1602接收信息滚动显示
程序新手
2018-4-28 14:25
1602接收信息滚动显示
我这边 写了一个程序 是1602液晶显示屏通过24l01无线模块接收消息 并滚动显示在1602屏幕上
但是 我写完验证时不是滚动显示 是闪烁显示
各位大声能帮我看看是什么原因吗?
看看哪里出错了。。。
具体程序如下:
#include <reg51.h>
#include <string.h>
#include<intrins.h>
#define ulong unsigned long
#define TX_ADR_WIDTH 5 // 5字节宽度的发送/接收地址
#define TX_PLOAD_WIDTH 4 // 数据通道有效数据宽度
sbit RS = P3^5; //定义端口
sbit RW = P3^6;
sbit EN = P3^4;
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
#define DataPort P0
sbit LED = P2^1;
uchar code TX_ADDRESS[TX_ADR_WIDTH] = {0x34,0x43,0x10,0x10,0x01}; // 定义一个静态发送地址
uchar RX_BUF[TX_PLOAD_WIDTH];
uchar TX_BUF[TX_PLOAD_WIDTH];
uchar flag;
uchar DATA = 0x01;
uchar bdata sta;
sbit RX_DR = sta^6;
sbit TX_DS = sta^5;
sbit MAX_RT = sta^4;
sbit CE = P1^0;
sbit CSN= P1^1;
sbit SCK= P1^2;
sbit MOSI= P1^3;
sbit MISO= P1^4;
sbit IRQ = P1^5;
// SPI(nRF24L01) commands
#define READ_REG 0x00 // Define read command to register
#define WRITE_REG 0x20 // Define write command to register
#define RD_RX_PLOAD 0x61 // Define RX payload register address
#define WR_TX_PLOAD 0xA0 // Define TX payload register address
#define FLUSH_TX 0xE1 // Define flush TX register command
#define FLUSH_RX 0xE2 // Define flush RX register command
#define REUSE_TX_PL 0xE3 // Define reuse TX payload register command
#define NOP 0xFF // Define No Operation, might be used to read status register
// SPI(nRF24L01) registers(addresses)
#define CONFIG 0x00 // 'Config' register address
#define EN_AA 0x01 // 'Enable Auto Acknowledgment' register address
#define EN_RXADDR 0x02 // 'Enabled RX addresses' register address
#define SETUP_AW 0x03 // 'Setup address width' register address
#define SETUP_RETR 0x04 // 'Setup Auto. Retrans' register address
#define RF_CH 0x05 // 'RF channel' register address
#define RF_SETUP 0x06 // 'RF setup' register address
#define STATUS 0x07 // 'Status' register address
#define OBSERVE_TX 0x08 // 'Observe TX' register address
#define CD 0x09 // 'Carrier Detect' register address
#define RX_ADDR_P0 0x0A // 'RX address pipe0' register address
#define RX_ADDR_P1 0x0B // 'RX address pipe1' register address
#define RX_ADDR_P2 0x0C // 'RX address pipe2' register address
#define RX_ADDR_P3 0x0D // 'RX address pipe3' register address
#define RX_ADDR_P4 0x0E // 'RX address pipe4' register address
#define RX_ADDR_P5 0x0F // 'RX address pipe5' register address
#define TX_ADDR 0x10 // 'TX address' register address
#define RX_PW_P0 0x11 // 'RX payload width, pipe0' register address
#define RX_PW_P1 0x12 // 'RX payload width, pipe1' register address
#define RX_PW_P2 0x13 // 'RX payload width, pipe2' register address
#define RX_PW_P3 0x14 // 'RX payload width, pipe3' register address
#define RX_PW_P4 0x15 // 'RX payload width, pipe4' register address
#define RX_PW_P5 0x16 // 'RX payload width, pipe5' register address
#define FIFO_STATUS 0x17 // 'FIFO Status Register' register address
//--定义SPI要使用的 IO--//
void blink(char i);
//--全局函数声明--//
函数: init_io()
描述:
初始化IO
void init_io(void)
CE = 0; // 待机
CSN = 1; // SPI禁止
SCK = 0; // SPI时钟置低
IRQ = 1; // 中断复位
LED = 1; // 关闭指示灯
函数:delay_ms()
描述:
延迟x毫秒
void delay_ms(uchar x)
uchar i, j;
i = 0;
for(i=0; i<x; i++)
j = 250;
while(--j);
j = 250;
while(--j);
函数:SPI_RW()
描述:
根据SPI协议,写一字节数据到nRF24L01,同时从nRF24L01
读出一字节
uchar SPI_RW(uchar byte)
uchar i;
for(i=0; i<8; i++) // 循环8次
MOSI = (byte & 0x80); // byte最高位输出到MOSI
byte <<= 1; // 低一位移位到最高位
SCK = 1; // 拉高SCK,nRF24L01从MOSI读入1位数据,同时从MISO输出1位数据
byte |= MISO; // 读MISO到byte最低位
SCK = 0; // SCK置低
return(byte); // 返回读出的一字节
函数:SPI_RW_Reg()
描述:
写数据value到reg寄存器
uchar SPI_RW_Reg(uchar reg, uchar value)
uchar status;
CSN = 0; // CSN置低,开始传输数据
status = SPI_RW(reg); // 选择寄存器,同时返回状态字
SPI_RW(value); // 然后写数据到该寄存器
CSN = 1; // CSN拉高,结束数据传输
return(status); // 返回状态寄存器
函数:SPI_Read()
描述:
从reg寄存器读一字节
uchar SPI_Read(uchar reg)
uchar reg_val;
//blink(4);
reg_val = SPI_RW(0); // 然后从该寄存器读数据
//delay_ms(200);
return(reg_val); // 返回寄存器数据
函数:SPI_Read_Buf()
描述:
从reg寄存器读出bytes个字节,通常用来读取接收通道
数据或接收/发送地址
uchar SPI_Read_Buf(uchar reg, uchar * pBuf, uchar bytes)
uchar status, i;
for(i=0; i<bytes; i++)
pBuf[i] = SPI_RW(0); // 逐个字节从nRF24L01读出
函数:SPI_Write_Buf()
描述:
把pBuf缓存中的数据写入到nRF24L01,通常用来写入发
射通道数据或接收/发送地址
uchar SPI_Write_Buf(uchar reg, uchar * pBuf, uchar bytes)
uchar status, i;
SPI_RW(pBuf[i]); // 逐个字节写入nRF24L01
函数:RX_Mode()
描述:
这个函数设置nRF24L01为接收模式,等待接收发送设备的数据包
void RX_Mode(void)
CE = 0;
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 接收设备接收通道0使用和发送设备相同的发送地址
SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 使能接收通道0自动应答
SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 使能接收通道0
SPI_RW_Reg(WRITE_REG + RF_CH, 40); // 选择射频通道0x40
SPI_RW_Reg(WRITE_REG + RX_PW_P0, TX_PLOAD_WIDTH); // 接收通道0选择和发送通道相同有效数据宽度
SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07); // 数据传输率1Mbps,发射功率0dBm,低噪声放大器增益
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // CRC使能,16位CRC校验,上电,接收模式
delay_ms(150);
CE = 1; // 拉高CE启动接收设备
函数:TX_Mode()
描述:
这个函数设置nRF24L01为发送模式,(CE=1持续至少10us),
130us后启动发射,数据发送结束后,发送模块自动转入接收
模式等待应答信号。
void TX_Mode(uchar * BUF)
CE = 0;
SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 写入发送地址
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 为了应答接收设备,接收通道0地址和发送地址相同
SPI_Write_Buf(WR_TX_PLOAD, BUF, TX_PLOAD_WIDTH); // 写数据包到TX FIFO
SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x0a); // 自动重发延时等待250us+86us,自动重发10次
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // CRC使能,16位CRC校验,上电
delay_ms(150);
CE = 1;
函数:Check_ACK()
描述:
检查接收设备有无接收到数据包,设定没有收到应答信
号是否重发
uchar Check_ACK(bit clear)
while(IRQ);
sta = SPI_RW(NOP); // 返回状态寄存器
if(TX_DS)
//blink(3);
//blink(5);
if(MAX_RT)
if(clear) // 是否清除TX FIFO,没有清除在复位MAX_RT中断标志后重发
SPI_RW(FLUSH_TX);
SPI_RW_Reg(WRITE_REG + STATUS, sta); // 清除TX_DS或MAX_RT中断标志
IRQ = 1;
if(TX_DS)
return(0x00);
return(0xff);
函数:CheckButtons()
描述:
检查按键是否按下,按下则发送一字节数据
void CheckButtons()
P3 |= 0x00;
if(!(P3 & 0x01)) // 读取P3^0状态
delay_ms(20);
TX_BUF[0] = ~DATA; // 数据送到缓存
//TX_BUF[0] = 0xff; // 数据送到缓存
TX_Mode(TX_BUF); // 把nRF24L01设置为发送模式并发送数据
//LED = ~DATA; // 数据送到LED显示
Check_ACK(0); // 等待发送完毕,清除TX FIFO
delay_ms(250);
delay_ms(250);
LED = 1; // 关闭LED
RX_Mode(); // 设置为接收模式
while(!(P3 & 0x01));
DATA <<= 1;
if(!DATA)
DATA = 0x01;
void blink(char i)
while(i--)
LED = 1;
delay_ms(500);
LED = 0;
delay_ms(500);
uS延时函数,含有输入参数 unsigned char t,无返回值
unsigned char 是定义无符号字符变量,其值的范围是
0~255 这里使用晶振12M,精确延时请使用汇编,大致延时
长度如下 T=tx2+5 uS
void DelayUs2x(unsigned char t)
while(--t);
mS延时函数,含有输入参数 unsigned char t,无返回值
void DelayMs(unsigned char t)
while(t--)
//大致延时1mS
DelayUs2x(245);
DelayUs2x(245);
判忙函数
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
_nop_();
EN_SET;
return (bit)(DataPort & 0x80);
写入命令函数
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙则等待
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
_nop_();
EN_CLR;
写入数据函数
void LCD_Write_Data(unsigned char Data)
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
_nop_();
EN_CLR;
清屏函数
void LCD_Clear(void)
LCD_Write_Com(0x01);
DelayMs(5);
写入字符串函数
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
LCD_Write_Com(0x80 + x); //表示第一行
LCD_Write_Com(0xC0 + x); //表示第二行
while (*s)
LCD_Write_Data( *s);
s ++;
写入字符函数
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0)
LCD_Write_Data( Data);
初始化函数
void LCD_Init(void)
LCD_Write_Com(0x38); /*显示模式设置*/
DelayMs(5);
DelayMs(5);
DelayMs(5);
LCD_Write_Com(0x08); /*显示关闭*/
LCD_Write_Com(0x01); /*显示清屏*/
LCD_Write_Com(0x06); /*显示光标移动设置*/
DelayMs(5);
LCD_Write_Com(0x0C); /*显示开及光标设置*/
函数:main()
描述:
主函数
void main(void)
init_io(); // 初始化IO
LCD_Init();
LCD_Clear();//清屏
// LCD_Write_String(1,1,"A");
sta = SPI_Read(STATUS); // 读状态寄存器
//delay_ms(200);
if(RX_DR) // 判断是否接受到数据
SPI_Read_Buf(RD_RX_PLOAD, RX_BUF, TX_PLOAD_WIDTH); // 从RX FIFO读出数据
flag = 1;
SPI_RW_Reg(WRITE_REG + STATUS, sta); // 清除RX_DS中断标志
if(flag) // 接受完成
if(RX_BUF[0] == 1)
LCD_Write_Char(2,0,'A');
LCD_Write_Char(3,0,'4');
LCD_Write_Char(4,0,'1');
LCD_Write_Com(0x18);//左平移画面 0x1C 是右平移 ,0x18是左移。
blink(2);
if(RX_BUF[0] == 2)
LCD_Write_Char(6,0,'A');
LCD_Write_Char(7,0,'4');
LCD_Write_Char(8,0,'2');
blink(4);
if(RX_BUF[0] == 3)
LCD_Write_Char(2,1,'A');
LCD_Write_Char(3,1,'4');
LCD_Write_Char(4,1,'3');
blink(4);
flag = 0; // 清标志
delay_ms(250);
delay_ms(250);
LED = 1;
LCD_Init();
DelayMs(200);
