标题: 单片机语音密码锁源码 [打印本页]
作者: 1573104943    时间: 2018-4-18 10:49
标题: 单片机语音密码锁源码
语音密码锁单片机源程序如下:
  1. //包含头文件
  2. #include <REG51.h>
  3. #include<intrins.h>
  4. #include "yyxp.h"
  5. //宏定义
  6. #define LCM_Data  P0                  //将P0口定义为LCM_Data
  7. #define uchar unsigned char
  8. #define uint  unsigned int
  9. #define w 6                                //定义密码位数
  10. //1602的控制脚
  11. sbit lcd1602_rs=P2^7;
  12. sbit lcd1602_rw=P2^6;
  13. sbit lcd1602_en=P2^5;
  14. sbit Scl=P3^4;                        //24C02串行时钟
  15. sbit Sda=P3^5;                        //24C02串行数据
  16. sbit ALAM = P2^4;                //报警
  17. sbit ledOpen = P2^3;    //开锁成功LED闪烁
  18. sbit KEY = P3^6;                //开锁
  19. bit  pass=0;                        //密码正确标志
  20. bit  ReInputEn=0;                //重置输入允许标志
  21. unsigned char miao;
  22. unsigned char moshi;//模式
  23. unsigned char t0Count;
  24. unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};                                 //控盘扫描控制表
  25. //液晶显示数据数组
  26. unsigned char code start_line[]        = {"password:       "};
  27. unsigned char code name[]                  = {"  Speech  Lock  "};        //显示名称
  28. unsigned char code Correct[]         = {"     correct    "};                //输入正确
  29. unsigned char code Error[]           = {"      error     "};          //输入错误
  30. unsigned char code codepass[]        = {"      pass      "};
  31. unsigned char code LockOpen[]        = {"      open      "};                //OPEN
  32. unsigned char code SetNew[]         = {"SetNewWordEnable"};
  33. unsigned char code Input[]           = {"input:          "};                //INPUT
  34. unsigned char code ResetOK[]         = {"ResetPasswordOK "};
  35. unsigned char code initword[]        = {"Init password..."};
  36. unsigned char code Er_try[]                = {"error,try again!"};
  37. unsigned char code again[]                = {"input again     "};
  38. unsigned char code shengyu[]    = {"Time:  :        "};
  39. unsigned char code jihui[]      = {"  Ci Ji Hui     "};
  40. unsigned char InputData[6];        //输入密码暂存区
  41. unsigned char CurrentPassword[6]={1,3,1,4,2,0};                         //管理员密码(只可在程序中修改)
  42. unsigned char TempPassword[6];
  43. unsigned char N=0;                                //密码输入位数记数
  44. unsigned char ErrorCont;                        //错误次数计数
  45. unsigned char CorrectCont;                        //正确输入计数
  46. unsigned char ReInputCont;                         //重新输入计数
  47. unsigned char code initpassword[6]={0,0,0,0,0,0};                        //输入管理员密码后将密码初始为000000
  48. //=====================5ms延时==============================
  49. void Delay5Ms(void)
  50. {
  51.         unsigned int TempCyc = 5552;
  52.         while(TempCyc--);
  53. }
  54. //===================400ms延时==============================
  55. void Delay400Ms(void)
  56. {
  57. unsigned char TempCycA = 5;
  58. unsigned int TempCycB;
  59. while(TempCycA--)
  60. {
  61.   TempCycB=7269;
  62.   while(TempCycB--);
  63. }
  64. }
  65. //=============================================================================================
  66. //================================24C02========================================================
  67. //=============================================================================================
  68. void mDelay(uchar t) //延时
  69. {
  70.         uchar i;
  71.            while(t--)
  72.            {
  73.                    for(i=0;i<125;i++)
  74.                    {;}
  75.            }
  76. }
  77.
  78. void Nop(void)                  //空操作
  79. {
  80.         _nop_();                  //仅作延时用一条语句大约1us
  81.         _nop_();
  82.         _nop_();
  83.         _nop_();
  84. }
  85. /*****24c02程序参照24c02时序图*****/
  86. /*起始条件*/
  87. void Start(void)
  88. {
  89.         Sda=1;
  90.         Scl=1;
  91.         Nop();
  92.         Sda=0;
  93.         Nop();
  94. }
  95. /*停止条件*/
  96. void Stop(void)
  97. {
  98.         Sda=0;
  99.         Scl=1;
  100.         Nop();
  101.         Sda=1;
  102.         Nop();
  103. }
  104. /*应答位*/
  105. void Ack(void)
  106. {
  107.         Sda=0;
  108.         Nop();
  109.         Scl=0;
  110.         Nop();
  111.         Scl=1;
  112. }
  113. /*反向应答位*/
  114. void NoAck(void)
  115. {
  116.         Sda=1;
  117.         Nop();
  118.         Scl=1;
  119.         Nop();
  120.         Scl=0;
  121. }
  122. /*发送数据子程序,Data为要求发送的数据*/
  123. void Send(uchar Data)
  124. {
  125.            uchar BitCounter=8;
  126.            uchar temp;
  127.            do
  128.            {
  129.                    temp=Data;                                           //将待发送数据暂存temp
  130.                    Scl=0;
  131.                    Nop();
  132.                    if((temp&0x80)==0x80)                   //将读到的数据&0x80
  133.                    Sda=1;
  134.                    else
  135.                    Sda=0;
  136.                    Scl=1;
  137.                    temp=Data>>1;                                   //数据左移
  138.                    Data=temp;                                           //数据左移后重新赋值Data
  139.                    BitCounter--;                                   //该变量减到0时,数据也就传送完成了
  140.            }
  141.            while(BitCounter);                                   //判断是否传送完成
  142.            Scl=0;
  143. }
  144. /*读一字节的数据,并返回该字节值*/
  145. uchar Read(void)
  146. {
  147.     uchar temp=0;
  148.         uchar temp1=0;
  149.         uchar BitCounter=8;
  150.         Sda=1;
  151.         do
  152.         {
  153.                 Scl=0;
  154.                 Nop();
  155.                 Scl=1;
  156.                 Nop();
  157.                 if(Sda)                                   //数据位是否为1
  158.                         temp=temp&&0x01;           //为1 temp的最低位为1(|0x01,就是将最低位变为1)
  159.                 else                                   //如果为0
  160.                         temp=temp||0xfe;           //temp最低位为0(&0xfe(11111110)最低位就是0)
  161.                 if(BitCounter-1)           //BitCounter减1后是否为真
  162.                 {
  163.                         temp1=temp<<1;           //temp左移
  164.                         temp=temp1;
  165.                 }
  166.                 BitCounter--;                   //BitCounter减到0时,数据就接收完了
  167.         }
  168.         while(BitCounter);                   //判断是否接收完成
  169.         return(temp);
  170. }
  171. void WrToROM(uchar Data[],uchar Address,uchar Num)
  172. {
  173.   uchar i;
  174.   uchar *PData;
  175.   PData=Data;
  176.   for(i=0;i<Num;i++)
  177.   {
  178.   Start();
  179.   Send(0xa0);
  180.   Ack();
  181.   Send(Address+i);
  182.   Ack();
  183.   Send(*(PData+i));
  184.   Ack();
  185.   Stop();
  186.   mDelay(20);
  187.   }
  188. }
  189. void RdFromROM(uchar Data[],uchar Address,uchar Num)
  190. {
  191.   uchar i;
  192.   uchar *PData;
  193.   PData=Data;
  194.   for(i=0;i<Num;i++)
  195.   {
  196.   Start();
  197.   Send(0xa0);
  198.   Ack();
  199.   Send(Address+i);
  200.   Ack();
  201.   Start();
  202.   Send(0xa1);
  203.   Ack();
  204.   *(PData+i)=Read();
  205.   Scl=0;
  206.   NoAck();
  207.   Stop();
  208.   }
  209. }
  210. //==================================================================================================
  211. //=======================================LCD1602====================================================
  212. //==================================================================================================
  213. #define yi 0x80 //LCD第一行的初始位置,因为LCD1602字符地址首位D7恒定为1(100000000=80)
  214. #define er 0x80+0x40 //LCD第二行初始位置(因为第二行第一个字符位置地址是0x40)
  215. //----------------延时函数,后面经常调用----------------------
  216. void delay(uint xms)//延时函数,有参函数
  217. {
  218.         uint x,y;
  219.         for(x=xms;x>0;x--)
  220.          for(y=110;y>0;y--);
  221. }
  222. //--------------------------写指令---------------------------
  223. void write_1602com(uchar com)//****液晶写入指令函数****
  224. {
  225.         lcd1602_rs=0;//数据/指令选择置为指令
  226.         lcd1602_rw=0; //读写选择置为写
  227.         P0=com;//送入数据
  228.         delay(1);
  229.         lcd1602_en=1;//拉高使能端,为制造有效的下降沿做准备
  230.         delay(1);
  231.         lcd1602_en=0;//en由高变低,产生下降沿,液晶执行命令
  232. }
  233. //-------------------------写数据-----------------------------
  234. void write_1602dat(uchar dat)//***液晶写入数据函数****
  235. {
  236.         lcd1602_rs=1;//数据/指令选择置为数据
  237.         lcd1602_rw=0; //读写选择置为写
  238.         P0=dat;//送入数据
  239.         delay(1);
  240.         lcd1602_en=1; //en置高电平,为制造下降沿做准备
  241.         delay(1);
  242.         lcd1602_en=0; //en由高变低,产生下降沿,液晶执行命令
  243. }
  244. //-------------------------初始化-------------------------
  245. void lcd_init(void)
  246. {
  247.         write_1602com(0x38);//设置液晶工作模式,意思:16*2行显示,5*7点阵,8位数据
  248.         write_1602com(0x0c);//开显示不显示光标
  249.         write_1602com(0x01);//清显示
  250.         write_1602com(0x06);//整屏不移动,光标自动右移
  251. }
  252. //========================================================================================
  253. //=========================================================================================
  254. //==============将按键值编码为数值=========================
  255. unsigned char coding(unsigned char m)
  256. {
  257.         unsigned char k;
  258.
  259.         switch(m)
  260.         {
  261.                 case (0x11): k=1;break;
  262.                 case (0x21): k=2;break;
  263.                 case (0x41): k=3;break;
  264.                 case (0x81): k='A';break;
  265.                 case (0x12): k=4;break;
  266.                 case (0x72): k=5;break;
  267.                 case (0x42): k=6;break;
  268.                 case (0x82): k='B';break;
  269.                 case (0x14): k=7;break;
  270.                 case (0x24): k=8;break;
  271.                 case (0x44): k=9;break;
  272.                 case (0x84): k='C';break;
  273.                 case (0x18): k='*';break;
  274.                 case (0x28): k=0;break;
  275.                 case (0x48): k='#';break;
  276.                 case (0x88): k='D';break;
  277.         }
  278.         return(k);
  279. }
  280. //=====================按键检测并返回按键值===============================
  281. unsigned char keynum(void)
  282. {
  283.         unsigned char row,col,i;
  284.         P1=0xf0;
  285.         if((P1&0xf0)==0xf0)
  286.         {
  287.                    Delay5Ms();
  288.         Delay5Ms();
  289.                    if((P1&0xf0)==0xf0)
  290.                 {
  291.                     row=P1^0xf0;          //确定行线
  292.                         i=0;
  293.                         P1=a[i];                  //精确定位
  294.                         while(i<4)
  295.                         {
  296.                                  if((P1&0xf0)==0xf0)
  297.                                   {
  298.                                            col=~(P1&0xff);          //确定列线
  299.                                            break;            //已定位后提前退出
  300.                                   }
  301.                                 else
  302.                                   {
  303.                                            i++;
  304.                                            P1=a[i];
  305.                                   }
  306.                         }
  307.                 }
  308.                 else
  309.                 {
  310.                         return 0;
  311.                 }
  312.
  313.                 while((P1&0xf0)==0xf0);
  314.                 return (row|col);                         //行线与列线组合后返回
  315.         }
  316.         else return 0;                                 //无键按下时返回0
  317. }
  318. //=======================一声提示音,表示有效输入========================
  319. void OneAlam(void)
  320. {
  321.         ALAM=0;
  322.         Delay5Ms();
  323.     ALAM=1;
  324. }
  325. //========================二声提示音,表示操作成功========================
  326. void TwoAlam(void)
  327. {
  328.         ALAM=0;
  329.         Delay5Ms();
  330.     ALAM=1;
  331.     Delay5Ms();
  332.         ALAM=0;
  333.         Delay5Ms();
  334.     ALAM=1;
  335. }
  336. //========================三声提示音,表示错误========================
  337. void ThreeAlam(void)
  338. {
  339.         ALAM=0;
  340.         Delay5Ms();
  341.     ALAM=1;
  342.     Delay5Ms();
  343.         ALAM=0;
  344.         Delay5Ms();
  345.     ALAM=1;
  346.     Delay5Ms();
  347.         ALAM=0;
  348.         Delay5Ms();
  349.     ALAM=1;
  350. }
  351. //========================两次LED闪烁,表示开锁成功========================
  352. void threeLed(void)
  353. {
  354.         ledOpen=0;
  355.         Delay5Ms();
  356.     ledOpen=1;
  357.     Delay5Ms();
  358.         ledOpen=0;
  359.         Delay5Ms();
  360.     ledOpen=1;
  361. }
  362. //=====================显示输入的N个数字,用H代替以便隐藏============================
  363. //=======================显示提示输入=========================
  364. void DisplayChar(void)
  365. {
  366.         unsigned char i;
  367.         if(pass==1)
  368.         {
  369.                 //DisplayListChar(0,1,LockOpen);
  370.                 write_1602com(er);                                   //在二行开始显示
  371.                 for(i=0;i<16;i++)
  372.                 {
  373.                         write_1602dat(LockOpen[i]);           //显示open 开锁成功
  374.                 }
  375.         }
  376.         else
  377.         {
  378.                 if(N==0)
  379.                 {
  380.                         //DisplayListChar(0,1,Error);
  381.                         write_1602com(er);
  382.                         for(i=0;i<16;i++)
  383.                         {
  384.                                 write_1602dat(Error[i]);        //显示错误
  385.                         }
  386.                 }
  387.                 else
  388.                 {
  389.                         //DisplayListChar(0,1,start_line);
  390.                         write_1602com(er);
  391.                         for(i=0;i<16;i++)
  392.                         {
  393.                                 write_1602dat(start_line[i]);//显示开始输入
  394.                         }
  395.                 }
  396.         }
  397. }
  398. //========================重置密码==================================================
  399. //==================================================================================
  400. void ResetPassword(void)
  401. {
  402.         unsigned char i;
  403.         unsigned char j;
  404.         if(pass==0)
  405.         {
  406.                 pass=0;
  407.                 DisplayChar();           //显示错误
  408.                 ThreeAlam();           //没开锁时按下重置密码报警3声
  409.         }
  410.         else                                   //开锁状态下才能进行密码重置程序
  411.         {
  412.             if(ReInputEn==1)   //开锁状态下,ReInputEn置1,重置密码允许
  413.                 {
  414.                         if(N==6)           //输入6位密码
  415.                         {
  416.                                 ReInputCont++;                        //密码次数计数
  417.                                 if(ReInputCont==2)                //输入两次密码
  418.                                 {
  419.                                         for(i=0;i<6;)
  420.                                         {
  421.                                                 if(TempPassword[i]==InputData[i])        //将两次输入的新密码作对比
  422.                                                         i++;
  423.                                                 else        //如果两次的密码不同
  424.                                                 {
  425.                                                         //DisplayListChar(0,1,Error);
  426.                                                         speak(49);
  427.                                                         write_1602com(er);
  428.                                                         for(j=0;j<16;j++)
  429.                                                         {
  430.        write_1602dat(Error[j]);        //显示错误Error
  431.                                                         }
  432.                                                         ThreeAlam();                        //错误提示
  433.                                                         pass=0;                                        //关锁
  434.                                                         ReInputEn=0;                        //关闭重置功能,
  435.                                                         ReInputCont=0;
  436.                                                         DisplayChar();
  437.                                                         break;
  438.                                                 }
  439.                                         }
  440.                                         if(i==6)
  441.                                         {
  442.                                                 //DisplayListChar(0,1,ResetOK);
  443.                                                 speak(50);
  444.                                                 write_1602com(er);
  445.                                                 for(j=0;j<16;j++)
  446.                                                 {
  447.                                                         write_1602dat(ResetOK[j]);          //密码修改成功,显示
  448.                                                 }
  449.                                                 TwoAlam();                                //操作成功提示
  450.                                                  WrToROM(TempPassword,0,6);                //将新密码写入24C02存储
  451.                                                 ReInputEn=0;
  452.                                         }
  453.                                         ReInputCont=0;
  454.                                         CorrectCont=0;
  455.                                 }
  456.                                 else                                          //输入一次密码时
  457.                                 {
  458.                                         OneAlam();
  459.                                         speak(51);
  460.                                         //DisplayListChar(0, 1, again);                 //显示再次输入一次
  461.                                         write_1602com(er);
  462.                                         for(j=0;j<16;j++)
  463.                                         {
  464.                                                 write_1602dat(again[j]);                        //显示再输入一次
  465.                                         }
  466.                                         for(i=0;i<6;i++)
  467.                                         {
  468.                                                 TempPassword[i]=InputData[i];                //将第一次输入的数据暂存起来
  469.                                         }
  470.                                 }
  471.                         N=0;                                                //输入数据位数计数器清零
  472.                    }
  473.             }
  474.         }
  475. }
  476. //=======================输入密码错误超过三过,报警并锁死键盘======================
  477. void Alam_KeyUnable(void)
  478. {
  479.         P1=0x00;
  480.         {
  481.                 ALAM=~ALAM;                                 //蜂鸣器一直闪烁鸣响
  482.                 Delay5Ms();
  483.         }
  484. }
  485. //=======================取消所有操作============================================
  486. void Cancel(void)
  487. {
  488.         unsigned char i;
  489.         unsigned char j;
  490.         //DisplayListChar(0, 1, start_line);
  491.         write_1602com(er);
  492.         for(j=0;j<16;j++)
  493.         {
  494.                 write_1602dat(start_line[j]);          //显示开机输入密码界面
  495.         }
  496.         TwoAlam();                                //提示音
  497.         for(i=0;i<6;i++)
  498.         {
  499.                 InputData[i]=0;                //将输入密码清零
  500.         }
  501.         KEY=1;                                        //关闭锁
  502.         ALAM=1;                                        //报警关
  503.         pass=0;                                        //密码正确标志清零
  504.         ReInputEn=0;                        //重置输入充许标志清零
  505.         CorrectCont=0;                        //密码正确输入次数清零
  506.         ReInputCont=0;                        //重置密码输入次数清零
  507.         speak(54);
  508.         N=0;                                        //输入位数计数器清零
  509. }
  510. //==========================确认键,并通过相应标志位执行相应功能===============================
  511. void Ensure(void)
  512. {
  513.         unsigned char i,j;
  514.         RdFromROM(CurrentPassword,6,0);                                         //从24C02里读出存储密码
  515.     if(N==6)
  516.         {
  517.             if(ReInputEn==0)                                                        //重置密码功能未开启
  518.                 {
  519.                         for(i=0;i<6;)
  520.                            {
  521.                                 if(CurrentPassword[i]==InputData[i])        //判断输入密码和24c02中的密码是否相同
  522.                                 {
  523.                                         i++;        //相同一位 i就+1
  524.                                 }
  525.                                 else        //如果有密码不同
  526.                                 {
  527.                                         ErrorCont++;                                                //错误次数++
  528.
  529.                                         if(ErrorCont==3)                        //错误输入计数达三次时,报警并锁定键盘
  530.                                         {
  531.                                             speak(52);
  532.                                                 write_1602com(er);
  533.                                                 TR0=1;
  534.                                                 miao=0;
  535.                                                 t0Count=0;
  536.                                                 ErrorCont=0;
  537.                                                 write_1602com(0x0c);
  538.                                                 write_1602com(er);
  539.                                                 for(i=0;i<16;i++)
  540.                                                 {
  541.                                                         write_1602dat(shengyu[i]);
  542.                                                 }
  543.                                                 do
  544.                                                 {
  545.                                              write_1602com(0xc5);
  546.                                                  write_1602dat(miao/60/10+0x30);
  547.                                                  write_1602dat(miao/60%10+0x30);
  548.                                                  write_1602com(0xc8);
  549.                                                  write_1602dat(miao%60/10+0x30);
  550.                                                  write_1602dat(miao%60%10+0x30);
  551.                                                  delay(200);
  552.                                                 }
  553.                                                 while(miao<180);
  554.                                         }
  555.                                         else                                         //错误次数小于3次时,锁死键盘3秒,然后重新可以输入
  556.                                         {
  557.
  558.                                                 pass=0;                                        //pass位清零
  559.                                                 break;                                        //跳出
  560.                                         }
  561.                                 }
  562.                         }
  563.                         if(i==6)                                         //密码输入对时
  564.                         {
  565.                              threeLed();
  566.                                  ErrorCont=0;
  567.                                 CorrectCont++;                                        //输入正确变量++
  568.                                 if(CorrectCont==1)                                //正确输入计数,当只有一次正确输入时,开锁
  569.                                 {
  570.                                         speak(47);
  571.                                         write_1602com(er);
  572.                                         for(j=0;j<16;j++)
  573.                                         {
  574.                                                 write_1602dat(LockOpen[j]);                  //显示open开锁画面
  575.                                         }
  576.                                         TwoAlam();                        //操作成功提示音
  577.                                         KEY=0;        //开锁
  578.                                         pass=1;        //置正确标志位
  579.
  580.
  581.                                         for(j=0;j<6;j++)        //将输入清除
  582.                                         {
  583.                                                 InputData[i]=0;        //开锁后将输入位清零
  584.                                         }
  585.                                 }
  586.                                 else        //当两次正确输入时,开启重置密码功能
  587.                                 {
  588.                                         //DisplayListChar(0,1,SetNew);
  589.                                         speak(55);
  590.                                         write_1602com(er);
  591.                                         for(j=0;j<16;j++)
  592.                                         {
  593.                                                 write_1602dat(SetNew[j]);                                        //显示重置密码界面
  594.                                         }
  595.                                         TwoAlam();        //操作成功提示
  596.                                         ReInputEn=1;        //允许重置密码输入
  597.                                         CorrectCont=0;        //正确计数器清零
  598.                                 }
  599.                           }
  600.
  601.                         else                        //=========================当第一次使用或忘记密码时可以用131420对其密码初始化============
  602.                         {
  603.                                 if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
  604.                                    {
  605.                                         WrToROM(initpassword,6,0);                                 //强制将初始密码写入24C02存储
  606.                                         //DisplayListChar(0,1,initword);                        //显示初始化密码
  607.                                         write_1602com(er);
  608.                                         for(j=0;j<16;j++)
  609.                                         {
  610.                                                 write_1602dat(initword[j]);                                //显示初始化密码
  611.                                         }
  612.                                         speak(53);
  613.                                         //TwoAlam();        //成功提示音
  614.                                         //Delay400Ms();        //延时400ms
  615.                                         //TwoAlam();        //成功提示音
  616.                                         N=0;        //输入位数计数器清零
  617.                                 }
  618.                                 else        //密码输入错误
  619.                                 {
  620.                                         //DisplayListChar(0,1,Error);
  621.                                                 speak(49);
  622.                                         write_1602com(er);
  623.                                         for(j=0;j<16;j++)
  624.                                         {
  625.                                                 write_1602dat(jihui[j]);                                 //显示错误信息
  626.                                         }
  627.                                         write_1602com(0xc0);
  628.                                         write_1602dat(3-ErrorCont+0x30);
  629.                                         write_1602com(0xd0);
  630.                                         ThreeAlam();        //错误提示音
  631.                                         pass=0;
  632.                                 }
  633.                         }
  634.                 }
  635.                 else        //当已经开启重置密码功能时,而按下开锁键,
  636.                 {
  637.                         //DisplayListChar(0,1,Er_try);
  638.                         write_1602com(er);
  639.                         for(j=0;j<16;j++)
  640.                         {
  641.                                 write_1602dat(Er_try[j]);                          //错误,请重新输入
  642.                         }
  643.                         ThreeAlam();                                                          //错误提示音
  644.                 }
  645.         }
  646.         else                                   //密码没有输入到6位时,按下确认键时
  647.         {
  648.                 //DisplayListChar(0,1,Error);
  649.                 write_1602com(er);
  650.                 for(j=0;j<16;j++)
  651.                 {
  652.                         write_1602dat(Error[j]);                 //显示错误
  653.                 }
  654.                 ThreeAlam();        //错误提示音
  655.                 pass=0;
  656.         }
  657.
  658.         N=0;        //将输入数据计数器清零,为下一次输入作准备
  659. }
  660. void dealKey()
  661. {
  662.         unsigned char KEY,NUM;
  663.                 unsigned char i,j;
  664.         KEY=keynum();                                                        //读按键的位置码
  665.                 if(KEY!=0)        //当有按键按下时
  666.                 {
  667.
  668.                                 NUM=coding(KEY);                                //根据按键的位置将其编码,编码值赋值给NUM
  669.                                 {
  670.                                         switch(NUM)                                        //判断按键值                  if
  671.                                         {
  672.                                                 case ('A'): moshi=1        ;                                         break;
  673.                                                 case ('B'):                ;                                     break;
  674.                                                 case ('C'):         ;                                         break;                //ABC是无定义按键
  675.                                                 case ('D'): ResetPassword();                break;      //重新设置密码
  676.                                                 case ('*'): Cancel();                                break;      //取消当前输入
  677.                                                 case ('#'): Ensure();                                 break;           //确认键,
  678.                                                 default:        //如果不是功能键按下时,就是数字键按下
  679.                                                 {
  680.                                                         //DisplayListChar(0,1,Input);
  681.                                                         write_1602com(er);
  682.                                                         for(i=0;i<16;i++)
  683.                                                         {
  684.        write_1602dat(Input[i]);                                //显示输入画面
  685.                                                         }
  686.
  687.                                                         if(N<6)                                                           //当输入的密码少于6位时,接受输入并保存,大于6位时则无效。
  688.                                                         {
  689.        OneAlam();        //按键提示音
  690.        //DisplayOneChar(6+N,1,'*');
  691.        for(j=0;j<=N;j++)
  692.        {
  693.        write_1602com(er+6+j);                                //显示位数随输入增加而增加
  694.        write_1602dat('*');                                        //但不显示实际数字,用*代替
  695.        }
  696.        InputData[N]=NUM;                                                //将数字键的码赋值给InputData[]数组暂存
  697.        N++;        //密码位数加
  698.                                                         }
  699.                                                         else        //输入数据位数大于6后,忽略输入
  700.                                                         {
  701.        N=6;        //密码输入大于6位时,不接受输入
  702.        break;
  703.                                                         }
  704.                                                 }
  705.                                         }
  706.                                 }
  707.
  708.                  }
  709. }
  710. //==============================主函数===============================
  711. void main(void)
  712. {
  713.         unsigned char i;
  714.         P1=0xFF;                                    //P1口复位
  715.         TMOD=0x01;
  716.         TL0=0x4c;
  717.         TH0=0x00;
  718.         ET0=1;
  719.         EA=1;
  720.         lcd_init();         //LCD初始化
  721.         write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
  722.         for(i=0;i<16;i++)
  723.         {
  724.                 write_1602dat(name[i]);//向液晶屏写开机画面
  725.         }
  726.         write_1602com(er);
  727.         for(i=0;i<16;i++)
  728.         {
  729.                 write_1602dat(start_line[i]);//写输入密码等待界面
  730.         }
  731.         write_1602com(er+9);        //设置光标位置
  732.         write_1602com(0x0f);        //设置光标为闪烁
  733.         N=0;                                         //初始化数据输入位数
  734.         Delay400Ms();        //延时400ms
  735.         Delay400Ms();        //延时400ms
  736.         speak(48);
  737.         while(1)                 //进入循环
  738.         {
  739.          dealKey();
  740.         }
  741. }
  742. void timer0() interrupt 1
  743. {
  744. TL0=0x4c;
  745. TH0=0x00;
  746. t0Count++;
  747. if(t0Count>=20)
  748. {
  749.   t0Count=0;
  750.   miao++;
  751.   if(miao>=180)
  752.   {
  753.    TR0=0;
  754.    miao=180;
  755.   }
  756. }
  757. }
1-程序.rar (61.84 KB, 下载次数: 36)
