标题: 12864用图形方式显示数字有乱码 [打印本页]
作者: 835290448    时间: 2018-6-12 21:05
如图,出现这种乱码怎么破
#include "reg52.h"          //包含头文件
#define uint  unsigned int
sbit RS=P2^5;    //命令/数据选择
sbit RW=P2^4;    //读写口
sbit  E=P2^3;    //锁存控制
sbit RES = P2^0; //复位
sbit PSB = P2^2; //串并选择
extern uchar disp[14];
//图片数字方体
uchar code tab[12][64]={
        {// 图片数字0
         0x00,0x00,0x3F,0xFC,0x5F,0xFA,0x6F,0xF6,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,
         0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x60,0x06,0x40,0x02,0x00,0x00,
         0x40,0x02,0x60,0x06,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,
         0x70,0x0E,0x70,0x0E,0x70,0x0E,0x6F,0xF6,0x5F,0xFA,0x3F,0xFC,0x00,0x00,0x00,0x00},
        {// 图片数字1
         0x00,0x00,0x00,0x20,0x00,0x60,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,
     0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0x60,0x00,0x20,0x00,0x00,0x00,0x20,
         0x00,0x60,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0xE0,
         0x00,0xE0,0x00,0xE0,0x00,0xE0,0x00,0x60,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00},
        {// 图片数字2
         0x00,0x00,0x3F,0xFC,0x1F,0xFA,0x0F,0xF6,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,
         0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x06,0x1F,0xFA,0x3F,0xFC,
         0x5F,0xF8,0x60,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,
         0x70,0x00,0x70,0x00,0x70,0x00,0x6F,0xF8,0x5F,0xFC,0x3F,0xFE,0x00,0x00,0x00,0x00},
        {// 图片数字3
         0x00,0x00,0x7F,0xFC,0x3F,0xFA,0x1F,0xF6,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,
     0x1F,0xFA,0x00,0x06,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,
     0x00,0x0E,0x00,0x0E,0x00,0x0E,0x1F,0xF6,0x3F,0xFA,0x7F,0xFC,0x00,0x00,0x00,0x00},
        {// 图片数字4
         0x00,0x00,0x40,0x02,0x60,0x06,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,
         0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x60,0x06,0x5F,0xFA,0x3F,0xFC,
         0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x06,0x00,0x02,0x00,0x00,0x00,0x00},
        {// 图片数字5
         0x00,0x00,0x3F,0xFC,0x5F,0xF8,0x6F,0xF0,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,
         0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x70,0x00,0x60,0x00,0x5F,0xF8,0x3F,0xFC,
         0x00,0x0E,0x00,0x0E,0x00,0x0E,0x0F,0xF6,0x1F,0xFA,0x3F,0xFC,0x00,0x00,0x00,0x00},
        {// 图片数字6
         0x5F,0xFA,0x60,0x06,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,0x70,0x0E,
        {// 图片数字7
         0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x06,0x00,0x02,0x00,0x00,
         0x00,0x02,0x00,0x06,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,0x00,0x0E,
        {// 图片数字8
        {// 图片数字9
        {// 图片":"
     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
     0x03,0xC0,0x03,0xC0,0x03,0xC0,0x03,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xC0,0x03,0xC0,0x03,0xC0,0x03,0xC0,
     0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
         {// 图片" "
//延时函数
void delay(uint time)         //int型数据为16位,所以最大值为65535
  uint  i,j;             //定义变量i,j,用于循环语句
  for(i=0;i<time;i++)    //for循环,循环50*time次
     for(j=0;j<100;j++); //for循环,循环50次
//查忙
void checkbusy()
   RS=0;                   //命令/数据选择,为0时选择命令
   RW=1;                   //读/写选择,为1时选择读
   E=1;                    //使能
   while((P0&0x80)==0x80); //查忙标志位,等待标志位为0,即表示写入完毕
   E=0;                    //关闭读写
//向LCD写一命令
void wcode(uchar cmdcode)
   checkbusy();            //查忙
   RW=0;                   //读/写选择,为0时选择写
   E=1;                    //使能
   P0=cmdcode;             //送入命令
   delay(20);              //等待写入
   E=0;                    //关闭读写
//向LCD写一数据
void wdata(uchar dispdata)
   checkbusy();            //查忙
   RS=1;                   //命令/数据选择,为1时选择数据
   E=1;                    //使能
   P0=dispdata;            //送入数据
   delay(20);              //等待写入
   E=0;                    //关闭读写
//LCD 初始化
void InitLCD()
   PSB=1;             //设置为8BIT并口工作模式
   RES=0;             //复位
   delay(10);         //延时
   RES=1;             //关复位
   wcode(0x30);       //选择基本指令集
   wcode(0x0c);       //开显示(无游标、不反白)
   wcode(0x01);       //清除显示,并且设定地址指针为00H
   wcode(0x06);       //指定在资料的读取及写入时,设定游标的移动方向及指定显示的移位
   wcode(0x01);       //清屏
//任意位置显示字符串
/*void dis(uchar x,uchar y,uchar code *s)
{                                     //x为横坐标,y位纵坐标,*s表示指针,为数据的首地址
switch(y)                            //选择纵坐标
          case 0: wcode(0x80+x);break;    //第1行
          case 1: wcode(0x90+x);break;    //第2行
          case 2: wcode(0x88+x);break;    //第3行
          case 3: wcode(0x98+x);break;    //第4行
      default:break;
   while(*s>0)                        //写入数据,直到数据为空
      wdata(*s);                      //写数据
      delay(10);                      //等待写入
      s++;                            //下一字符
//功能:大数字(图片)
void shijianshuzi(uchar add,uchar bata)
  uchar i,j=0;
        wcode(0x36);          //开启拓展指令集
        for(i=0;i<16;i++)
                wcode(0x90+i);
                wcode(0x80+add);
                wdata(tab[bata][j++]);
        for(i=0;i<16;i++)
                wcode(0x80+i);
                wcode(0x88+add);
        wcode(0x30);       //恢复基本指令集
//功能:LCD显示第一行
/*void xian1()
  wcode(0x80);              //设置第一行显示地址
  wdata('2');
  wdata('0');               //显示20
  wdata(disp[13]);   //显示年
  wdata(disp[12]);
  wdata('-');        //显示"-"
  wdata(disp[9]);   //显示月
        wdata(disp[8]);   //显示月
  wdata('-');
  wdata(disp[7]);   //显示日
        wdata(disp[6]);   //显示日
  switch(disp[10])       //显示星期
  case 0x31:dis(6,0,"周一"); break;
  case 0x32:dis(6,0,"周二"); break;
  case 0x33:dis(6,0,"周三"); break;
        case 0x34:dis(6,0,"周四"); break;
        case 0x35:dis(6,0,"周五"); break;
        case 0x36:dis(6,0,"周六"); break;
        case 0x37:dis(6,0,"周日"); break;
    default:break;
//功能:LCD显示第二行
void xian2()
  shijianshuzi(0,1);         //时十位
        shijianshuzi(1,8);         //时个位
        shijianshuzi(2,10);
        shijianshuzi(3,3);         //分十位
        shijianshuzi(4,3);         //分个位
        shijianshuzi(5,10);
        shijianshuzi(6,4);         //秒十位
        shijianshuzi(7,4);         //秒个位
   InitLCD();                             //初始化液晶
   while(1)                              //进入死循环,防止看门狗复位
                        xian2();
作者: 会飞的大象    时间: 2019-4-19 09:58
请问解决了吗,我的也出现同样的问题
