STM32 fats0.13a SDIO移植成功代码
IdeaMing
2018-3-2 09:36
根据论坛的帖子
http://www.51hei.com/bbs/dpj-88507-1.html
自己移植了最新版FATS 0.13a
测试成功,可以读写文件,追加文件。
部分代码如下
void SD_ReadTest(void)
unsigned int offset = 0;
disk_initialize(DEV_MMC);
res = f_mount(&fs,"1:",0); // 挂载
res = f_open(&fsrc,"1:/KILLL.BAT",FA_OPEN_EXISTING | FA_READ); // 打开文件
if(res != FR_OK)
printf("%d ",res);
printf("open error\r\n");
file_size = f_size(&fsrc);
printf("filesize:%d\r\n",file_size);
do{
res = f_lseek(&fsrc,offset); // 指针往后推128
res = f_read(&fsrc,buffer,sizeof(buffer),&br);
if(res == FR_OK)
USART1_SendBuf(buffer,br);
printf("\r\n");
printf("read fils err\r\n");
offset += 128;
file_size -= 128;
}while(file_size>128);
if(file_size>0)
res = f_read(&fsrc,buffer,file_size,&br);
if(res == FR_OK)
printf("EndOfFile\r\n");
f_close(&fsrc);// 关闭文件
f_mount(NULL,"1:",0); //卸载磁盘
获取文件长度并串口输出文件内容,适用于读取bin文件做系统软件升级IAP.
FRESULT open_append (
FIL* fp, /* [OUT] File object to create */
const char* path /* [IN] File name to be opened */
FRESULT fr;
/* Opens an existing file. If not exist, creates a new file. */
fr = f_open(fp, path, FA_WRITE | FA_OPEN_ALWAYS);
if (fr == FR_OK) {
/* Seek to end of the file to append data */
fr = f_lseek(fp, f_size(fp));
if (fr != FR_OK)
f_close(fp);
return fr;
void SD_WriteTest(void)
unsigned char write_f[20]={"ming write file test"};
disk_initialize(0);
res = open_append(&fdst,"1:/testa.txt");
// res = f_open(&fdst, "1:/testa.txt", FA_CREATE_ALWAYS | FA_WRITE);
if(res != FR_OK)
f_printf(&fdst, "%d\n", runtime);
//res = f_write(&fdst,write_f,sizeof(write_f),&bw);
//res = f_puts("hello",&fdst);
if(res <0)
printf("write err! %d\r\n",res);
printf("write ok! %d\r\n",res);
f_close(&fdst);
f_mount(NULL,"1:",0);// 卸载
printf("write test passed! \r\n");
文件内容追加,适合保存日志log
void ReadSDFile(void)
// FIL file;
FILINFO finfo;
DIR dirs;
int i_name=0;
// char *fn;
f_mount(&fs,"1:",1);
res = f_opendir(&dirs, "1:/");
if (res == FR_OK)
while (f_readdir(&dirs, &finfo) == FR_OK)
if (finfo.fattrib & AM_ARC)
if(!finfo.fname[0]) break; //文件名不为空,如果为空,则表明该目录下面的文件已经读完了
stringcopy(buff_filename[i_name], (BYTE*)finfo.fname);
i_name++;
file_cnt = i_name;
f_close(&fsrc);
i_name = 0;
do{
//USART1_SendBuf(buff_filename[i_name],br);
printf("%s\r\n",buff_filename[i_name]);
i_name++;
file_cnt--;
}while(file_cnt);
f_mount(NULL,"1:",1);
获取文件列表。
STM32_SDIO_FAT13.zip
(1.44 MB, 下载次数: 39)
2018-3-2 09:35 上传
点击文件名下载附件
下载积分: 黑币 -5
如果需要解压密码,请双击压缩包或右键压缩包查看注释。
Oxygen_
2021-4-25 22:57
这个是单线的SDIO,且是MMC卡,如果是4线,8线SDIO,DMA操作,SD卡都需要自行修改
