单片机LCD1602实时时钟 为什么第二行的“T”为什么显示不出来?
迈特拉布
2018-5-28 08:02
哪位大神帮我看看为什么 LCD的第二行的“T”为什么显示不出来?下面是我的代码
#include <reg52.h>
#include <string.h>
#include<intrins.h>
sbit SDA=P1^0; // DS1302数据线
sbit CLK=P1^1; //DS1302时钟线
sbit RST=P1^2; //DS1302复位线
sbit RS=P2^0;
sbit RW=P2^1;
sbit EN=P2^2;
uchar *WEEK[]={"SUN","TUS","MON","WEN","THU","FRI","SAT"};
uchar LCD_DSY_BUFFER1[]={"Date 00-00-01 "}; //LCD显示缓冲
uchar LCD_DSY_BUFFER2[]={"Time 00:00:00 "};
uchar DateTime[7]; //所读取的日期时间
void DelayMS(uint x)
uchar i;
while(x--) for(i=0;i<120;i++);
void DS1302_Write_Byte(uchar x)
uchar i;
for(i=0;i<8;i++)
SDA=x&1;
CLK=1;
CLK=0;
x>>=1;
uchar DS1302_Read_Byte()
uchar i,b,t;
for(i=0;i<8;i++)
b>>=1;
t=SDA;
b|=t<<7;
CLK=1;
CLK=0;
return b/16*10+b%16;
uchar Read_Data(uchar addr)
uchar dat;
RST=0;
CLK=0;
RST=1;
DS1302_Write_Byte(addr);
dat=DS1302_Read_Byte();
CLK=1;
RST=0;
return dat;
void GetTime()
uchar i;
for(i=0;i<7;i++)
DateTime[i]=Read_Data(0x81+2*i);
uchar Read_LCD_State()
uchar state;
RS=0;
RW=1;
EN=1;
DelayMS(1);
state=P0;
EN=0;
DelayMS(1);
return state;
void LCD_Busy_Wait()
while((Read_LCD_State()&0x08)==0x80);
DelayMS(5);
void Write_LCD_Data(uchar dat) //写数据
LCD_Busy_Wait();
RS=1;
RW=0;
EN=0;
P0=dat;
EN=1;
DelayMS(1);
EN=0;
void Write_LCD_Command(uchar cmd)//写命令
LCD_Busy_Wait();
RS=0;
RW=0;
EN=0;
P0=cmd;
EN=1;
DelayMS(1);
EN=0;
void Init_LCD() //LCD初始化
Write_LCD_Command(0x38); DelayMS(1);
Write_LCD_Command(0x01); DelayMS(1);
Write_LCD_Command(0x06); DelayMS(1);
Write_LCD_Command(0x0C); DelayMS(1);
void Set_LCD_POS(uchar p)
Write_LCD_Command(p+0x80);
void Display_LCD_String(uchar p,uchar *s)
uchar i;
Set_LCD_POS(p);
for(i=0;i<16;i++)
Write_LCD_Data(s[i]);
DelayMS(1);
void Format_DateTime(uchar d,uchar *a)
a[0]=d/10+'0';a[1]=d%10+'0';
Init_LCD();
GetTime();
Format_DateTime(DateTime[6],LCD_DSY_BUFFER1+5); //年
Format_DateTime(DateTime[4],LCD_DSY_BUFFER1+8); //月
Format_DateTime(DateTime[3],LCD_DSY_BUFFER1+11); //日
strcpy(LCD_DSY_BUFFER1+13,WEEK[DateTime[5]]); //week
Format_DateTime(DateTime[2],LCD_DSY_BUFFER2+5); //hour
Format_DateTime(DateTime[1],LCD_DSY_BUFFER2+8);
Format_DateTime(DateTime[0],LCD_DSY_BUFFER2+11);
Display_LCD_String(0x00,LCD_DSY_BUFFER1);
Display_LCD_String(0x40,LCD_DSY_BUFFER2);
QIANLILI
2018-5-28 23:00
uchar i;
Set_LCD_POS(p);
for(i=0;i<16;i++) //
你这里显示时用的是循环16次。
Write_LCD_Data(s[ i]);
DelayMS(1);
而上面定义的
Date 00-00-01
//这里定义了15个字符 都没满16个
Time 00:00:00
//这里定义了14个字符 都没满16个
应该改成
Date 00-00-01
//后面多加个空格
Time 00:00:00
//后面多加2个空格
其它程序没问题。我已仿真测试过。
迈特拉布
2018-5-29 10:16
uchar i;
谢谢您
