标题: STM32 spi从机代码 [打印本页]
作者: daizia    时间: 2018-6-13 17:09
标题: STM32 spi从机代码
  1. // 硬件连接:
  2. // STM32(作为从设备)    外部设备
  3. // PB12-SPI2-NSS------------>  CS
  4. // PB13-SPI2-SCK------------->CLK
  5. // PB14-SPI2-MISO----NC
  6. // PB15_SPI2-MOSI----------->data
  7. // STM32作为从设备的时候,获取数据的接口为MOSI(PB15),STM32只需要从SPI接口获取数据,不需要发送数据,因此MISO(PB14)悬空。
  8. //SPI2作为从机接口配置
  9. void SPI_slave(void)
  10. {
  11.     GPIO_InitTypeDef GPIO_InitStructure;
  12.     SPI_InitTypeDef SPI_InitStructure;
  13.     NVIC_InitTypeDef   NVIC_InitStructure;
  14.     //Enable SPI2 clock and GPIO clock for SPI2 and SPI
  15.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE);
  16.     RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  17.     //IO初始化
  18.     //Configure SPI2 pins: SCK, MISO and MOSI
  19.     GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_12|GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
  20.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  21.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  22.     GPIO_Init(GPIOB, &GPIO_InitStructure);
  23.     //1st phase: SPI2 slave
  24.     //SPI1 Config
  25.     SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_RxOnly;//只接收,不发送,这个地方是重点,如果设置为单工通信是不能实现数据采集的。
  26.     SPI_InitStructure.SPI_Mode = SPI_Mode_Slave; //从机模式
  27.     SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //数据位为8
  28.     SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //不发送数据时,时钟线为高
  29.     SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //在第二个沿进行采样
  30.     SPI_InitStructure.SPI_NSS = SPI_NSS_Hard; //硬NSS
  31.     SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  32.     SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //MSB优先
  33.     SPI_InitStructure.SPI_CRCPolynomial = 7;
  34.     SPI_Init(SPI2, &SPI_InitStructure);
  35.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); //使用中断进行接收,因此设置NVIC的优先机组,1表示1bit抢占优先级
  36.     NVIC_InitStructure.NVIC_IRQChannel = SPI2_IRQn;
  37.     NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  38.     NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
  39.     NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  40.     NVIC_Init(&NVIC_InitStructure);
  41.     /* Enable SPI2 RXNE interrupt */
  42.     SPI_I2S_ITConfig(SPI2,SPI_I2S_IT_RXNE,ENABLE);
  43.     //Enable SPI2
  44.     //SPI_Cmd(SPI2, ENABLE); //先不启动SPI,在收到特定命令的时候再启动
  45. }
  46. //中断服务程序
  47. void SPI2_IRQHandler(void)
  48. {
  49.     //接收数据
  50.     //printf("SPI_IRQ %d\n",RxIdx);
  51.     SPI2_Buffer_Rx[RxIdx++] = SPI_I2S_ReceiveData(SPI2);
  52. }
  53. int main(void)
  54. {
  55.     int i;
  56.         SystemInit();        /* 配置系统时钟为 72M */
  57.         LEDKEY_GPIOInit();
  58.         USART_GPIOInit();
  59.         SysTick_Configuration();
  60.         USART_Configuration(USART1, 9600);
  61.         SPI_slave();
  62.         LED1_ON;
  63.   while (1)
  64.   {
  65.      if(RxIdx==50)//接收数据满,对数据进行处理
  66.      {
  67.         SPI_Cmd(SPI2, DISABLE);
  68.         RxIdx=0;
  69.         printf("rcv full\n");
  70.         for(i=0;i<49;i++)
  71.            printf("0x%02X\n ",SPI2_Buffer_Rx);//串口输出获取的数据
  72.      }
  73.      if(GetKey()==1)
  74.          {
  75.          LED1_ON;
  76.          SPI_Cmd(SPI2, ENABLE);//按键按下后,使能SPI2,然后在中断中接收数据
  77.          RxIdx=0;//接收数据下标清零
  78.          printf("key1\n");
  79.          }
  80.          if(GetKey()==2)
  81.          {
  82.                  LED1_OFF;
  83.          }
  84.   }
  85. }
有黑币吗
作者: Shaking    时间: 2020-5-7 23:50
请问主机里的NSS要设置成软件管理对吗
