标题: Error[Pe147]: declaration is incompatible with "__interwork __softfp... [打印本页] 作者: bojie1024 时间: 2018-3-7 17:33 标题: Error[Pe147]: declaration is incompatible with "__interwork __softfp... 使用IAR 6.4(7.0)编译工程报错
Error[Pe147]: declaration is incompatible with "__interwork __softfp unsigned long __get_PSP(void)"
把core_cm3.h里面这句给注释掉,然后加上一句
#if defined (__ICCARM__)
//#include <intrinsics.h> /* IAR Intrinsics */
__intrinsic void __DSB(void);
#endif
完全没有任何警告和错误。
我的是IAR6.3+STM32F10x_StdPeriph_Driver V3.5.0
