基于51单片机的1602刷屏显示
ssy111222ssy
2018-6-11 14:43
基于51单片机的1602刷屏显示
/*描述: *
* 上电后液晶屏先显示信息,接着按下S2,定时开始,再次按下 *
* S2暂停,第3次按下显示累积计时,第4次按下暂停计时,任何时候按下S3*
* 计数清零。 *
#include <reg51.h>
#include <intrins.h>
uchar KeyCount=0;
sbit S2 = P3^0;
sbit S3 = P3^1;
sbit BEEP = P2^3; //蜂鸣器
uchar code cdis1[ ] = {" STOPWATCH 0 "};
uchar code cdis2[ ] = {" QX-MCS51 "};
uchar code cdis3[ ] = {"TIME "};
uchar code cdis4[ ] = {" BEGIN COUNT 1 "};
uchar code cdis5[ ] = {" PAUSE COUNT 2 "};
uchar code cdis6[ ] = {" BEGIN COUNT 3 "};
uchar code cdis7[ ] = {" PAUSE COUNT 4 "};
uchar code cdis8[ ] = {" "};
sbit LCD_RS = P3^5;
sbit LCD_RW = P3^6;
sbit LCD_EN = P3^4;
sbit dula=P2^6;
sbit wela=P2^7;
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
uchar display[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00};
uchar display2[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
延时函数
void Delay(uint num)//延时函数
while( --num );
蜂鸣器响一声
void beep()
unsigned char y;
for (y=0;y<180;y++)
BEEP=!BEEP; //BEEP取反
Delay(70);
BEEP=1; //关闭蜂鸣器
延时函数1
void delay1(int ms)
unsigned char n;
while(ms--)
for(n = 0; n<250; n++)
_nop_();
_nop_();
_nop_();
_nop_();
*写指令数据到LCD *
*RS=L,RW=L,E=高脉冲,D0-D7=指令码。 *
void lcd_wcmd(uchar cmd)
// while(lcd_busy());
LCD_RS = 0;
// LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = cmd;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
Delay(10);
*写显示数据到LCD *
*RS=H,RW=L,E=高脉冲,D0-D7=数据。 *
void lcd_wdat(uchar dat)
LCD_RS = 1;
// LCD_RW = 0;
LCD_EN = 0;
P0 = dat;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
Delay(10);
* LCD初始化设定 *
void lcd_init()
LCD_RW = 0;
dula=0;
wela=0;
delay1(15);
lcd_wcmd(0x01); //清除LCD的显示内容
lcd_wcmd(0x38); //16*2显示,5*7点阵,8位数据
delay1(5);
lcd_wcmd(0x38);
delay1(5);
lcd_wcmd(0x38);
delay1(5);
lcd_wcmd(0x0c); //开显示,不显示光标
delay1(5);
delay1(5);
* 设定显示位置 *
void lcd_pos(uchar pos)
lcd_wcmd(pos | 0x80); //数据指针=80+地址变量
显示函数
void play()
uchar i;
for(i=0;i<6;i++)
display2[i]=display[i]+0x30;
display2[7]=display[6]/10+0x30; //时单位数据处理
display2[6]=display[6]%10+0x30;
lcd_pos(0x45);
lcd_wdat(display2[7]); //显示时
lcd_wdat(display2[6]);
lcd_wdat(0x3a); //显示':'
lcd_wdat(display2[5]); //显示分
lcd_wdat(display2[4]);
lcd_wdat(display2[3]); //显示秒
lcd_wdat(display2[2]);
lcd_wdat(display2[1]); //显示毫秒
lcd_wdat(display2[0]);
主函数
main()
uchar m;
TMOD=0x01;
TH0=0xdc; TL0=0x00; //50ms定时
EA=1; ET0=1;
lcd_init();
lcd_pos(0x00); //设置显示位置为第一行
for(m=0;m<16;m++)
lcd_wdat(cdis1[m]); //显示字符
lcd_pos(0x40); //设置显示位置为第二行
for(m=0;m<16;m++)
lcd_wdat(cdis2[m]); //显示字符
delay1(60);
delay1(100);
for(m=0;m<16;m++)
lcd_wdat(cdis3[m]);
if(S2==0)
KeyCount++; //计数
beep();
delay1(100);
switch (KeyCount)
case 1:
TR0=1; //启动中断
lcd_pos(0x00);
for(m=0;m<16;m++)
lcd_wdat(cdis4[m]);
break;
case 2:
TR0=0; //停止中断
lcd_pos(0x00);
for(m=0;m<16;m++)
lcd_wdat(cdis5[m]);
break;
case 3:
TR0=1; //启动中断
lcd_pos(0x00);
for(m=0;m<16;m++)
lcd_wdat(cdis6[m]);
break;
case 4:
TR0=0; //停止中断
lcd_pos(0x00);
for(m=0;m<16;m++)
lcd_wdat(cdis7[m]);
break;
default:
TR0=0; //停止中断
break;
if(S3==0)
TR0=0; //停止中断
KeyCount=0;
for(m=0;m<8;m++)
display[m]=0x00; //计时单元清零
for(m=0;m<16;m++)
lcd_wdat(cdis1[m]);
beep();
delay1(100);
play();
* Time0中断函数 *
void Time0(void) interrupt 1 using 0
TH0=0xdc; //10ms定时
TL0=0x00;
display[0]++; //0.01S
if(display[0]==10)
display[0]=0;
display[1]++; //0.1S
if(display[1]==10)
display[1]=0;
display[2]++; //秒个位
if(display[2]==10)
display[2]=0;
display[3]++; //秒十位
if(display[3]==6)
display[3]=0;
display[4]++; //分个位
if(display[4]==10)
display[4]=0;
display[5]++; //分十位
if(display[5]==6)
display[5]=0;
display[6]++; //时
if(display[6]==24)
display[6]=0;
