机转动并测量转动角度,原理图和程序
我尼玛
2018-5-14 16:19
#include "reg52.h"
int delay();
void inti_lcd();
void show_lcd(int);
void cmd_wr();
void ShowState();
void clock(unsigned int Delay) ;
void DoSpeed(); //¼ÆËãËù¶è
//Õy×aÖμ
#define RIGHT_RUN 1
//·′×aÖμ
#define LEFT_RUN 0
sbit RS=0xA0;
sbit RW=0xA1;
sbit E=0xA2;
char SpeedChar[]="SPEED(n/min):";
char StateChar[]="RUN STATE:";
char STATE_CW[]="CW";
char STATE_CCW[]="CCW";
char SPEED[3]="050";
unsigned int RunSpeed=50; //Ëù¶è
unsigned char RunState=RIGHT_RUN; //ÔËDD×′ì¬
main()
/*¶¨ê±Æ÷éèÖÃ*/
TMOD=0x66; //¶¨ê±Æ÷0£¬1¶¼Îa¼Æêy·½ê½£»·½ê½2£»
EA=1; //¿aÖD¶Ï
TH0=0xff; //¶¨ê±Æ÷03õÖμFFH£»
TL0=0xff;
ET0=1;
TR0=1;
TH1=0xff; //¶¨ê±Æ÷13õÖμFFH£»
TL1=0xff;
ET1=1;
TR1=1;
IT0=1; //Âö3å·½ê½
EX0=1; //¿aía2¿ÖD¶Ï0:¼óËù
IT1=1; //Âö3å·½ê½
EX1=1; //¿aía2¿ÖD¶Ï1:¼õËù
inti_lcd();
DoSpeed();
ShowState();
clock(RunSpeed);
P0=0x01;
//¶¨ê±Æ÷0ÖD¶Ï3ìDò:Õy×a
void t_0(void) interrupt 1
RunState=RIGHT_RUN;
P0=1;
P1=0x01;
cmd_wr();
ShowState();
//¶¨ê±Æ÷1ÖD¶Ï:·′×a
void t_1(void) interrupt 3
RunState=LEFT_RUN;
P0=0;
P1=0x01;
cmd_wr();
ShowState();
//ÖD¶Ï0:¼óËù3ìDò
void SpeedUp() interrupt 0
if(RunSpeed>=12)
RunSpeed=RunSpeed-2;
DoSpeed();
P1=0x01;
cmd_wr();
ShowState();
//ÖD¶Ï1:¼õËù3ìDò
void SpeedDowm() interrupt 2
if(RunSpeed<=100)
RunSpeed=RunSpeed+2;
DoSpeed();
P1=0x01;
cmd_wr();
ShowState();
int delay() //ÅD¶ÏLCDêÇ·ñÃ|
int a;
start:
RS=0;
RW=1;
E=0;
for(a=0;a<2;a++);
E=1;
P1=0xff;
if(P1^7==0)
return 0;
goto start;
void inti_lcd() //éèÖÃLCD·½ê½
P1=0x38;
cmd_wr();
delay();
P1=0x01; //Çå3y
cmd_wr();
delay();
P1=0x0f;
cmd_wr();
delay();
P1=0x06;
cmd_wr();
delay();
P1=0x0c;
cmd_wr();
delay();
void cmd_wr() //D′¿ØÖÆ×Ö
RS=0;
RW=0;
E=0;
E=1;
void show_lcd(int i) //LCDÏÔê¾×ó3ìDò
P1=i;
RS=1;
RW=0;
E=0;
E=1;
void ShowState() //ÏÔê¾×′ì¬óëËù¶è
int i=0;
while(SpeedChar[i]!='\0')
delay();
show_lcd(SpeedChar[i]);
i++;
delay();
P1=0x80 | 0x0d;
cmd_wr();
i=0;
while(SPEED[i]!='\0')
delay();
show_lcd(SPEED[i]);
i++;
delay();
P1=0xC0;
cmd_wr();
i=0;
while(StateChar[i]!='\0')
delay();
show_lcd(StateChar[i]);
i++;
delay();
P1=0xC0 | 0x0A;
cmd_wr();
i=0;
if(RunState==RIGHT_RUN)
while(STATE_CW[i]!='\0')
delay();
show_lcd(STATE_CW[i]);
i++;
while(STATE_CCW[i]!='\0')
delay();
show_lcd(STATE_CCW[i]);
i++;
void clock(unsigned int Delay) //1msÑóê±3ìDò
{ unsigned int i;
for(;Delay>0;Delay--)
for(i=0;i<124;i++);
void DoSpeed()
SPEED[0]=(1000*6/RunSpeed/100)+48;
SPEED[1]=1000*6/RunSpeed%100/10+48;
SPEED[2]=1000*6/RunSpeed%10+48;
这是程序
我尼玛
2018-5-14 16:22
#include "reg52.h"
int delay();
void inti_lcd();
void show_lcd(int);
void cmd_wr();
void ShowState();
//Õy×aÖμ
#define RIGHT_RUN 1
//·′×aÖμ
#define LEFT_RUN 0
sbit RS=0xA0;
sbit RW=0xA1;
sbit E=0xA2;
main()
/*¶¨ê±Æ÷éèÖÃ*/
EA=1; //¿aÖD¶Ï
TL0=0xff;
ET0=1;
TR0=1;
TL1=0xff;
ET1=1;
TR1=1;
IT0=1; //Âö3å·½ê½
IT1=1; //Âö3å·½ê½
inti_lcd();
DoSpeed();
ShowState();
clock(RunSpeed);
P0=0x01;
RunState=RIGHT_RUN;
P0=1;
P1=0x01;
cmd_wr();
ShowState();
//¶¨ê±Æ÷1ÖD¶Ï:·′×a
RunState=LEFT_RUN;
P0=0;
P1=0x01;
cmd_wr();
ShowState();
//ÖD¶Ï0:¼óËù3ìDò
if(RunSpeed>=12)
DoSpeed();
P1=0x01;
cmd_wr();
ShowState();
//ÖD¶Ï1:¼õËù3ìDò
if(RunSpeed<=100)
DoSpeed();
P1=0x01;
cmd_wr();
ShowState();
int a;
start:
RS=0;
RW=1;
E=0;
for(a=0;a<2;a++);
E=1;
P1=0xff;
if(P1^7==0)
return 0;
goto start;
P1=0x38;
cmd_wr();
delay();
P1=0x01; //Çå3y
cmd_wr();
delay();
P1=0x0f;
cmd_wr();
delay();
P1=0x06;
cmd_wr();
delay();
P1=0x0c;
cmd_wr();
delay();
RS=0;
RW=0;
E=0;
E=1;
P1=i;
RS=1;
RW=0;
E=0;
E=1;
int i=0;
delay();
i++;
delay();
P1=0x80 | 0x0d;
cmd_wr();
i=0;
delay();
show_lcd(SPEED[i]);
i++;
delay();
P1=0xC0;
cmd_wr();
i=0;
delay();
i++;
delay();
P1=0xC0 | 0x0A;
cmd_wr();
i=0;
delay();
i++;
delay();
i++;
{ unsigned int i;
for(i=0;i<124;i++);
void DoSpeed()
忘了说了,这个是控制转速的
