STM32 ADC采集,DMA传输 DMA中断处理
lyolve
2018-5-7 22:13
//函数名称:ADC1_Mode_Config(void)
//功能描述:配置ADC1的工作模式为MDA模式
//输入:无
//输出:无
void ADC1_Mode_Config(void)
DMA_InitTypeDef DMA_InitStructure;
ADC_InitTypeDef ADC_InitStructure;
/* DMA channel1 configuration */
DMA_DeInit(DMA1_Channel1);
DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; //ADC地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue; //内存地址 ADC_ConvertedValue[15]一个数组
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
DMA_InitStructure.DMA_BufferSize = 15;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址固定
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址自加
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //半字
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循环传输
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
/* Enable DMA channel1 */
DMA_Cmd(DMA1_Channel1, ENABLE);
DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,ENABLE); //传输结束中断
/* ADC1 configuration */
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //独立ADC模式
ADC_InitStructure.ADC_ScanConvMode = DISABLE ; //禁止扫描模式,扫描模式用于多通道采集
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //开启连续转换模式,即不停地进行ADC转换
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //不使用外部触发转换
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //采集数据右对齐
ADC_InitStructure.ADC_NbrOfChannel = 1; //要转换的通道数目1
ADC_Init(ADC1, &ADC_InitStructure);
/*配置ADC时钟,为PCLK2的8分频,即9MHz*/
RCC_ADCCLKConfig(RCC_PCLK2_Div8);
/*配置ADC1的通道11为55. 5个采样周期,序列为1 */
ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);
/* Enable ADC1 DMA */
ADC_DMACmd(ADC1, ENABLE);
/* Enable ADC1 */
ADC_Cmd(ADC1, ENABLE);
/*复位校准寄存器 */
ADC_ResetCalibration(ADC1);
/*等待校准寄存器复位完成 */
while(ADC_GetResetCalibrationStatus(ADC1));
/* ADC校准 */
ADC_StartCalibration(ADC1);
/* 等待校准完成*/
while(ADC_GetCalibrationStatus(ADC1));
/* 由于没有采用外部触发,所以使用软件触发ADC转换 */
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
//函数名称:DMA1_Channel1_IRQHandler
//功能描述:DMA中断 对AD采集值平均滤波
//输入:无
//输出:无
void DMA1_Channel1_IRQHandler(void)
BYTE i;
WORD ADC_ConvertedValue_TEMP=0;
for(i=0;i<15;i++)
ADC_ConvertedValue_TEMP += ADC_ConvertedValue; } ADC_ConvertedValue_average = ADC_ConvertedValue_TEMP/15; //全局变量ADC_ConvertedValue_average DMA_ClearITPendingBit(DMA1_IT_TC1); DMA_ClearFlag(DMA1_FLAG_TC1);}
//============================================//函数名称:void GPIO_Configuration(void)//功能描述:ADC引脚配置//输入:无//输出:无//============================================void GPIO_Configuration(void){ GPIO_InitTypeDef GPIO_InitStructure; //=======================ADC通道配置======================== GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOB, &GPIO_InitStructure); // PB0,输入时不用设置速率}
//============================================//函数名称:void NVIC_Configuration(void)//功能描述:中断配置//输入:无//输出:无//============================================void NVIC_Configuration(void){ NVIC_InitTypeDef NVIC_InitStructure; /* Configure the NVIC Preemption Priority Bits */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn; NVIC_Init(&NVIC_InitStructure); }
njqlkj
2018-5-9 15:00
你好 这个程序恨我的差不多 能看看完整的转换吗
njqlkj
2018-5-9 15:01
厉害了 还有具体的 吗
DUANQIRUI
2018-11-15 14:16
厉害了 还有具体的 吗
nmgbtzyf
2020-3-9 12:40
也在搞这个,怎么也不进中断,有人帮我看看嘛,
代码在见附件,只不过我是407的,
ADC多通道DMA传输实验.7z
2020-3-9 23:58 上传
点击文件名下载附件
下载积分: 黑币 -5
299.44 KB, 下载次数: 23, 下载积分: 黑币 -5
luzzyman
2020-3-10 15:22
少了一句开启端口时钟
