标题: 基于STM32驱动IIC0.96寸OLED屏 底层驱动+菜单程序源码 [打印本页]
作者: xiaolibo    时间: 2018-4-22 14:24
本文针对IIC OLED屏底层驱动相关代码
16X32,32X32,128X48等下面附带相关实物图
内置简单的菜单程序,下面附带实物图
相关资料已经上传
stm32单片机OLED菜单源程序如下:
  1. #define OLED_IIC_SCL  PBout(4) //SCL   串行时钟
  2. #define OLED_IIC_SDA  PBout(3) //SDA  串行数据
  3. }
  4. void OLED_P16x32Ch(unsigned char x,unsigned char y,unsigned int N)
  5. {
  6.         unsigned char wm=0;
  7.         unsigned int adder=64*N;
  8.         OLED_Set_Pos(x , y);
  9.         for(wm = 0;wm < 16;wm++)
  10.         {
  11.                 OLED_WrDat(F16x32[adder]);
  12.                 adder += 1;
  13.         }
  14.         OLED_Set_Pos(x,y+1 );
  15.         for(wm = 0;wm <16;wm++)
  16.         {
  17.                 OLED_WrDat(F16x32[adder]);
  18.                 adder += 1;
  19.         }
  20. OLED_Set_Pos(x , y+2);
  21.         for(wm = 0;wm < 16;wm++)
  22.         {
  23.                 OLED_WrDat(F16x32[adder]);
  24.                 adder += 1;
  25.         }
  26.         OLED_Set_Pos(x,y+3 );
  27.         for(wm = 0;wm <16;wm++)
  28.         {
  29.                 OLED_WrDat(F16x32[adder]);
  30.                 adder += 1;
  31.         }
  32. }
  33. void OLED_P32x32Ch(unsigned char x,unsigned char y,unsigned int N)
  34. {
  35.         unsigned char wm=0;
  36.         unsigned int adder=128*N;
  37.         OLED_Set_Pos(x , y);
  38.         for(wm = 0;wm < 32;wm++)
  39.         {
  40.                 OLED_WrDat(F32x32[adder]);
  41.                 adder += 1;
  42.         }
  43.         OLED_Set_Pos(x,y+1 );
  44.         for(wm = 0;wm <32;wm++)
  45.         {
  46.                 OLED_WrDat(F32x32[adder]);
  47.                 adder += 1;
  48.         }
  49. OLED_Set_Pos(x , y+2);
  50.         for(wm = 0;wm < 32;wm++)
  51.         {
  52.                 OLED_WrDat(F32x32[adder]);
  53.                 adder += 1;
  54.         }
  55.         OLED_Set_Pos(x,y+3 );
  56.         for(wm = 0;wm <32;wm++)
  57.         {
  58.                 OLED_WrDat(F32x32[adder]);
  59.                 adder += 1;
  60.         }
  61. }
  62. void OLED_P128x48Ch(unsigned char x,unsigned char y,unsigned int N)
  63. {
  64.         unsigned char wm=0;
  65.         unsigned int adder=768*N;
  66.         OLED_Set_Pos(x , y);
  67.         for(wm = 0;wm < 128;wm++)
  68.         {
  69.                 OLED_WrDat(F128x48[adder]);
  70.                 adder += 1;
  71.         }
  72.         OLED_Set_Pos(x,y+1);
  73.         for(wm = 0;wm <128;wm++)
  74.         {
  75.                 OLED_WrDat(F128x48[adder]);
  76.                 adder += 1;
  77.         }
  78. OLED_Set_Pos(x , y+2);
  79.         for(wm = 0;wm < 128;wm++)
  80.         {
  81.                 OLED_WrDat(F128x48[adder]);
  82.                 adder += 1;
  83.         }
  84. OLED_Set_Pos(x,y+3 );
  85.         for(wm = 0;wm <128;wm++)
  86.         {
  87.                 OLED_WrDat(F128x48[adder]);
  88.                 adder += 1;
  89.         }
  90. OLED_Set_Pos(x,y+4 );
  91.         for(wm = 0;wm <128;wm++)
  92.         {
  93.                 OLED_WrDat(F128x48[adder]);
  94.                 adder += 1;
  95.         }
  96. OLED_Set_Pos(x,y+5 );
  97.         for(wm = 0;wm <128;wm++)
  98.         {
  99.                 OLED_WrDat(F128x48[adder]);
  100.                 adder += 1;
  101.         }
  102. }
  103. //  IIC协议    OLED屏 人机界面
  104. void lnterface(void)                          //人机界面
  105. {
  106.
  107.         Status_Bar();
  108.         switch(Page_Sgin)
  109.         {
  110.                 case 0:
  111.                              Main_Menu(); break;
  112.                 case 2:
  113.                              Menu_2(); break;
  114.                 case 3:
  115.                              Menu_3();break;
  116.
  117.
  118.                 default : break;
  119.         }
  120.
  121. }
  122. //主菜单
  123. void Main_Menu(void)
  124. {
  125.   WhenTheDisplay();                             //显示时分秒
  126.         DayAndDayDisplay();                         //显示年月日
  127.         OLED_P16x16Ch(0*16,6,11);                   //显示 //菜
  128.         OLED_P16x16Ch(1*16,6,12);                   //显示 //单
  129.         OLED_P16x16Ch(6*16,6,13);                   //显示 //退
  130.         OLED_P16x16Ch(7*16,6,14);                   //显示 //出
  131.         if(KEY_Scan(Key_Selectio)==Determine_Choice)//判断是否按下确定按键
  132.         {
  133.                 Page_Sgin=2;                              //页面选择置2
  134.                 OLED_P128x48Ch(0,2,0);                    //清除内容栏
  135.         }
  136. }
  137. void Menu_2(void)
  138. {
  139.         if(Choice==2||Choice==4||Choice==6)
  140.         {
  141.                 OLED_P16x16Ch(0*16,Choice,44);              //选择
  142.                 Display(2,0,0);
  143.
  144.
  145.                 switch(KEY_Scan(Key_Selectio))
  146.                 {
  147.                         case Superior_Choice:                     //上翻
  148.                                    OLED_P16x16Ch(0*16,Choice,37);
  149.                                    Choice-=2;
  150.                                    break;
  151.                         case Subordinate_Choice:                  //下翻
  152.                                    OLED_P16x16Ch(0*16,Choice,37);
  153.                                    Choice+=2;
  154.                                    break;
  155.                         case Determine_Choice:                    //确定
  156.                                    OLED_P128x48Ch(0,2,0);               //清除内容栏
  157.                              Page_Sgin=3;Choice=2;
  158.                                    break;
  159.                         case Return_Choice:                       //返回
  160.                                    OLED_P128x48Ch(0,2,0);
  161.                                    Page_Sgin=0;
  162.                              break;
  163.                         default :
  164.                                    break;
  165.                 }
  166.
  167.         }
  168.         else if(Choice>6)Choice=2;
  169.         else if(Choice<2)Choice=6;
  170.
  171.         OLED_ShowNum(6*16,6,Choice/2,1,12);
  172.         OLED_P6x8Str(6.5*16,7,"/");
  173.         OLED_P6x8Str(7*16,7,"10");
  174. }
  175. void Menu_3(void)
  176. {
  177.         if(Choice==2||Choice==4||Choice==6)
  178.         {
  179.                 OLED_P16x16Ch(0*16,Choice,44);              //选择
  180.                 Display(2,0,0);
  181.
  182.                 switch(KEY_Scan(Key_Selectio))
  183.                 {
  184.                         case Superior_Choice:                     //上翻
  185.                                    OLED_P16x16Ch(0*16,Choice,37);
  186.                                    Choice-=2;
  187.                                    break;
  188.                         case Subordinate_Choice:                  //下翻
  189.                                    OLED_P16x16Ch(0*16,Choice,37);
  190.                                    Choice+=2;
  191.                                    break;
  192.                         case Determine_Choice:                    //确定
  193.                                    OLED_P128x48Ch(0,2,0);               //清除内容栏
  194.                              Page_Sgin=3;Choice=2;
  195.                                    break;
  196.                         case Return_Choice:                       //返回
  197.                                    OLED_P128x48Ch(0,2,0);
  198.                                    Page_Sgin=2;Choice=2;
  199.                              break;
  200.                         default :
  201.                                    break;
  202.                 }
  203.
  204.         }
  205.         else if(Choice>6)Choice=2;
  206.         else if(Choice<2)Choice=6;
  207.
  208.         OLED_ShowNum(6*16,6,Choice/2,1,12);
  209.         OLED_P6x8Str(6.5*16,7,"/");
  210.         OLED_P6x8Str(7*16,7,"10");
  211. }
  212.
PCtoLCD2002完美版.rar (702.05 KB, 下载次数: 480)
IIC驱动0.96寸OLED显示实验.rar (313.56 KB, 下载次数: 1607)
作者: 小胖波波    时间: 2018-4-22 21:01
非常不错的程序,值得看看
作者: sxtz531    时间: 2018-6-16 12:38
感谢搂主,学习学习
作者: y12345678    时间: 2018-6-24 16:31
你好,请问这个程序是stm32f103的吗?
作者: spdshmt    时间: 2018-6-27 10:07
很好的资料,正好学习需要
作者: sxtz531    时间: 2018-7-21 13:51
很好的资料,感谢搂主
作者: nb44444    时间: 2018-7-23 07:52
学习学习
作者: Ice_Fish    时间: 2018-8-31 20:23
找了好久!谢谢楼主的资源!
作者: 280431247    时间: 2018-9-8 19:03
66666感谢分享
作者: ebingyu    时间: 2018-10-10 10:18
学习了,谢谢楼主!
作者: lwdlwd    时间: 2018-10-18 19:09
打开后程序首先有错误  其次主程序都被注释掉了 就留了它qq 什么意思
作者: candylife9    时间: 2018-11-1 13:42
不能用
作者: 127lo    时间: 2018-11-6 17:05
刚好需要,谢谢分享
作者: wxb世界第一    时间: 2018-11-6 21:52
谢谢楼主分享
作者: lucq7896    时间: 2018-11-7 09:00
在stm32f429要改哪些地方?
作者: 18217586953    时间: 2018-11-7 10:47
不错,看看!
作者: morixinguan    时间: 2018-11-7 16:55
写得真的不错!
作者: 对对对啊    时间: 2018-11-14 11:51
非常不错的程序,值得看看
作者: 血洗无涯    时间: 2018-11-14 23:19
好好学习学习,感谢您的分享
作者: ddd123321    时间: 2018-11-16 13:55
谢谢分享呀,正好用上啦,棒棒棒!
作者: li247085736    时间: 2018-11-16 21:33
谢谢分享
作者: lyh01    时间: 2018-11-18 01:13
很好的资料
作者: 1113634577    时间: 2018-12-12 20:09
感谢分享,测试一下,竖排阴反选菜单去掉显示“确定”简洁些
作者: lwf1    时间: 2018-12-13 19:44
很好的资源,下载看看
作者: cyrs    时间: 2018-12-13 22:29
我就是懒静等成品
作者: zjk995063909    时间: 2018-12-16 22:17
谢谢楼主的分享啦。不过我怎么烧进去没反应呢。。
作者: tonyhy1975    时间: 2018-12-19 22:50
谢谢分享,值得学习
作者: rivamed    时间: 2018-12-20 10:50
谢谢楼主分享,我好好学习一下
作者: tonyhy1975    时间: 2018-12-20 12:21
谢谢分享,不错资料
作者: 1113634577    时间: 2018-12-25 18:01
下载学习一下
作者: 墨鱼腌肉    时间: 2018-12-26 16:14
看着不错;有需求会回来
作者: Darkness1206    时间: 2019-1-10 14:43
谢谢分享
作者: lrf32535604    时间: 2019-1-14 09:13
谢谢楼主分享
作者: xode    时间: 2019-2-10 09:19
谢谢楼主分享
作者: 周鹏    时间: 2019-2-16 15:10
内容太棒了!非常的工整!谢谢!
作者: gh001    时间: 2019-2-21 07:32
很好的资料,多给些资料
作者: 莫名的前行    时间: 2019-2-21 10:46
不错,学习学习
作者: 疯子单行    时间: 2019-2-23 11:31
不错  我的下载上就是闪屏
作者: 1843    时间: 2019-4-11 17:14
学习参考一下
作者: jz21zfr    时间: 2019-4-12 22:46
好好学习学习,感谢您的分享
作者: 2376024940    时间: 2019-4-14 11:35
非常感谢楼主的开源分享精神,正好我也在学习32驱动OLED屏,这是一个很好的教程。但是我在使用楼主的分享的程序时,并没有正常的驱动我的OLED显示,最初只是修改了IIC的端口,32的型号也是与楼主的样,可最终还是没能驱动成功!
作者: 2376024940    时间: 2019-4-15 19:28
想问一下楼主,这个时间显示是显示的图片吧?不是实时显示系统时间的?这个显示大字体的函数不能实时的显示RTC时钟?
作者: wjdfcm    时间: 2019-5-1 12:09
xiexiedalaofenxiang
作者: psyren    时间: 2019-5-3 21:22
很好的资料,正好学习需要
作者: 否定11    时间: 2019-6-4 20:50
感谢分享,但是有错误怎么办?
作者: willy926234097    时间: 2019-6-5 09:48
感謝分享!學習中!!
作者: 陈仕祥    时间: 2019-6-18 22:38
谢谢楼主分享
作者: lsh574    时间: 2019-6-20 15:13
感谢搂主,学习学习
作者: qq646926493    时间: 2019-7-21 17:41
谢谢分析~~学习一下~
作者: utt    时间: 2019-7-22 15:13
好好学习学习,感谢您的分享
作者: 18172467016    时间: 2019-7-23 21:24
硬核oled
作者: zwll    时间: 2019-8-5 14:16
好东西
作者: 迁就    时间: 2019-8-5 16:54
谢谢分享
作者: chenmingsi    时间: 2019-8-9 17:05
还行呀,不错不错
作者: yazhoulong    时间: 2019-8-11 12:53
找了好久!谢谢楼主的资源!
作者: 嘿嘿嘿迷麟    时间: 2019-8-11 15:09
谢谢楼主,有没有f4的IIC通信的oled例程啊
作者: 那个谁和谁    时间: 2019-8-23 12:04
很好,值得参考。
作者: linraochang    时间: 2019-9-7 22:51
切换不了界面
作者: bmsi001    时间: 2019-9-12 18:16
哪里下载
作者: yiyedd    时间: 2019-9-23 20:38
非常不错的程序,值得看看
作者: kjhisu    时间: 2019-11-27 00:54
终于找到你
作者: a4270    时间: 2019-11-29 15:34
感谢搂主,学习学习
作者: caiweijie    时间: 2019-12-25 16:36
谢谢分享,不错资料
作者: caiweijie    时间: 2019-12-25 17:33
刚好需要,参考参考
作者: fk192313871    时间: 2019-12-25 21:06
感谢 很详细 帮助很大
作者: leihh2005    时间: 2019-12-26 09:37
感谢搂主,学习学习
作者: eluo    时间: 2020-1-5 11:42
NICE,楼主
作者: ben0148    时间: 2020-1-13 11:36
正好需要啊,可是没黑币了!!!
作者: 31261265    时间: 2020-1-17 18:35
还需要配置其他东西吗
作者: suilian6617    时间: 2020-1-18 08:16
谢谢分享,值得学习
作者: 零丁洋    时间: 2020-3-10 15:58
下下来看看,感觉就是那个模块附赠的示例程序啊,不过还是感谢分享了!
作者: 34岁老学生    时间: 2020-3-10 23:58
不错,学习了
作者: schidler    时间: 2020-3-13 04:20
不错,不错,很想看看
作者: 123123啊    时间: 2020-3-20 18:39
感谢分享
作者: zhangkaiy1220    时间: 2020-4-14 10:39
不错的资料,点赞
作者: ZMLZML1009    时间: 2020-4-24 17:55
你的电量,信号,蓝牙显示是怎么通过PC2002生成的?字符模式还是图片模式?
作者: l68715553    时间: 2020-4-25 16:56
不错的资料,点赞
作者: mm1113512    时间: 2020-6-2 23:03
谢谢分享,不错资料
作者: yangyue01    时间: 2020-11-5 17:05
学习下,跑跑看看
作者: HJJ079    时间: 2021-5-15 01:06
打开只有楼主的的QQ,没看到上面那些功能呢。是要改掉注释吗
作者: jery_li    时间: 2022-1-3 21:49
很好的一个例程,学到很多
作者: dashiwork    时间: 2022-1-6 19:57
确实想学习液晶,参考一下程序
