标题: 步进电机驱动监测(可正反转) [打印本页]
作者: jijsiejd    时间: 2018-4-28 21:39
标题: 步进电机驱动监测(可正反转)
#include<reg52.h>
uchar code zheng[]={
0xf3,0xf6,0xfc,0xf9};
uchar code fan[]={
0xf9,0xfc,0xf6,0xf3};
//uchar t;
bit flag=0;
uint shijian;
uchar temp;
void delay(uint z)
uint i,j;
for(i=0;i<z;i++)
for(j=0;j<80;j++);
/*void timer_init()
  TMOD=0X01;//???0,??1
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
  ET0=1;
  EA=1;
  TR0=1;
void motor_z()
  uchar i;
  for(i=0;i<4;i++)
    P2=zheng[i];
        delay(shijian);
void motor_f()
  uchar i;
  for(i=0;i<4;i++)
    P2=fan[i];
        delay(shijian);
void keyscan()
  P3=0XFF;
  delay(1);
  if(P3!=0xff)
          temp=P3;
          switch(temp)
            case 0xfe:
               {flag=~flag;break;   }
               case 0xfd:
               {if(shijian<=60)
                 {shijian=50;}
               {shijian=shijian-100;}
               break;  }
               case 0xfb:
               {if(shijian>=600)
                {shijian=650;}
                {shijian=shijian+100;}
               break;  }
               default : break;
          while(temp==P3);
   shijian=350;
  //timer_init();
     keyscan();
     if(flag==0)
           motor_z();
              motor_f();
/*void timer() interrupt 1
  if(t>=200)
    t=0;
    flag=~flag;
  t++;
