C51单片机电子琴与音乐盒设计(世上只有妈妈好)
加勒比还带
2018-5-1 16:51
单片机音乐盒仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
(21.16 KB, 下载次数: 66)
下载附件
2018-5-2 01:19 上传
#include<reg51.h>
int code Yinfu[]={63628,63835,64021,64103,64260,64400,64524,64580};
unsigned char duanma[10]={0xc0,0xf9,0xa4,0XB0,0x99,0x92,0x82,0xF8,0x80,0x90};
sbit beep = P3^3;
unsigned char KEY;
void delay()
int i;
for(i=0;i<240;i++);
void play() interrupt 1
TH0 = Yinfu[KEY]/256;
TL0 = Yinfu[KEY]%256;
beep = ~beep;
unsigned char scan()
unsigned char res;
switch(P1)
case 0xfe:res=0;P0=duanma[1];break;
case 0xfd:res=1;P0=duanma[2];break;
case 0xfb:res=2;P0=duanma[3];break;
case 0xf7:res=3;P0=duanma[4];break;
case 0xef:res=4;P0=duanma[5];break;
case 0xdf:res=5;P0=duanma[6];break;
case 0xbf:res=6;P0=duanma[7];break;
case 0x7f:res=7;P0=duanma[8];break;
return res;
TMOD = 0x01;
IE = 0x82;
P1 = 0xff;
if(P1 != 0xff)
delay();
if(P1 != 0xff)
KEY = scan();
TR0 = 1;
TR0 = 0;
beep = 1;
delay();
#include <reg51.h>
sbit speaker=P3^6;
unsigned char timer0h,timer0l,time,led=1,j=0;
unsigned char flagd=0;
//世上只有妈妈好数据表
code unsigned char sszymmh[]={ 6,2,3, 5,2,1, 3,2,2, 5,2,2, 1,3,2, 6,2,1, 5,2,1,
6,2,4, 3,2,2, 5,2,1, 6,2,1, 5,2,2, 3,2,2, 1,2,1,
6,1,1, 5,2,1, 3,2,1, 2,2,4, 2,2,3, 3,2,1, 5,2,2,
5,2,1, 6,2,1, 3,2,2, 2,2,2, 1,2,4, 5,2,3, 3,2,1,
2,2,1, 1,2,1, 6,1,1, 1,2,1, 5,1,6, 0,0,0
// 音阶频率表 高八位
code unsigned char FREQH[]={
0xF2,0xF3,0xF5,0xF5,0xF6,0xF7,0xF8,
0xF9,0xF9,0xFA,0xFA,0xFB,0xFB,0xFC,0xFC, //1,2,3,4,5,6,7,8,i
0xFC,0xFD,0xFD,0xFD,0xFD,0xFE,
0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,0xFF,
// 音阶频率表 低八位
code unsigned char FREQL[]={
0x42,0xC1,0x17,0xB6,0xD0,0xD1,0xB6,
0x21,0xE1,0x8C,0xD8,0x68,0xE9,0x5B,0x8F, //1,2,3,4,5,6,7,8,i
0xEE,0x44, 0x6B,0xB4,0xF4,0x2D,
0x47,0x77,0xA2,0xB6,0xDA,0xFA,0x16,
void delay(unsigned char t)
unsigned char t1;
unsigned long t2;
for(t1=0;t1<t;t1++)
for(t2=0;t2<6000;t2++)
TR0=0;
void t0int() interrupt 1
…………限于本文篇幅 余下代码请从51黑下载附件…………
单片机期中.rar
(77.18 KB, 下载次数: 91)
2018-5-1 16:50 上传
点击文件名下载附件
下载积分: 黑币 -5
学渣0.0
2018-9-15 12:46
没有proteus文件,图不完整
