标题: 为什么液晶处没有显示 [打印本页]
作者: july0    时间: 2018-3-5 21:26
标题: 为什么液晶处没有显示
这是仅仅有一小部分功能的计算器程序,但液晶去没反应;求各位指出问题;
  #include<reg52.h>
sbit rs=P2^6;
sbit wr=P2^5;
sbit len=P2^7;
uchar annum,num,date;
uchar dis[16];
void delay(uint z)
        uint x,y;
        for(x=z;z>0;x--)
                for(y=110;y>0;y--);
void  write_com(uchar com)
        rs=0;
        P0=com;
        delay(5);
        len=1;
        delay(5);
        len=0;
void write_date(uchar date)
        rs=1;
        P0=date;
        delay(5);
        len=1;
        delay(5);
        len=0;
void keyscan()
        uchar temp,key;
        P3=0xfe;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(10);
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                         temp=P3;
                        switch(temp)
                                case 0xee:
                                num=0;
                                break;
                                annum++;
                                case 0xde:
                                num=1;
                                annum++;
                                break;
                                case 0xbe:
                                num=2;
                                annum++;
                                break;
                                case 0x7e:
                                num=3;
                                annum++;
                                break;
                        while(temp!=0xf0);
                                P3=temp;
                                temp=temp&0xf0;
        P3=0xfd;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(5);
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xed:
                                num=4;
                                annum++;
                                break;
                                case 0xdd:
                                num=5;
                                annum++;
                                break;
                                case 0xbd:
                                num=6;
                                annum++;
                                break;
                                case 0x7d:
                                num=7;
                                annum++;
                                break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp=temp&0xf0;
        P3=0xfb;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(10);
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xeb:
                                num=8;
                                annum++;
                                break;
                                case 0xdb:
                                num=9;
                                annum++;
                                break;
                                case 0xbb:
                                num=10;
                                break;
                                case 0x7b:
                                num=11;
                                break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp=temp&0xf0;
        P3=0xf7;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(10);
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        temp=P3;
                        switch(temp)
                                case 0xe7:
                                num=12;
                                break;
                                case 0xd7:
                                num=13;
                                case 0xb7:
                                num=14;
                                break;
                                case 0x77:
                                num=15;
                                break;
                        while(temp!=0xf0)
                                temp=P3;
                                temp&0xf0;
uchar keysuan(uchar date)
          if(num==0)
                date=date+(num*annum*10);
        if(num==1)
        if(num==2)
        if(num==3)
        if(num==4)
        if(num==4)
        if(num==5)
        if(num==6)
        if(num==7)
        if(num==8)
        if(num==9)
                {date=date+(num*annum*10);}
                return date;
void jisuan()
        write_com(0x80+0x40+16);
        dis[0]=date%10+0x30;
        dis[1]=date/10%10+0x30;
        dis[2]=date/100%10+0x30;
        dis[3]=date/1000%10+0x30;
        dis[4]=date/10000%10+0x30;
        dis[5]=date/100000%10+0x30;
        dis[6]=date/1000000%10+0x30;
        dis[7]=date/10000000%10+0x30;
        dis[8]=date/100000000%10+0x30;
        dis[9]=date/1000000000%10+0x30;
        dis[10]=date/10000000000%10+0x30;
void display()
  uchar i=0;
        write_com(0x80+0x50);
        while(dis[i]!='\0')
                write_date(dis[i]);
                i++;
        i=0;
void init()
    date=0;
        wr=0;
        write_com(0x38);
        write_com(0x0f);
        write_com(0x04);
        write_com(0x01);
        init();
          keyscan();
          keysuan();
          jisuan();
          display();
作者: wayne0830    时间: 2018-3-6 15:12
我是进来学习的。
作者: 小狗吃大白菜    时间: 2018-3-6 22:00
你看看清屏代码对了没!
作者: july0    时间: 2018-3-7 08:24
小狗吃大白菜 发表于 2018-3-6 22:00
你看看清屏代码对了没!
没有,0x01是清屏指令
作者: july0    时间: 2018-3-7 13:46
哪位大神指导一下
作者: fhx9999    时间: 2018-3-7 14:22
好像是你的
sbit wr=P2^5;
没在使用,是不是时序不对?
作者: 844574875    时间: 2018-3-7 15:07
检查一下液晶的连线是否正确。
作者: beha    时间: 2018-3-7 15:33
程序有错误吗
作者: july0    时间: 2018-3-8 09:31
fhx9999 发表于 2018-3-7 14:22
好像是你的
sbit wr=P2^5;
没在使用,是不是时序不对?
因为只是写所以这个口一直是设为低电平
844574875 发表于 2018-3-7 15:07
检查一下液晶的连线是否正确。
是正确的应该是程序有问题
作者: july0    时间: 2018-3-8 09:32
beha 发表于 2018-3-7 15:33
程序有错误吗
我还没看出哪错了
作者: july0    时间: 2018-3-8 09:33
好像是你的
sbit wr=P2^5;
没在使用,是不是时序不对?
时序没问题
作者: wulin    时间: 2018-3-8 15:50
你原来的程序根本不能通过编辑,修改错误后得到的结果如下,这就是你想要的显示效果?
改后的程序:
#include<reg52.h>
sbit rs=P2^6;
sbit wr=P2^5;
sbit len=P2^7;
uchar dis[16];
/*******100us延时程序********/
void delay(uint x)
        uint a,b;
        for(a=x;a>0;a--)
                for(b=10;b>0;b--);
/*******1ms延时程序********/
void delay(uint z)
        uint x,y;
        for(x=z;z>0;x--)
                for(y=110;y>0;y--);
/*******液晶写指令程序**********/
        len=0;
        rs=0;
        P0=com;
        delay(10);
        len=1;
        delay(10);
        len=0;
/*******液晶写数据程序********/
        rs=1;
        P0=date;
        delay(10);
        len=1;
        delay(10);
        len=0;
/*******液晶初始化程序********/
void init()
        date=0;
        wr=0;
        write_com(0x38);
        write_com(0x01);
//        write_com(0x0c);
//        write_com(0x06);
        write_com(0x0f);
        write_com(0x04);
        write_com(0x80);
void keyscan()                                        //按键扫描程序
        static bit sign=0;                        //按键有效标志
        static uint count=0;                //消抖计数变量
        uchar num0=0;                                //临时变量
        P3=0xf0;                                        //赋值P3 1111 0000
        if(P3!=0xf0)                                //检测有按键按下
                count++;                                //消抖计数
                if((count>=500)&&(sign==0))//100~1000,根据主循环周期调整约10~20ms
                        sign=1;                                //按键有效标志置1,防止重复响应
                        num0=P3;                                //保存P3值xxxx 0000,x为0或1
                        num0|=0x0f;                        //保存num按位或0x0f值xxxx 1111
                        P3=num0;                                //赋值P3 xxxx 1111
                        num0=P3;                                //保存P3值xxxx xxxx
                        switch(num0)
                                case 0xee: num= 0;annum++; break;
                                case 0xde: num= 1;annum++; break;
                                case 0xbe: num= 2;annum++; break;
                                case 0x7e: num= 3;annum++; break;
                                case 0xed: num= 4;annum++; break;
                                case 0xdd: num= 5;annum++; break;
                                case 0xbd: num= 6;annum++; break;
                                case 0x7d: num= 7;annum++; break;
                                case 0xeb: num= 8;annum++; break;
                                case 0xdb: num= 9;annum++; break;
                                case 0xbb: num=10; break;
                                case 0x7b: num=11; break;
                                case 0xe7: num=12; break;
                                case 0xd7: num=13; break;
                                case 0xb7: num=14; break;
                                case 0x77: num=15; break;
        else                                                //键抬起
                sign=0;                                //按键有效标志清0
                count=0;                                //消抖计数清0
        if(num==0)
        if(num==1)
        if(num==2)
        if(num==3)
        if(num==4)
        if(num==4)
        if(num==5)
        if(num==6)
        if(num==7)
        if(num==8)
        if(num==9)
        return date;
void jisuan()
void display()
        uchar i=0;
        while(dis!='\0')
                write_date(dis);
                i++;
        i=0;
        init();
                keyscan();
                date=keysuan(num);
                jisuan();
                display();
作者: 飞天的猫    时间: 2018-3-8 19:48
代码应该没毛病,只能是硬件问题了
作者: walt740    时间: 2018-3-8 23:33
检查一下液晶的连线是否正确。
作者: woainissaazz123    时间: 2018-3-9 03:57
&#128522;&#128522;MSP430系列单片机实用C语言程序设计与MSP430单片机常用模块与综合系统实例精讲等光盘资料分享,里面有很多有用的例程.
下载内容
下载内容包括3个文件夹:“程序代码”、“实例插图”、“电路图”3个文件夹。
其中各个文件夹主要有以下内容。
“程序代码”文件夹里面的内容为各实例章的程序源代码。
“实例插图”文件夹里面的内容为各实例章的插图,为bmp格式。
“实例电路图”文件夹里面的内容为各实例章的电路图,由Protel99软件制成。
;下载内容使用说明
下载内容的程序需要采用C语言的编译软件打开阅读,也可以使用“UltraEdit”等软件打开阅读或者编辑。
但是这些程序必须使用“Embedded Workbench”集成开发环境进行编译调试。
下载内容的电路图是用Protel99软件画成的,所以必须使用该软件打
作者: wulin    时间: 2018-3-9 15:22
july0 发表于 2018-3-8 09:32
我还没看出哪错了
这么多错误这么看不到???
作者: 阔爱的钊钊    时间: 2018-3-10 10:53
代码细节还有很多错误,仔细调试吧
作者: 笔墨纸砚    时间: 2018-3-23 11:27
首先注意焊接有没有问题,其次看一下程序,最后注意调接在屏幕上的电阻阻值。
作者: 小企鹅卖萌    时间: 2018-3-23 16:03
可能是程序错吧
作者: 神经漫游    时间: 2018-3-23 19:36
代码粗略读起来没有大问题,建议再检查一遍硬件连接与元器件
作者: 郭没那么简单    时间: 2018-3-23 19:40
建议你买一本 郭天祥的《新概念 51单片机 C语言教程》的书来看看,附带光盘有视频讲解
作者: I2C    时间: 2018-3-24 16:35
没有文字库
