秒表程序
单片机小白1995
2018-5-8 15:24
秒表程序
* 程序说明 ;使数码管依次显示0-8
#include "io430.h"
#define KeyPort P1IN //独立键盘接在P60~P63
#define CPU_F ((double)1000000)
#define DelayUs(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define DelayMs(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define KEY1 1
#define KEY2 2
#define KEY3 3
#define KEY4 4
#define KEY5 5
uchar KeyScan(void);
#define SMG_DATA P4OUT //573位选信号的输入管脚
#define SMG_WEI P5OUT
//#define CLK_H P6OUT|=BIT6 //595时钟信号的输入置高
//#define CLK_L P6OUT&=~BIT6 //595时钟信号的输入置低
//#define ST_H P6OUT|=BIT5 //595锁存信号置高
//#define ST_L P6OUT&=~BIT5 //595锁存信号置低
//#define DATA_H P6OUT|=BIT4 //595数据信号输入置高
//#define DATA_L P6OUT&=~BIT4 //595数据信号置低
//#define LED_E0 P5OUT&=~BIT7 //数码管 573使能置低
//#define LED_E1 P5OUT|=BIT6 //点阵 573使能置高
uchar uc7leds[17]={0x3f,0x06,0x5b,0x4f, //0,1,2,3,
0x66,0x6d,0x7d,0x07, //4,5,6,7,
0x7f,0x6f,0x77,0x7c, //8,9,A,b,
0x39,0x5e,0x79,0x71,0x00}; //C,d,E,F
uchar jishu=0;
uchar mode=1;
uchar downtime=1;
void PortInit();
uchar number[4] = {0,0,0,0};
void ClockInit();
void display();
void TimerAInit();
void fentime(int num);
void fenshu(int num);
uint b;
WDTCTL=WDTPW+WDTHOLD;
ClockInit(); //时钟初始化
TimerAInit();
PortInit();
uchar jishi=0;
uchar keyvalue=0;
uchar zhu=1;
uchar wait=1;
uchar mode2start=0;
if(b==0)
keyvalue=KeyScan();
if(zhu==1)
if(keyvalue==5)
zhu=0;
if(keyvalue==4)
mode++;
if(mode==4)
mode=1;
number[0]=mode+9;
number[1]=16;
number[2]=16;
number[3]=16;
else if(mode==1)
if(wait)
fentime(0);
wait=0;
if(keyvalue==1)
jishi=!jishi;
if(jishi)
TACTL=TASSEL_1+MC_1+ID_3+TAIE;
TACTL=TASSEL_1+MC_0+ID_3+TAIE;
else if(mode==2)
if(!mode2start)
if(wait)
fentime(60);
wait=0;
if(keyvalue==4)
downtime++;
fentime(downtime*60);
if(keyvalue==1)
mode2start=1;
if(keyvalue==2)
jishi=0;
keyvalue=0;
zhu=1;
wait=1;
mode2start=0;
jishu=0;
mode=1;
downtime=1;
TACTL=TASSEL_1+MC_0+ID_3+TAIE+TACLR;
P2OUT_bit.P0=0;
display();
if(keyvalue!=0)
b=0x8fff;
keyvalue=0;
if(b!=0)
b--;
* PortInit()
* 功能说明 ;IO初始化
* 参数 :无
* 返回值 :无
void PortInit()
P4SEL=0X00;//普通
P4DIR=0XFF;//输出
P5SEL=0X00;//普通
P5DIR=0XF0;//输出
P5OUT=0XFF;
P2SEL = 0x00; //设置IO口为普通I/O模式
P2DIR = 0x01; //设置IO口方向为输出
P2OUT = 0x00; //初始设置为00,即都为低电平
P1SEL = 0x00;
P1DIR = 0x00;
P4OUT=uc7leds[0];
//P6SEL=0X00;
//P6DIR=0XFF;
//P5SEL=0X00;
//P5DIR=0XFF;
//LED_E1;
//LED_E0;
* TimerAInit()
* 功能说明 ;定时器A初始化
* 参数 :无
* 返回值 :无
void TimerAInit()
TACTL=TASSEL_1+MC_0+ID_3+TAIE;//选择ACK,增计数模式,8分频,使能定时器中断
CCR0=4095;
__enable_interrupt();
void ClockInit()
uchar i;
BCSCTL1&=~XT2OFF; //设置XT2为有效
BCSCTL2|=SELM1+SELS;
do{
IFG1&=~OFIFG; //清除振荡器失效标志
for(i=0;i<100;i++)
__no_operation();
}while((IFG1&OFIFG)!=0); //如果振荡失效标志存在则继续循环
IFG1&=~OFIFG;
* TimerA()
* 功能说明 ;定时器A中断处理程序
* 参数 :无
* 返回值 :无
#pragma vector = TIMERA1_VECTOR
__interrupt void TimerA(void)
switch(TAIV)
case 2:break;
case 4:break;
case 10:
jishu++;
if(mode==1)
fentime(jishu);
else if(mode==2)
fentime(downtime*60-jishu);
if(!(downtime*60-jishu))
P2OUT_bit.P0=1;
break;
* uchar KeyScan(void)
* 功能说明 ;按键检测
* 参数 :无
* 返回值 :KeyNum:按下的按键值
uchar KeyScan(void)
uchar keycode;
static uchar sta=0; //不支持连续按
//uchar sta=0; //支持连按
uchar tmp=0;
P1DIR |= 0X1f;
P1OUT = 0X1f;
P1DIR &= 0xe0; //设置P10 P11 P12为输入
if(sta==0) //sta=0 时检测按键是否按下
if((P1IN&0X1f)!=0X1f) // 扫描按键
DelayMs(10);
if((P1IN&0X1f)!=0X1f) //确认按键按下
keycode=(P1IN&0X1f);
switch(keycode) //确认按键
case 0x1e:tmp=1;;break;
case 0x1d:tmp=2;;break;
case 0x1b:tmp=3;;break;
case 0x17:tmp=4;;break;
case 0x0f:tmp=5;;break;
default : ;break;
sta=1;
else if((P1IN&0X1f)!=0X1f) // 确定按键是否松开
DelayMs(10);
if((P1IN&0X1f)!=0X1f) //若是按键松开,sta = 0;
sta=0;
return tmp; //返回按下的按键数
number[0]=num%10;
number[1]=(num%100)/10;
number[2]=(num%1000)/10;
number[3]=num/1000;
number[0]=(num%60)%10;
number[1]=(num%60)/10;
number[2]=(num/60)%10;
number[3]=(num/60)/10;
void display() //数码管显示
static uchar i=0;
i++;
if(i >= 4)
i = 0;
P4OUT =0x00; //消隐
switch(i) //位选
case 3: SMG_WEI=0x10; break;
case 2: SMG_WEI=0x20; break;
case 1: SMG_WEI=0x40; break;
case 0: SMG_WEI=0x80; break;
P4OUT = uc7leds[number
