1 Top Tracks, top side
2 Route2 Inner layer (signal or supply)
3 Route3 Inner layer (signal or supply)
4 Route4 Inner layer (signal or supply)
5 Route5 Inner layer (signal or supply)
6 Route6 Inner layer (signal or supply)
7 Route7 Inner layer (signal or supply)
8 Route8 Inner layer (signal or supply)
9 Route9 Inner layer (signal or supply)
10 Route10 Inner layer (signal or supply)
11 Route11 Inner layer (signal or supply)
12 Route12 Inner layer (signal or supply)
13 Route13 Inner layer (signal or supply)
14 Route14 Inner layer (signal or supply)
15 Route15 Inner layer (signal or supply)
16 Bottom Tracks, bottom side
17 Pads Pads (through-hole)元件的引脚(过孔型,贴片引脚算在顶层和底层上)
18 Vias Vias (through all layers)过孔
19 Unrouted Airlines (rubber bands)
20 Dimension Board outlines (circles for holes) *)板子外形,相当于机械层
21 tPlace Silk screen, top side丝印层
22 bPlace Silk screen, bottom side丝印层
23 tOrigins Origins, top side (generated autom.)元件中间有个十字叉,代表元件位置
24 bOrigins Origins, bottom side (generated autom.)
25 tNames Service print, top side (component NAME)
26 bNames Service print, bottom s. (component NAME)
27 tValues Component VALUE, top side
28 bValues Component VALUE, bottom side
21~28制版时可全部放在丝印层
29 tStop Solder stop mask, top side (gen. autom.)
30 bStop Solder stop mask, bottom side (gen. Autom.)
31 tCream Solder cream, top side
32 bCream Solder cream, bottom side
33 tFinish Finish, top side
34 bFinish Finish, bottom side
35 tGlue Glue mask, top side
36 bGlue Glue mask, bottom side
37 tTest Test and adjustment information, top side
38 bTest Test and adjustment inf., bottom side
39 tKeepout Restricted areas for components, top side
40 bKeepout Restricted areas for components, bottom s.
41 tRestrict Restricted areas for copper, top side
42 bRestrict Restricted areas for copper, bottom side
43 vRestrict Restricted areas for vias
44 Drills Conducting through-holes
45 Holes Non-conducting holes
46 Milling Milling
47 Measures Measures
48 Document Documentation
49 Reference Reference marks
51 tDocu Detailed top screen print
52 bDocu Detailed bottom screen print
