STM32F407+LWIP+OV2640摄像头+DCMI+SRAM源码
cchit001
2018-1-11 22:15
采用STM407实现摄像头OV2640获取图片数据,通过TCP网络上传显示。图片最大分辨率1600*1200,这个分辨率下大概能实现每秒1~2帧左右的传输,速度还可以.原始工程文件,配合BOOTLOAD应用,如果不用BOOTLOAD,可以修改起始地址,直接下载应用。
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/** @addtogroup Template_Project
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
extern void vTestUartSend(void);
extern void LwIP_Periodic_Handle(__IO uint32_t localtime);
u32 u32_mark_debug = 0;
extern __IO uint32_t LocalTime;
extern unsigned char gu8NetRecMark;
extern void fudp_init(void);
extern void LwIP_Init(void);
extern void vDcmiDataInit(void);
extern void frame_deal(void);
extern void vDcmi_Set_Start(void);
extern void init_sysparameter_set(void);
extern void vNetTimeTask(void);
//extern static void SystemInit_ExtMemCtl(void);
/* Private functions ---------------------------------------------------------*/
* @brief Main program
* @param None
* @retval None
int main(void)
System_Setup();
init_sysparameter_set();
while(OV2640_Init())
Delay(200);
LwIP_Init();
fudp_init();
//vDcmiDataInit();
/* Infinite loop */
//vDcmi_Set_Start();//STM32F40_41xxx1
//SystemInit_ExtMemCtl();
while (1)
vPictureEndDeal();
vCmdUartDeal();
Led_Status_Handle();
vNetTimeTask();
frame_deal();
LwIP_Periodic_Handle(LocalTime);
* @brief Inserts a delay time.
* @param nTime: specifies the delay time length, in milliseconds.
* @retval None
void Delay(uint32_t nTime)
uint32_t u32TimePara = LocalTime + nTime;
while(u32TimePara>LocalTime);
void Led_Status_Handle(void)
u32_mark_debug++;
if((u32_mark_debug>1000000)&&(u32_mark_debug<2000000))
GPIO_SetBits(GPIOB,GPIO_Pin_12);//
GPIO_ResetBits(GPIOB,GPIO_Pin_13);//
u32_mark_debug = 3000000;
//delay_us(500);
//vTestUartSend();
else if((u32_mark_debug>4000000)&&(u32_mark_debug<5000000)){
GPIO_SetBits(GPIOB,GPIO_Pin_13);//复位结束
GPIO_ResetBits(GPIOB,GPIO_Pin_12);//
u32_mark_debug = 0;
/* Write the descriptor through the endpoint */
//USB_SIL_Write(EP1_IN, (uint8_t*) u8_lin, 2);
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
LIWP DCMI.rar
(12.04 MB, 下载次数: 166)
2018-1-11 22:15 上传
点击文件名下载附件
下载积分: 黑币 -5
lzts88
2018-7-7 15:31
谢谢分享,下载备用
easyming
2019-1-26 14:14
赞,下载学习一下!!!
yb1988001
2019-1-27 10:52
解压不了
ljw22676739
2019-3-3 00:44
根本就没使用到SRAM
jinniuxing88888
2020-5-28 09:13
谢谢分享!
hei8888
2020-11-4 14:30
用到内部SRAM?
xikree
2023-10-16 09:06
我用的udp,刚好可以参考下
王向来
2023-10-16 09:58
代码清楚
