stm32-gbrl-g代码解释程序
asd150080
2018-3-19 16:03
stm32-gbrl-g代码解释程序
stm32-gbrl-g代码解释程序
//2013.8.27 Copyright@ rhyme呆瓜云
#include "stm32f10x.h"
#include "stdio.h"
#include "gpio.h"
#include "usart.h"
#include "delay.h"
#include "tim.h"
#include "eeprom.h"
#include "pwm.h"
#include "config.h"
#include "planner.h"
#include "nuts_bolts.h"
#include "stepper.h"
#include "spindle_control.h"
#include "coolant_control.h"
#include "motion_control.h"
#include "gcode.h"
#include "protocol.h"
#include "limits.h"
#include "report.h"
#include "settings.h"
#include "serial.h"
u8 USART_RX[60]={""};
u8 USART_mark=0;
u8 Press_mark=0;
int USART_control=0;
int USART_data=0;
u16 USART_RX_STA; //接收状态标记
uint16_t ee;//EEPROM变量
u8 mo=1;
int main(void)
RCC_Configuration();
delay_Configuration(72);
USART1_Configuration(9600);
PB9_OUT
Set_B9
// PB8_OUT
// Set_B8
// delay_ms(200);
// Clr_B8
// delay_ms(200);
// Set_B8
// delay_ms(300);
// Clr_B8
// PA7_OUT
// Clr_A7
// PA6_OUT
// Clr_A6
Motors_Set_GPIO();//电机IO口定义
// FLASH_Unlock();
// EE_Init();
settings_reset(true);//GRBL重置所有参数
//读取EEPROM 设定FEED和SEEK
// if(!EE_ReadVariable(32,&ee))
// settings.default_feed_rate = ee;
// settings.default_seek_rate = ee;
TIM_Configuration(TIM2,1001,1,1);
st_init(); //步进电机初始化,用这两个中断,通过 “布雷森汉姆直线算法”同时控制三个步进输出。
memset(&sys, 0, sizeof(sys)); //清数组
sys.abort = true; // 设置abort 标志着初始化完成
sys.state = STATE_INIT; // 设置一个警示标志来指示未知的初始位置
// TIM3_PWM_Configuration(20,3600,1,1,0,0);
// PA6_OUT
// Set_A6
// PA7_OUT
// Clr_A7
if (sys.abort) {
// Reset system.
serial_reset_read_buffer(); // Clear serial read buffer
plan_init(); // Clear block buffer and planner variables
gc_init(); // Set g-code parser to default state
protocol_init(); // Clear incoming line data and execute startup lines
spindle_init();
coolant_init();
limits_init();
st_reset(); // Clear stepper subsystem variables.
// Sync cleared gcode and planner positions to current system position, which is only
// cleared upon startup, not a reset/abort.
sys_sync_current_position();
// Reset system variables.
sys.abort = false;
sys.execute = 0;
if (bit_istrue(settings.flags,BITFLAG_AUTO_START)) { sys.auto_start = true; }
// Check for power-up and set system alarm if homing is enabled to force homing cycle
// by setting Grbl's alarm state. Alarm locks out all g-code commands, including the
// startup scripts, but allows access to settings and internal commands. Only a homing
// cycle '$H' or kill alarm locks '$X' will disable the alarm.
// NOTE: The startup script will run after successful completion of the homing cycle, but
// not after disabling the alarm locks. Prevents motion startup blocks from crashing into
// things uncontrollably. Very bad.
#ifdef HOMING_INIT_LOCK
if (sys.state == STATE_INIT && bit_istrue(settings.flags,BITFLAG_HOMING_ENABLE)) { sys.state = STATE_ALARM; }
#endif
// Check for and report alarm state after a reset, error, or an initial power up.
if (sys.state == STATE_ALARM) {
report_feedback_message(MESSAGE_ALARM_LOCK);
} else {
// All systems go. Set system to ready and execute startup script.
sys.state = STATE_IDLE;
protocol_execute_startup();
protocol_execute_runtime();
protocol_process(); // ... process the serial protocol
if(mo==0) {MotorsEnable(0x00);mo=10;}
// delay_ms(500);
// Set_B12
// delay_ms(500);
// Clr_B12
// printf(" This is the STM32 Demo !!! \r\n");
STM32-GRBL-master.rar
(412.7 KB, 下载次数: 176)
2018-3-19 16:03 上传
点击文件名下载附件
g代码解释器
下载积分: 黑币 -5
mamingle666
2018-5-17 11:04
谢谢分享
mick32
2018-5-26 05:01
Nice work
Thanks
yibunihao
2018-12-8 10:50
多谢楼主分享
swapkernel1
2018-12-19 08:39
多谢楼主分享
肥佬的黑猫
2018-12-24 10:44
谢谢分享
Poker_
2019-4-17 20:31
楼主,你13行到25行的代码都指的啥呀
WGY116
2020-2-3 17:40
感谢分享
cnc2020
2020-2-6 22:27
very good, thank you
yulin3192
2022-7-10 10:36
谢谢分享,啥时候能发个文档
