标题: PCB设计中专业英译术语之形状与尺寸 [打印本页]
作者: 板儿妹0517 时间: 2018-5-11 17:53
1.开料:CutLamination/Material cutting
2.钻孔:Drilling
3.内钻:Inner LayerDrilling
4一次孔:Outer Layer Drilling
5.二次孔:2nd Drilling
6.雷射钻孔:Laser Drilling /Laser Ablation
7.盲(埋)孔钻孔:Blind & Buried Hole Drilling
8.干膜制程:PhotoProcess(D/F)/Dry Film
9.前处理 (Pretreatment)
10.压膜:Dry Film Lamination
11.曝光:Exposure
12.显影:Developing
13.去膜:Stripping
14.压合:Lamination
15:黑化:Black OxideTreatment
16.微蚀:Microetching
17.铆钉组合:eyelet
18.迭板:Lay up
19.压合:Lamination
20.后处理:Post Treatment
21.黑氧化:Black Oxide Removal
22.铣靶:spot face
23.去溢胶:resin flush removal
24.减铜:Copper Reduction
25.水平电镀:HorizontalElectrolytic Plating
26.电镀:Panel plating
27.锡铅电镀:Tin-Lead Plating /Pattern Plating
28.低于 1 mil: Less than 1 mil Thickness
29.高于 1 mil:More than 1 mil Thickness
30.砂带研磨:Belt Sanding
31:剥锡铅:Tin-Lead Stripping
32.微切片: Microsection
33.蚀铜:Etching
34.初检:Touch-up
35.塞孔:Plug Hole
36.防焊(绿漆/绿油):SolderMask
37.C面印刷:Printing Top Side
38.S面印刷:Printing Bottom Side
39.静电喷涂:Spray Coating
40.前处理:Pretreatment
41.预烤:Precure
42.后烘烤:Postcure
43.印刷:Ink Print
44.表面刷磨:Scrub
45.后烘烤:Postcure
46.UV烘烤:UV Cure
47.文字印刷:Printing of Legend
48.喷砂:Pumice/Wet Blasting
49.印可剥离防焊/蓝胶:Peelable Solder Mask)
50.化学前处理,化学研磨:Chemical Milling
51.选择性浸金压膜:Selective Gold Dry Film Lamination
52.镀金:Gold plating
53.喷锡:Hot Air SolderLeveling
54.成型:Profile/Form
55.开短路测试:Electrical Testing
56.终检:Final VisualInspection
57.金手指镀镍金:Gold Finger
58.电镀软金:Soft Ni/Au Plating
59.浸镍金:Immersion Ni/Au / Electroless Ni/Au
60.喷锡:Hot Air Solder Leveling
61.水平喷锡:HorizontalHot Air Solder Leveling
62.垂直喷锡: Vertical Hot Air Solder Leveling
63.超级焊锡:Super Solder
64.印焊锡突点:Solder Bump
65.数控铣/锣板:N/C Routing/Milling
66.模具冲/啤板:Punch
67.板面清洗烘烤:Cleaning & Backing
68.V型槽/V-CUT: V-Cut/V-Scoring
69.金手指斜边:Beveling of G/F
70.短断路测试Electrical Testing/Continuity & Insulation Testing
71.AOI 光学检查:AOI Inspection
72:VRS 目检:Verified & Repaired
73.泛用型治具测试:Universal Tester
74.专用治具测试:Dedicated Tester
75.飞针测试:Flying Probe
76.终检:Final Visual Inspection
77.压板翘:Warpage Remove
78.X-OUT 印刷:X-Out Marking
79.包装及出货:Packing& shipping
80.清洗及烘烤: Final Clean & Baking
81.铜面保护剂:ENTEK Cu-106A/OSP
82.离子残余量测试:Ionic Contamination Test/ Cleanliness Test
83.冷热冲击试验:Thermal cycling Testing
84.焊锡性试验:Solderability Testing
85.雷射钻孔:Laser Ablation
86.雷射钻Tooling孔:Laser ablationTooling Hole
87.雷射曝光对位孔:Laser Ablation Registration Hole
88.雷射Mask制作:Laser Mask
89.雷射钻孔:Laser Ablation
90.AOI检查及VRS:AOI Inspection & Verified & Repaired
91.除胶渣:Desmear
92.专用治具测试:Dedicated Tester
93.飞针测试:Flying Probe
94.压板翘: Warpage Remove
95.底片:Ablation
96.烧溶:laser)
97.切/磨:abrade
98.粗化:abrasion
99.耐磨性:absorption resistance
100.允收:ACC /accept
101.加速腐蚀:accelerated corrosion test
102加速试验:accelerated test
103.速化反应:acceleration
104.加速剂:accelerator
105.允许:acceptable
106.活化液:activator
107.实际在制品:active work in process
108.附着力:adhesion
109.黏着法:adhesive method
110.气泡:air inclusion
111.风刀:air knife
112.不定形的改变:amorphous change
113.总量:amount
114.硝基戊烷:amylnitrite
115.分析仪:analyzer
116环状垫圈;孔环annular ring
117.阳极泥:anodeslime (sludge)
118.阳极清洗:anodizing
119.自动光学检测:AOI/automatic optical inspection
120.引用之文件:applicable documents
121.允收水平抽样:AQL sampling
122.液态光阻:aqueous photoresist
123.纵横比(厚宽比):aspect ratioAs received
124.背光:back lighting
125.垫板:back-up
126.预留在制品:banked work in process
127.基材:base material
128.基准绩效:baseline performance
129.批:batch
130.贝他射线照射法:beta backscattering
131.切斜边;斜边:beveling
132.二方向之变形:biaxial deformation
133.黑化:black-oxide
134.空板:blank panel
135.挖空:blanking
136.弹开:blip
137.气泡:blister blistering
138.吹孔:blow hole
139.板厚错误:board-thickness error
140.黏结层:bonding plies
141.板弯:bow ; bowing
142.破空:break out
143.搭桥;桥接:bridging
144.接单生产:BTO (Build To Order)
145,.烧焦:burning
146.毛边(毛头):burr
147.碳化物:carbide
148.定位梢:carlson pin
149.载运剂:carrier
150.催化:catalyzing
151.阴极溅射法:catholicsputtering
152.隔板;钢板:caul plate
153.校验系统之各种要求:calibration system requirements
154.中心光束法:center beam method
155.集中式投射线:central projection
156.认证:certification
157.倒角 (金手指):chamfer chamfer
158.切斜边;倒角:chamfering
159.特性阻抗:characteristic impedance
160.电量传递过电压:charge transfer overpotential
161.网框:chase
162.棋盘:checkboard
163.蟹和剂:chelator
164.化学键:chemical bond
165.化学蒸着镀:chemical vapor deposition
166.圆周性之孔破:circumferential void
167.包夹金属:clad metal
168.无尘室:clean room
169.间隙:clearance
170.表面处理:Coating/Surface Finish
| 欢迎光临 (http://www.51hei.com/bbs/) |
Powered by Discuz! X3.1 |
