标题: 求助 51单片机4个74hc595驱动16x16点阵。改32x32 [打印本页]
作者: henry9779    时间: 2018-5-23 18:29
51单片机4个74hc595驱动16x16点阵。程序加仿真成功。但是想改成8个74hc595,驱动32X32的点阵怎么改程序?
改了好久都改不对?求大哥大姐指导一下。
我的程序:
4个74hc595驱动16x16的。
#include<reg51.h>
sbit  si=P2^0;                           //74HC595串行数据段
sbit  sck=P2^1;                           //74HC595移位时钟端
sbit  rck=P2^2;                           //74HC595锁存端
uchar i,j,k,zb;
uchar xsz[32],xsz1[32] ;
uchar code  smsg[8] ={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
uchar code   wz[][32]={
/*--  文字:  我  --*/
/*--  宋体12;  此字体下对应的点阵为:宽x高=16x16   --*/
0xDF,0xFD,0x8F,0xF5,0xE1,0xED,0xEF,0xED,0xEF,0xFD,0x00,0x80,0xEF,0xFD,0xEF,0xDD,
0xAF,0xDD,0xCF,0xED,0xE7,0xF3,0xE9,0xBB,0xEF,0xB5,0xEF,0xAE,0x2B,0x9F,0xF7,0xBF,
/*--  文字:  爱  --*/
0xFF,0xEF,0x7F,0xC0,0x81,0xF7,0xBB,0xF7,0x77,0xFB,0x01,0x80,0xBD,0xBF,0xBE,0xDF,
0x01,0xE0,0xDF,0xFF,0x1F,0xF0,0xAF,0xF7,0x77,0xFB,0xFB,0xFC,0x3D,0xF3,0xC7,0x8F,
/*--  文字:  单  --*/
0xF7,0xF7,0xEF,0xFB,0xDF,0xFD,0x03,0xE0,0x7B,0xEF,0x7B,0xEF,0x03,0xE0,0x7B,0xEF,
0x7B,0xEF,0x03,0xE0,0x7F,0xFF,0x7F,0xFF,0x00,0x80,0x7F,0xFF,0x7F,0xFF,0x7F,0xFF,
/*--  文字:  片  --*/
0xFF,0xFD,0xF7,0xFD,0xF7,0xFD,0xF7,0xFD,0xF7,0xFD,0x07,0xC0,0xF7,0xFF,0xF7,0xFF,
0xF7,0xFF,0x07,0xF8,0xF7,0xFB,0xF7,0xFB,0xF7,0xFB,0xFB,0xFB,0xFB,0xFB,0xFD,0xFB,
/*--  文字:  机  --*/
0xF7,0xFF,0x77,0xF0,0x77,0xF7,0x77,0xF7,0x40,0xF7,0x77,0xF7,0x73,0xF7,0x63,0xF7,
0x55,0xF7,0x55,0xF7,0x76,0xF7,0x77,0xB7,0x77,0xB7,0xB7,0xB7,0xB7,0x8F,0xD7,0xFF,
0xE7,0xE7,0xC3,0xC3,0x81,0x81,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x80,
0x03,0xC0,0x07,0xE0,0x07,0xE0,0x0F,0xF0,0x1F,0xF8,0x3F,0xFC,0x3F,0xFC,0x7F,0xFE, /*"心",5*/
void ys (uchar  a)
        uchar b,c;
        for (b=a;b>0;b--)
                for (c=110;c>0;c--);
void fs(uchar  a)
        uchar b;
        sck=0;
        rck=0;
        for (b=8;b>0;b--)
                        a=a<<1;                                          //左移一位
                        si=CY;
                        sck=1;
                        sck=0;
void xs()
         for (i=0,j=0;i<16;i++)                           //扫描行,16行循环16次
                 if (i<8)
                                fs(smsg[j]);
                                fs(0x00);
                                fs(0x00);
                                fs(smsg[j]);
                j++;
                if(j==8)
                j=0;
                fs(xsz[2*i+1]);
                fs(xsz[2*i]);
                rck=1;
                ys(3);
void co(uchar *p,uchar *p1)
        uchar a;
        for (a=0;a<16;a++)
                   p[a*2]=p1[a*2];
                   p[a*2+1]=p1[a*2+1];
void  shy(uchar e, uchar g,uchar *p1)
        uchar a,b,c,d=0,f=31;
        for (a=0;a<16;a++)
        if(g==1)
                        for (b=0;b<30;b++)
                                xsz[b]=xsz[b+2];
                        if(p1==0)
                                  xsz[30]=0xff;
                                  xsz[31]=0xff;
                                  xsz[30]=p1[d++];
                                  xsz[31]=p1[d++];
                        for (c=e;c>0;c--)
                          xs();
                        for (b=29;b>0;b--)
                                xsz[b+2]=xsz[b];
                        xsz[2]=xsz[0];
                        if(p1==0)
                                  xsz[1]=0xff;
                                  xsz[0]=0xff;
                        xsz[1]=p1[f--];
                        xsz[0]=p1[f--];
                        for (c=e;c>0;c--)
                          xs();
void  zyy(uchar a,uchar b,uchar  *p)
        uchar i,j,k,c;
        for (i=0;i<16;i++)
                        if(p==0)
                                        xsz1[2*i]=0xff;
                                        xsz1[2*i+1]=0xff;
                                        xsz1[2*i]=p[2*i];
                                        xsz1[2*i+1]=p[2*i+1];
        if(b==1)
        for (k=0;k<16;k++)
                for(i=0;i<16;i++)
                        xsz[i*2+1]=xsz[i*2+1]<<1;
                        xsz[i*2]=xsz[i*2]<<1;
                        if (CY==1)
                                xsz[i*2+1]=xsz[i*2+1]|0x01;
                        xsz1[i*2+1]=xsz1[i*2+1]<<1;
                        if (CY==1)
                                xsz[i*2]=xsz[i*2]|0x01;
                        xsz1[i*2]=xsz1[i*2]<<1;
                        if (CY==1)
                                xsz1[i*2+1]=xsz1[i*2+1]|0x01;
                for (j=a;j>0;j--)
                        xs();
                for (k=0;k<16;k++)
                        for(i=0;i<16;i++)
                                xsz[i*2]=xsz[i*2]>>1;
                                c=xsz[i*2+1]&0x01;
                                xsz[i*2+1]=xsz[i*2+1]>>1;
                                if (c)
                                        xsz[i*2]=xsz[i*2]|0x80;
                                c=xsz1[i*2]&0x01;
                                xsz1[i*2]=xsz1[i*2]>>1;
                                if (c)
                                        xsz[i*2+1]=xsz[i*2+1]|0x80;
                                c=xsz1[i*2+1]&0x01;
                                xsz1[i*2+1]=xsz1[i*2+1]>>1;
                                if (c)
                                        xsz1[i*2]=xsz1[i*2]|0x80;
                        for (j=a;j>0;j--)
                                xs();
void main ()
        while (1)
        co(xsz,wz[5]);
        shy(10,1,wz[0]);
        shy(10,1,wz[1]);
        shy(10,0,wz[2]);
        shy(10,1,wz[3]);
        shy(10,0,wz[4]);
        shy(10,1,0);
        zyy(10,0,wz[0]);
        zyy(10,1,wz[1]);
        zyy(10,0,wz[2]);
        zyy(10,1,wz[3]);
        zyy(10,0,wz[4]);
        zyy(10,1,0);
        co(xsz,wz[5]);
