标题: 麻烦各位大神看看有什么问题,电路不工作,无法设置温度 [打印本页]
作者: kaili    时间: 2018-5-17 12:30
#include<reg52.h>#include<reg52.h>
#include<math.h>
float R;
float Kp;
float T;
float Ti;
float Td;
float e2;
float e1,e;
float a0,a1,a2;
#define ui unsigned int
#define uc unsigned char
sbit bj=P2^4;
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdrw=P2^5;
sbit control=P2^3;
char lshi,lge,hshi,hge;
uc num,flag;
ui temp;
sbit dsio=P3^7;
//延时
void delay(ui z)
        uc x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
//DS18B20控制
void dsinit()
        uc i;
        dsio=0;
        i=70;
        while(i--);
        dsio=1;
        i=4;
        while(i--);
void dswritebyte(uc dat)
        uc i,j;
        for(j=0;j<8;j++)
                dsio=0;
                i++;
                dsio=dat&0x01;
                i=6;
                while(i--);
                dsio=1;
                dat>>=1;
uc dsreadbyte()
        uc i,j,byte,b;
        for(j=0;j<8;j++)
                dsio=0;
                i++;
                dsio=1;
                i++;i++;
                b=dsio;
                byte=(byte>>1)|(b<<7);
                i=4;
                while(i--);
        return byte;
void dschangetemp()
        dsinit();
        delay(1);
        dswritebyte(0xcc);
        dswritebyte(0x44);
void dsreadtemp()
        dsinit();
        delay(1);
        dswritebyte(0xcc);
        dswritebyte(0xbe);
ui gettemp()
        int temp;
        uc h,l;
        dschangetemp();
        dsreadtemp();
        l=dsreadbyte();
        h=dsreadbyte();
        temp=h;
        temp<<=8;
        temp|=l;
        temp=temp*0.0625*100+0.5;
        return temp;
//LCD控制程序
void lcdwritecom(uc com)
        lcdrs=0;
        P0=com;
        delay(10);
        lcden=1;
        delay(10);
        lcden=0;
void lcdwritedata(uc date)
        lcdrs=1;
        P0=date;
        delay(10);
        lcden=1;
        delay(10);
        lcden=0;
void lcdinit()
        lcdrw=0;
        lcden=0;
        lcdwritecom(0x38);
        lcdwritecom(0x0c);
        lcdwritecom(0x06);
        lcdwritecom(0x01);
//LCD显示
void lcddisplay(int temp)
        ui  tab[]={0,0,0,-2,0,0};
        lcdwritecom(0x80);
        lcdwritedata('+');
        tab[0]=temp/10000;
        tab[1]=temp%10000/1000;
        tab[2]=temp%1000/100;
        tab[4]=temp%100/10;
        tab[5]=temp%10;
        lcdwritecom(0x81);
        for(num=0;num<6;num++)
                lcdwritedata('0'+tab[num]);
//报警
void baojing()
        float t;
         t=gettemp();
        if(t<3000||t>8500)
        bj=0;
        else bj=1;
void adjust()
        delay(100);
        flag++;
        if(flag==5)flag=1;
        if(flag==1)
                lcdwritecom(0x80+0x44);
                lcdwritecom(0x0f);
         if(flag==2)
                lcdwritecom(0x80+0x45);
                lcdwritecom(0x0f);
        if(flag==3)
                lcdwritecom(0x80+0x47);
                lcdwritecom(0x0f);
        if(flag==4)
                lcdwritecom(0x80+0x48);
                lcdwritecom(0x0f);
void inc()
        delay(100);
        switch(flag)
                case 1:lshi++; if(lshi==10)lshi=0;
                                                lcdwritedata('0'+lshi);
                                                lcdwritecom(0x10);
                                                break;
                case 2:lge++; if(lge==10)lge=0;
                                                lcdwritedata('0'+lge);
                                                lcdwritecom(0x10);
                                                break;
                case 3:hshi++; if(hshi==10)hshi=0;
                                                lcdwritedata('0'+hshi);
                                                lcdwritecom(0x10);
                                                break;
                case 4:hge++; if(hge==10)hge=0;
                                                lcdwritedata('0'+hge);
                                                lcdwritecom(0x10);
                                                break;
void dec()
        delay(100);
        switch(flag)
                case 1:lshi--; if(lshi<0)lshi=9;
                                                lcdwritecom(0x10);
                                                break;
                case 2:lge--; if(lge<0)lge=9;
                                                lcdwritecom(0x10);
                                                break;
                case 3:hshi--; if(hshi<0)hshi=9;
                                                 lcdwritecom(0x10);
                                                break;
                case 4:hge--; if(hge<0)hge=9;
                                                 lcdwritecom(0x10);
                                                break;
//键盘扫描
void keyscan()
        uc test,num;
        num=0;
        test=P1;
        if(test!=0xff)
        delay(5);
        test=P1;
        if(test==0xf7)
                while(P1!=0xff);
                num++;
                        test=P1;
                        if(test!=0xff)
                        delay(5);
                        test=P1;
                        if(test!=0xff)
                                if(test==0xf7)
                                        num++;
                                        if(num==2)
                                        {        lcdwritecom(0x0c);
                                                break;}
                                switch(test)
                                        case 0xfe:adjust();
                                                        break;
                                        case 0xfd:inc();
                                                        break;
                                        case 0xfb:dec();
                                                        break;
                        while(P1!=0xff);
//PID
void PIDinit()
           Kp=2;Ti=4;Td=1;T=1;R=25;
           a0=Kp*(1+T/Ti+Td/T);
           a1=-Kp*(1+(2*Td)/T);
           a2=Kp*(Td/T);
           e2=e1=0;
void PIDdeal()
        float y        ,u ;
        y=gettemp();
        e=y/100-R;
        u=a0*e+a1*e1+a2*e2;
        e2=e1;e1=e;
        if(u>0.5||u<-0.5)
        control=0;
        else control=1;
        uc code tab2[]="SET:20~50C";
        uc i;
        TMOD=0x01;
        TH0=(65535-10900)/256;
        TL0=(65535-10900)%256;
        ET0=1;
        TR0=1;
        lcdinit();
        lcdwritecom(0x87);
        lcdwritedata('C');
        lcdwritecom(0x80+0x40);
        for(i=0;i<10;i++)
                lcdwritedata(tab2) ;
        lshi=2;lge=0;hshi=5;hge=0;
                lcddisplay(gettemp());
                baojing();
            keyscan() ;
                EA=1; while(1);
void t0() interrupt 1
        uc i;
        i++;
        if(i==100)
           void PIDinit();
           void PIDdeal();
作者: zhanghyg    时间: 2018-5-18 14:46
你的程序死在while(1)这里了。还有调用子程序不用加void
