标题: 为什么防真的时候数码管不动 [打印本页]
作者: 天才2333333    时间: 2018-5-23 12:21
标题: 为什么防真的时候数码管不动
#include<STC15F2K60S2.h>
uchar code wela[8]={0xfe,0xfd,0xfc,0xfb,0xef,0xdf,0xcf,0xbf};
uchar code dula[11]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xfb,0x80,0x90,0xbf};
void init();//初始化定时器
void delay(uint z);
void miao();
void fen();
void shi();
void fuhao();
void display();//显示函数
void keyscan();
sbit key1=P3^4; //控制秒分时的闪烁
sbit key2=P3^1; //控制时钟的启动暂停
sbit key3=P3^6; //设置时钟的值
sbit key4=P3^7; //计时和倒计时
uchar hour,second,minute,t0,i,t1,key1_num;
uchar s_flag;//闪烁标志位
uchar count_flag; //计时倒计时标志位
  init();
    keyscan();
        switch(key1_num)
     case 0:
            display();
            break;
     case 1:
           AUXR|=0x00;
            if(s_flag==1)
              P2=wela[5];
                  P0=0xff;
                  delay(1);
                  P2=wela[4];
                  P0=0xff;
                  delay(1);
            if(s_flag==0)
             miao();
                 fuhao();
             fen();
             shi();
             break;
     case 2:
            AUXR|=0x00;
            if(s_flag==1)
              P2=wela[3];
                  P0=0xff;
                  delay(1);
                  P2=wela[2];
                  P0=0xff;
                  delay(1);
             if(s_flag==0)
              fen();
                  fuhao();
              miao();
              shi();
                 break;
    case 3:
            AUXR|=0x00;
            if(s_flag==1)
              P2=wela[1];
                     P0=0xff;
                  delay(1);
                  P2=wela[0];
                  P0=0xff;
                  delay(1);
            if(s_flag==0)
              shi();
                 fuhao();
             miao();
             fen();
             break;
void miao()
  P2=wela[7];
  P0=dula[second%10];
  delay(1);
  P2=wela[6];
  P0=dula[second/10];
  delay(1);
void fen()
   P2=wela[4];
   P0=dula[minute%10];
   delay(1);
   P2=wela[3];
   P0=dula[minute/10];
   delay(1);
void shi()
   P2=wela[1];
   P0=dula[hour%10];
   delay(1);
   P2=wela[0];
   P0=dula[hour/10];
   delay(1);
void fuhao()
   P2=wela[5];
   P0=dula[10];
   delay(1);
   P2=wela[2];
   P0=dula[10];
   delay(1);
void delay(uint z)
  uint x,y;
    for(x=z;x>0;x--)
          for(y=110;y>0;y--);
void Timer2() interrupt 12
if(count_flag==0)
t0++;
if(t0==10)
  t0=0;
  second++;
  if(second==60)
    second=0;
    minute++;
    if(minute==60)
      minute=0;
          hour++;
          if(hour==24)
          hour=0;
if(count_flag==1)
t0++;
if(t0==10)
  t0=0;
  second--;
  if(second==255)
    second=59;
    minute--;
    if(minute==255)
      minute=59;
          hour--;
          if(hour==255)
          hour=23;
void T0_time() interrupt 1
TH0=0x3c;
TL0=0xb0;
t1++;
  if(t1==5)
    t1=0;
    s_flag=!s_flag;
void init()
  TMOD=0x01;
  AUXR&=0xfb;
  T2H=0x3c;
  T2L=0xb0;
  TH0=0x3c;
  TL0=0xb0;
  EA=1;
  IE2|=0x04;
  AUXR|=0x10;
  ET0=1;
  TR0=1;
void keyscan()
  if(key1==0)
    delay(10);
         if(key1==0)
     key1_num++;
         if(key1_num==4)
         key1_num=0;
         while(!key1)
         display();
   if(key2==0)
          delay(10);
          if(key2==0)
            AUXR|=0x00;
           while(!key2)
           display();
   if(key3==0)
         delay(10);
         if(key3==0)
            if(key1_num==1)
                  second++;
                   if(second==60)
                   second=0;
                if(key1_num==2)
                   minute++;
                    if(minute==60)
                        minute=0;
                if(key1_num==3)
                  hour++;
                   if(hour==24)
                         hour=0;
                 while(!key3)
                 display();
        if(key4==0)
           delay(10);
           if(key4==0)
                  count_flag++;
                  if(count_flag==2)
                  count_flag=0;
                while(!key4)
                display();
void display()
miao();
fen();
shi();
fuhao();
作者: 研制就是好    时间: 2018-5-23 15:26
这么长的程序你这程序没问题?
作者: wulin    时间: 2018-5-23 16:28
仿真软件里没有STC15系列,改用51单片机写程序。
作者: 糖醋麻辣Tang    时间: 2018-5-23 19:29
检查调用数码管的函数接口是否有问题,检查代码是否正确
