控制57步进电机旋转
aing123
2018-4-23 14:16
控制57步进电机旋转
代码:
int PUL=7; //define Pulse pin
int DIR=6; //define Direction pin
int ENA=5; //define Enable Pin
void setup() {
pinMode (PUL, OUTPUT);
pinMode (DIR, OUTPUT);
pinMode (ENA, OUTPUT);
void loop() {
for (int i=0; i<6400; i++) //Forward 6400 steps
digitalWrite(DIR,LOW);
digitalWrite(ENA,HIGH);
digitalWrite(PUL,HIGH);
delayMicroseconds(100);
digitalWrite(PUL,LOW);
delay(1000);
for (int i=0; i<6400; i++) //Backward 6400 steps
digitalWrite(DIR,HIGH);
delayMicroseconds(50);
delay(1000);
