标题: 请问这个光敏程序如何添加一个串口发送模块,实现电脑接受 [打印本页]
作者: gujufeng    时间: 2018-5-13 17:42
#include<reg52.h>
#include<intrins.h>
sbit sda=P2^0;
sbit scl=P2^1;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
                0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  //"F"
void delay()  //5us
void delay1(uint z)//1ms
        uint x,y;
        for(x=z;x>0;x--)
                for(y=120;y>0;y--);
void display(uchar value)
        uchar bai,shi,ge;
        bai=value/100;
        shi=value%100/10;
        ge=value%100%10;
        dula=1;
        P0=table[bai];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfe;
        wela=0;
        delay1(1);
        dula=1;
        P0=table[shi];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfd;
        wela=0;
        delay1(1);
        dula=1;
        P0=table[ge];
        dula=0;
        P0=0xff;
        wela=1;
        P0=0xfb;
        wela=0;
        delay1(1);
void start()
        scl=1;
        _nop_();
        sda=1;
        delay();
        sda=0;
        delay();
        scl=0;
        _nop_();
void stop()
        scl=1;
        _nop_();
        sda=0;
        delay();
        sda=1;
        delay();
void respons()
        scl=1;
        _nop_();
        sda=0;
        delay();
        scl=0;
        _nop_();
void norespons()
        scl=1;
        _nop_();
        sda=1;
        delay();
void init()
        scl=1;
        _nop_();
        sda=1;
        _nop_();
void write_byte(uchar dat)
        uchar i,temp;
        temp=dat;
        for(i=0;i<8;i++)
                scl=0;
                _nop_();
                if((temp&0x80)==0x80)
                        sda=1;          //д1
                        sda=0;          //д0
                scl=1;
                _nop_();
                temp<<=1;
        scl=0;
        _nop_();
uchar read_byte()
        uchar dat,i;
        sda=1;
        _nop_();
        scl=0;
        _nop_();
        for(i=0;i<8;i++)
                scl=1;
                _nop_();
                if(sda)
                        dat|=0x01;
                if(i<7)
                         dat<<=1;
                scl=0;
                _nop_();
        return dat;
void DAC_write(uchar dat)
        start();
        write_byte(0x90);
        respons();
        write_byte(0x40);
        respons();
        write_byte(dat);
        respons();
        stop();
uchar ADC_read(uchar com)
        uchar dat;
        dat=com;
        start();
        write_byte(0x90);
        respons();
        write_byte(com);
        respons();
        start();
        write_byte(0x91);
        respons();
        dat=read_byte();
        norespons();
        stop();
        return dat;
        uchar i=0,ad_value;
        init();
                ad_value=ADC_read(0x42);
                display(ad_value);
                /*DAC_write(i);
                i++;  */
                delay1(1);
