fc手柄控制的12864贪吃蛇源码
123份饭
2018-2-25 20:20
fc手柄控制的12864贪吃蛇源码
一套基于C51的12864贪吃蛇程序
(106.46 KB, 下载次数: 50)
下载附件
截图
2018-2-25 20:18 上传
贪食蛇程序
2016年10月6日20:02:37
#include "reg52.h"
#include "lcd12864.h"
#include "FC.H"
#include "stdlib.h"
#define snake_UP 0x01
#define snake_DOWN 0xfe
#define snake_LEFT 0x02
#define snake_RIGHT 0xfd
#define snakeInitLength 2
#define snakeInitSideX 70
#define snakeInitSideY 30
#define snakeInitDir snake_RIGHT
#define arraysize 100
#define LEFT_X 63
#define TOP_Y 0
#define RIGHT_X 127
#define BOTTOM_Y 63
unsigned char xdata stepArray[arraysize]={0};
unsigned char xdata dirArray[arraysize]={0};
unsigned char front_array,tail_array;//存放头尾数据的数组编号
unsigned char front_dir,tail_dir;//头尾移动的方向
unsigned char frontdat,taildat; //头尾的段数
char tail_x,tail_y,front_x,front_y;//头尾的坐标
unsigned char food_x,food_y;//食物坐标
unsigned int score=0;
unsigned int time_speed;
unsigned char scoreString[5]={0};
unsigned char flag_food=0,flag_skip=0;
unsigned int speed = 1;
unsigned char power = 1;
void toString(unsigned char* str) //将分数转换为ask码的形式
str[0] = score/1000+0x30;
str[1] = score%1000/100+0x30;
str[2] = score%100/10+0x30;
str[3] = score%10+0x30;
//生成食物
void CreateFood()
do
food_x = rand ()%LEFT_X+LEFT_X+1;
food_y = rand ()%(BOTTOM_Y-1);
}while(LCD12864_Readpoint(food_x,food_y)); //读点是为了让食物的点在蛇身之外
power = rand()%2+1;
time_speed = (250-speed*10)/power;
LCD12864_Drawpoint(food_x,food_y,DISPLAY); //将点在12864显示出来
//画界面
void drawGUI()
unsigned char i=0;
LCD12864_String(0,0," ");
LCD12864_String(0,1," ");
LCD12864_String(0,2," ");
LCD12864_String(0,3," ");
toString(scoreString);
LCD12864_String(0,0,"分数: ");
LCD12864_String(0,1,scoreString);
LCD12864_String(0,2,"称号: ");
LCD12864_String(0,3,"小虾米 ");
for(i=LEFT_X;i<RIGHT_X;i++) //画上下边框
LCD12864_Drawpoint(i,TOP_Y,DISPLAY);
LCD12864_Drawpoint(i,BOTTOM_Y,DISPLAY);
for(i=0;i<BOTTOM_Y;i++) //画左右边框
LCD12864_Drawpoint(LEFT_X,i,DISPLAY);
LCD12864_Drawpoint(RIGHT_X,i,DISPLAY);
//画蛇
for(i=0;i<snakeInitLength;i++)
LCD12864_Drawpoint(i+snakeInitSideX,snakeInitSideY,DISPLAY);
//食物
do
//power = rand()%2+1;
time_speed = (250-speed*10);
//初始化
void Snake_Init()
score = 0;
flag_food=0;
flag_skip=0;
speed = 1;
power = 1;
front_x = snakeInitSideX + snakeInitLength - 1;
front_y = snakeInitSideY;
tail_x = snakeInitSideX;
tail_y = snakeInitSideY;
stepArray[0] = snakeInitLength;
dirArray[0] = snakeInitDir;
tail_array = front_array = 0;
front_dir = dirArray[0];
tail_dir = dirArray[0];
frontdat = stepArray[0];
taildat = stepArray[0];
drawGUI();
//游戏结束界面
void GAMEOVER()
LCD12864_clearGDR();
LCD12864_String(0,0," GAME OVER ");
LCD12864_String(0,1," SCROE: ");
LCD12864_String(5,1,scoreString);
LCD12864_String(0,2," START ");
if(FC_ReadDATA() == FC_START) break;
Snake_Init();
//称号获得
void LEVEL_Name()
switch (score)
case 0 : LCD12864_String(0,3,"小虾米 ");speed =1;
break;
case 4 : LCD12864_String(0,3,"大虾米 ");speed =2;
break;
case 8 : LCD12864_String(0,3,"大豆虫 ");speed =3;
break;
case 12: LCD12864_String(0,3,"小青蛇 ");speed =4;
break;
case 20: LCD12864_String(0,3,"青蛇 ");speed =5;
break;
case 40: LCD12864_String(0,3,"白蛇精 ");speed =6;
break;
case 80: LCD12864_String(0,3,"白素贞 ");speed =7;
break;
case 160:LCD12864_String(0,3,"蛇界食神");speed =8;
break;
case 320 : LCD12864_String(0,3,"小白龙 ");speed =9;
break;
case 640:LCD12864_String(0,3,"逆天白龙 ");speed =10;
break;
case 1000:LCD12864_String(0,3,"通天神龙");speed =11;
break;
default:
break;
//画出贪食蛇
void drawSnake(unsigned char* stepArray,unsigned char* dirArray)
switch (front_dir)
case snake_UP : front_y--;if(front_y<(TOP_Y+1))front_y = (BOTTOM_Y-1);
break;
case snake_DOWN : front_y++;if(front_y>(BOTTOM_Y-1))front_y = (TOP_Y+1);
break;
case snake_LEFT : front_x--;if(front_x< (LEFT_X+1))front_x = (RIGHT_X-1);
break;
case snake_RIGHT: front_x++;if(front_x>(RIGHT_X-1))front_x = (LEFT_X+1);
break;
default:
break;
frontdat = stepArray[front_array];
frontdat++;
frontdat = frontdat%128;
stepArray[front_array] = frontdat;
//判断是食物还是自己身体
if(LCD12864_Readpoint(front_x,front_y)) //判断前进方向上有无点
//判断是否为食物
if((front_x==food_x)&&(front_y==food_y))
flag_food = 1;
score++;
LEVEL_Name();
flag_food = 0;
GAMEOVER();
//画头
LCD12864_Drawpoint(front_x,front_y,DISPLAY);
//消尾
if(flag_skip == 0)
LCD12864_Drawpoint(tail_x,tail_y,NOTDISPLAY);
taildat = stepArray[tail_array];
taildat--;
if(taildat == 0)
tail_array++;
tail_array %= arraysize;
//重新获取尾巴的段数和方向
tail_dir = dirArray[tail_array];
stepArray[tail_array] = taildat;
switch (tail_dir)
case snake_UP : tail_y--;if(tail_y<(TOP_Y+1))tail_y = (BOTTOM_Y-1);
break;
case snake_DOWN : tail_y++;if(tail_y>(BOTTOM_Y-1))tail_y = (TOP_Y+1);
break;
case snake_LEFT : tail_x--;if(tail_x<(LEFT_X+1))tail_x = (RIGHT_X-1);
break;
case snake_RIGHT: tail_x++;if(tail_x>(RIGHT_X-1))tail_x = (LEFT_X+1);
break;
if(flag_food==1)
//判断前面是食物
flag_food = 0;
flag_skip = 1;
CreateFood();
}else flag_skip = 0;
//FC手柄扫描
unsigned char FC_scan()
unsigned char dat;
dat = FC_ReadDATA();
if(dat != 0xff)
if((dat&~FC_UP) ==0) return snake_UP;
if((dat&~FC_DOWN)==0) return snake_DOWN;
if((dat&~FC_LEFT)==0) return snake_LEFT;
if((dat&~FC_RIGHT)==0) return snake_RIGHT;
return 0;
//手柄数据处理函数
void MakeFCscan(unsigned char* stepArray,unsigned char* dirArray)
unsigned char fcdat;
fcdat = FC_scan();
//手柄有方向
if(fcdat != 0)
//方向不与头的行进方向反向或相同
if((fcdat != ~front_dir) && (fcdat != front_dir))
…………限于本文篇幅 余下代码请从51黑下载附件…………
贪食蛇 2.0.zip
(68.71 KB, 下载次数: 20)
2018-2-25 20:14 上传
点击文件名下载附件
下载积分: 黑币 -5
