求助,为什么计算器无法正确仿真
Evelynchan
2018-4-17 13:47
求助,为什么计算器无法正确仿真
要求是:
1.简易四则运算,包括负数运算
2.错误提示:当计算器执行过程中有错误时,会在LCD上显示相应的提示,如:当输入的数值或计算得到的结果大于计算器的表示范围时,计算器会在LCD上提示OV;当除数为0时,计算器会在LCD上提示ERR。
仿真图在压缩包里
以下是程序:
#include<reg51.h>
sbit lcden=P1^1;
sbit rs=P1^0;
sbit rw=P1^2;
sbit busy=P0^7;
char i,j,temp,num,num_1;
long a,b,c;
float a_c,b_c;
uchar flag,fuhao;
uchar code table[]={
7,8,9,0,
4,5,6,0,
1,2,3,0,
0,0,0,0};
uchar code table1[]={
7,8,9,0x2f-0x30,
4,5,6,0x2a-0x30,
1,2,3,0x2d-0x30,
0x01-0x30,0,0x3d-0x30,0x2b-0x30
void delay(uchar z)
uchar y;
for(z;z>0;z--)
for(y=0;y<110;y++);
void write_com(uchar com)
rs=0;
P0=com;
delay(5);lcden=1;delay(5); lcden=0;
void write_date(uchar date)
rs=1; P0=date; delay(5);
lcden=1; delay(5); lcden=0;
void init()
num=-1;
lcden=1;
rw=0;
write_com(0x38);
delay(5); write_com(0x38);
delay(5); write_com(0x0c);
delay(1); write_com(0x06);
delay(1); write_com(0x80);
delay(1); write_com(0x01);
num_1=0;
i=0; j=0;
a=0;
b=0;
c=0;
flag=0;
fuhao=0;
void keyscan()
P2=0xfe;
if(P2!=0xfe)
delay(20);
if(P2!=0xfe) { temp=P2&0xf0;
switch(temp)
case 0xe0:num=0; break; //7
case 0xd0:num=1; break; //8
case 0xb0:num=2; break; //9
case 0x70:num=3; break;
} while(P2!=0xfe);
if(num==0||num==1||num==2)
if(j!=0){write_com(0x01); j=0; }
if(flag==0)
{ a=a*10+table[num]; }
{ b=b*10+table[num]; }
flag=1;
fuhao=4;
i=table1[num];
write_date(0x30+i);
P2=0xfd;
if(P2!=0xfd)
delay(20);
if(P2!=0xfd){ temp=P2&0xf0;
switch(temp)
case 0xe0:num=4; break; //4
case 0xd0:num=5; break; //5
case 0xb0:num=6; break; //6
case 0x70:num=7; break; //¡á
} while(P2!=0xfd);
if(num==4||num==5||num==6&&num!=7)
if(j!=0){ write_com(0x01); j=0; }
if(flag==0)
{ flag=1;
fuhao=3;
i=table1[num];
write_date(0x30+i);
P2=0xfb;
if(P2!=0xfb){ delay(20);
if(P2!=0xfb) { temp=P2&0xf0;
switch(temp)
case 0xe0:num=8; break; //1
case 0xd0:num=9; break; //2
case 0xb0:num=10; break; //3
case 0x70:num=11; break; //-
} while(P2!=0xfb);
if(num==8||num==9||num==10)
if(flag==0)
else if(num==11)
flag=1;
fuhao=2;
i=table1[num];
write_date(0x30+i);
P2=0xf7;
if(P2!=0xf7){ delay(20);
if(P2!=0xf7){ temp=P2&0xf0;
switch(temp)
case 0xe0:num=12; break;
case 0xd0:num=13; break;
case 0xb0:num=14; break;
case 0x70:num=15; break;
} while(P2!=0xf7);
switch(num)
case 12:{write_com(0x01);a=0;b=0;flag=0;fuhao=0;}
break;
case 13:{
if(flag==0)
{ a=a*10; write_date(0x30); P2=0; }
else if(flag>=1)
{ b=b*10; write_date(0x30); }
} break;
case 14:{j=1;
if(fuhao==1)
write_com(0x80+0x4f);
write_com(0x04);
c=a+b;
while(c!=0){write_date(0x30+c%10); c=c/10; }
write_date(0x3d);
else if(fuhao==2)
write_com(0x04);
if(a-b>0) c=a-b;
else c=b-a;
while(c!=0) { write_date(0x30+c%10);c=c/10; }
if(a-b<0) write_date(0x2d);
write_date(0x3d);
else if(fuhao==3)
{write_com(0x80+0x4f); write_com(0x04);
c=a*b;
while(c!=0) {write_date(0x30+c%10); c=c/10; }
write_date(0x3d); a=0;b=0;flag=0;fuhao=0;
else if(fuhao==4)
write_com(0x04);
i=0;
if(b!=0)
c=(long)(((float)a/b)*1000);
while(c!=0)
c=c/10;
i++; if(i==3) write_date(0x2e);
if(a/b<=0)
if(i<=2)
if(i==1) write_date(0x30);
write_date(0x2e); // .
write_date(0x30);
write_date(0x30); //
write_date(0x3d);
write_date('!');write_date('R');write_date('O');
write_date('R');write_date('R');write_date('E');
} break;
case 15:{write_date(0x30+table1[num]);flag=1;fuhao=1;} break;
}//P2!=0xf7
main()
init();
keyscan();
yehui409
2018-4-17 21:33
找到人了没,兄弟
HC6800-ES-V2.0
2018-4-18 14:58
发表于 2018-4-17 22:39
真希望你会
http://www.51hei.com/bbs/dpj-76023-1.html
在本论坛找的,你还可以找找其它的帖子,这个内容应该不新鲜。
areyouok
2019-2-1 10:14
你自身要求的这些判断条件你都没很好的加进去,正确做法应该是一个个地将条件加入进去调试.而却这一步是最好关键的!
