标题: 彩灯控制器源码分享 [打印本页]
作者: 林晚风    时间: 2018-6-2 11:39
标题: 彩灯控制器源码分享
#include<reg51.h>
const tab1[]={0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F};
const tab2[]={0xFF,0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00};
const tab3[]={0xFF,0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x00};
const tab4[]={0xFF,0xFE,0xFA,0xEA,0xAA,0x2A,0x0A,0x02,0x00};           //1,3,5,7
const tab5[]={0xFF,0x7F,0x5F,0x57,0x55,0x54,0x50,0x40,0x00};      //2,4,6,8
uchar key=0;
uchar state=0;
uchar stateTemp=0;
uchar flag=0;
void delay(uint n)//延时
{  uint i;
        for(i=0;i<n;i++)
void fun1(void)
        P0=0x00;
        P2=0x00;
        delay(30000); //        fun1全亮
        P0=0xff;
        P2=0xff;
        delay(30000);
  void fun2(void)
        uchar i;
          for(i=0;i<8;i++)  //向上逐次单个点亮
        P2=tab1[7-i];
        P2=tab1[7-i];
        delay(10000);
        if(state!=2)
                P0=0xFF;
                P2=0xFF;
                return;
        P2=0xFF;
        for(i=0;i<8;i++)
        P0=tab1[7-i];
        delay(10000);
         if(state!=2)
                P0=0xFF;
                P2=0xFF;
                return;
        P0=0xFF;
        for(i=0;i<8;i++)   //向下逐次单个点亮
         P0=tab1[i];
         delay(10000);
         if(state!=2)
                P0=0xFF;
                P2=0xFF;
                return;
        P0=0xFF;
        for(i=0;i<8;i++)
          P2=tab1[i];
          delay(10000);
           if(state!=2)
                        P0=0xFF;
                           P2=0xFF;
                           return;
        P2=0xFF;
void fun3(void)
        uchar i;
          for(i=0;i<9;i++)
        P0=tab4[i];
        P2=tab5[i];
        delay(25000);
        if(state!=3)
                P0=0xFF;
                   P2=0xFF;
                   return;
        for(i=0;i<3;i++)
        P0=0xAA;
        P2=0xAA;
        delay(20000);
          P0=0x55;
        P2=0x55;
        delay(20000);
        if(state!=3)
                P0=0xFF;
                  P2=0xFF;
                  return;
        for(i=0;i<9;i++)
        P0=tab4[8-i];
        P2=tab5[8-i];
        delay(25000);
    if(state!=3)
                P0=0xFF;
                  P2=0xFF;
                  return;
void fun4(void)
        uchar i;
           for(i=0;i<9;i++) //向上逐个点亮
        P2=tab3[i];
          delay(10000);
        if(state!=4)
                  P0=0xFF;
                P2=0xFF;
                  return;
        for(i=0;i<9;i++)
        P0=tab3[i];
          delay(10000);
        if(state!=4)
                P0=0xFF;
                   P2=0xFF;
                  return;
        for(i=0;i<9;i++) //向下逐个熄灭
        P0=tab3[8-i];
        delay(10000);
        if(state!=4)
                P0=0xFF;
                  P2=0xFF;
                return;
          P0=0xFF;
          for(i=0;i<9;i++)
          P2=tab3[8-i];
          delay(10000);
        if(state!=4)
                P0=0xFF;
                P2=0xFF;
                return;
          P2=0xFF;
        for(i=0;i<9;i++)   //向下逐个点亮
        {    P0=tab2[i];
          delay(10000);
        if(state!=4)
                  P0=0xFF;
                  P2=0xFF;
                  return;
        for(i=0;i<9;i++)
        P2=tab2[i];
        delay(10000);
        if(state!=4)
                P0=0xFF;
                P2=0xFF;
                return;
        for(i=0;i<9;i++)   //向上逐个熄灭
          {    P2=tab2[8-i];   delay(10000);
        if(state!=4)
                P0=0xFF;    P2=0xFF;    return;
        P2=0xFF;
        for(i=0;i<9;i++)
        {   P0=tab2[8-i];   delay(10000);
        if(state!=4)
                {    P0=0xFF;    P2=0xFF;    return;
        P0=0xFF;
void timer0(void)interrupt 1 using 1
{         TL0 = 0x00;   //重置初值
        TH0 = 0xBE;
        TL0 = 0xE5;
        key=P1;
        switch(key)
        case 0xF6:state=1;stateTemp=1;break;
        case 0xFD:state=2;stateTemp=2;break;
        case 0xFB:state=3;stateTemp=3;break;
        //case 0xF7:state=4;stateTemp=4;break;
        default:break;
void _int()interrupt 2 using 2
          if(flag==0)
        {state=5;   flag|=1;  }
  {   state=stateTemp;       flag&=0;    }
        IT1=1;
        IE|=0x86;
        TMOD= 0x21;
        TH0 = 0xBE;
        TL0 = 0xE5;
        ES  = 0;       //禁止串口中断
        TR0 = 1;       //开启定时器0,开始定时
                switch(state)
                case 1:fun1();break;
                case 2:fun2();break;
                case 3:fun3();break;
                case 4:fun4();break;
                case 5:P0=0x00;P2=0x00;break;//中断全亮
                default:  break;//fun1();fun2();fun3();fun4();break;
