12864液晶滚动显示(已完成)
无底价
2018-6-24 12:44
12864液晶滚动显示(已完成)
12864液晶滚动显示
(47.21 KB, 下载次数: 26)
下载附件
2018-6-30 03:18 上传
#include<reg51.h>
#include<intrins.h>
#include<absacc.h>
#define write_cmd_addr_1 XBYTE[0x8fff] //写指令地址左
#define read_state_addr_1 XBYTE[0xafff] //读状态地址左
#define write_data_addr_1 XBYTE[0x9fff] //写数据地址左
#define read_data_addr_1 XBYTE[0xbfff] //读数据地址左
#define write_cmd_addr_2 XBYTE[0x4fff] //写指令地址右
#define read_state_addr_2 XBYTE[0x6fff] //读状态地址右
#define write_data_addr_2 XBYTE[0x5fff] //写数据地址右
#define read_data_addr_2 XBYTE[0x7fff] //读数据地址右
#define Disp_On 0x3f//开显示
#define Disp_Off 0x3e//关显示
#define Col_Add 0x40//列地址
#define Page_Add 0xb8//页地址
#define Start_line 0xc0//起始页
字模,此字体下对应的
点阵为:宽x高=16x16
unsigned char code Chinese_character[][32]=
/*-- 文字: 江 --*/
0x10,0x60,0x02,0x0C,0xC0,0x04,0x04,0x04,0x04,0xFC,0x04,0x04,0x04,0x04,0x00,0x00,
0x04,0x04,0x7C,0x03,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x00,//"江",0
/*-- 文字: 西 --*/
0x02,0xF2,0x12,0x12,0x12,0xFE,0x12,0x12,0x12,0xFE,0x12,0x12,0x12,0xF2,0x02,0x00,
0x00,0x7F,0x28,0x24,0x22,0x21,0x20,0x20,0x20,0x21,0x22,0x22,0x22,0x7F,0x00,0x00//"西",1
/*-- 文字: 现 --*/
0x04,0x84,0x84,0xFC,0x84,0x84,0x00,0xFE,0x02,0x02,0xF2,0x02,0x02,0xFE,0x00,0x00,
0x20,0x60,0x20,0x1F,0x10,0x90,0x40,0x23,0x18,0x06,0x01,0x7E,0x80,0x83,0xE0,0x00,//"现",2
/*-- 文字: 代 --*/
0x00,0x80,0x60,0xF8,0x07,0x20,0x20,0x20,0x7F,0xA0,0x10,0x11,0x16,0x10,0x10,0x00,
0x01,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x03,0x0C,0x10,0x20,0x40,0xF8,0x00,//"代",3
/*-- 文字: 学 --*/
0x40,0x30,0x10,0x12,0x5C,0x54,0x50,0x51,0x5E,0xD4,0x50,0x18,0x57,0x32,0x10,0x00,
0x00,0x02,0x02,0x02,0x02,0x02,0x42,0x82,0x7F,0x02,0x02,0x02,0x02,0x02,0x02,0x00//"学",4
/*-- 文字: 院 --*/
0xFE,0x02,0x32,0x4A,0x86,0x0C,0x24,0x24,0x25,0x26,0x24,0x24,0x24,0x0C,0x04,0x00,
0xFF,0x00,0x02,0x04,0x83,0x41,0x31,0x0F,0x01,0x01,0x7F,0x81,0x81,0x81,0xF1,0x00//"院",5
/*-- 文字: 电 --*/
0x00,0x00,0xF8,0x48,0x48,0x48,0x48,0xFF,0x48,0x48,0x48,0x48,0xF8,0x00,0x00,0x00,
0x00,0x00,0x0F,0x04,0x04,0x04,0x04,0x3F,0x44,0x44,0x44,0x44,0x4F,0x40,0x70,0x00//"电",6
/*-- 文字: 子 --*/
0x80,0x82,0x82,0x82,0x82,0x82,0x82,0xE2,0xA2,0x92,0x8A,0x86,0x82,0x80,0x80,0x00,
0x00,0x00,0x00,0x00,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//"子",7
/*-- 文字: 工 --*/
0x00,0x00,0x02,0x02,0x02,0x02,0x02,0xFE,0x02,0x02,0x02,0x02,0x02,0x02,0x00,0x00,
0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00//"工",8
/*-- 文字: 程 --*/
0x10,0x12,0xD2,0xFE,0x91,0x11,0x80,0xBF,0xA1,0xA1,0xA1,0xA1,0xBF,0x80,0x00,0x00,
0x04,0x03,0x00,0xFF,0x00,0x41,0x44,0x44,0x44,0x7F,0x44,0x44,0x44,0x44,0x40,0x00//"程",9
/*-- 文字: 系 --*/
0x00,0x00,0x02,0x22,0xB2,0xAA,0x66,0x62,0x22,0x11,0x4D,0x81,0x01,0x01,0x00,0x00,
0x00,0x40,0x21,0x13,0x09,0x05,0x41,0x81,0x7F,0x01,0x05,0x09,0x13,0x62,0x00,0x00//"系",10
/*-- 文字: 古 --*/
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x00,
0x00,0x00,0x00,0xFF,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0xFF,0x00,0x00,0x00,0x00//"古",11
/*-- 文字: 美 --*/
0x00,0x04,0x24,0x24,0x25,0x26,0x24,0xFC,0x24,0x26,0x25,0x24,0x24,0x04,0x00,0x00,
0x81,0x89,0x89,0x49,0x49,0x29,0x19,0x0F,0x19,0x29,0x49,0x49,0x89,0x89,0x81,0x00,//"美",12
/*-- 文字: 丽 --*/
0x02,0x02,0xF2,0x12,0x12,0x12,0xF2,0x02,0xF2,0x12,0x12,0x12,0xF2,0x02,0x02,0x00,
0x00,0x00,0xFF,0x01,0x46,0x80,0x7F,0x00,0xFF,0x01,0x46,0x80,0x7F,0x00,0x00,0x00,//"丽",13
/*-- 文字: 行 --*/
0x10,0x08,0x84,0xC6,0x73,0x22,0x40,0x44,0x44,0x44,0xC4,0x44,0x44,0x44,0x40,0x00,
0x02,0x01,0x00,0xFF,0x00,0x00,0x00,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x00//"行",14
/*-- 文字: 胜 --*/
0x00,0x00,0xFE,0x12,0x12,0xFE,0x20,0x1C,0x10,0x10,0xFF,0x10,0x10,0x10,0x00,0x00,
0x40,0x30,0x0F,0x21,0x41,0x3F,0x20,0x21,0x21,0x21,0x3F,0x21,0x21,0x21,0x20,0x00//"胜",15
/*-- 文字: 于 --*/
0x40,0x40,0x42,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0x42,0x42,0x40,0x00,
0x00,0x00,0x00,0x00,0x20,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00//"于",16
/*-- 文字: 言 --*/
0x00,0x04,0x04,0xA4,0xA4,0xA4,0xA5,0xA6,0xA4,0xA4,0xA4,0xA4,0x04,0x04,0x04,0x00,
0x00,0x00,0x00,0xFC,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0xFC,0x00,0x00,0x00,0x00//"言",17
unsigned char tanhao[]=
/*-- 文字: ! --*/
0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x33,0x30,0x00,0x00,0x00//"!",18
unsigned char qingping[]=
/*-- 清屏 --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
/*********函数声明***********/
void busy_check_1(void);
void busy_check_2(void);
void write_cmd_1(unsigned char command);
void write_cmd_2(unsigned char command);
void write_data_1(unsigned char dis_data);
void write_data_2(unsigned char dis_data);
void clear_1(void);
void clear_2(void);
void Chinese_disp_1(unsigned char pag,unsigned char col,unsigned char n);
void Chinese_disp_2(unsigned char pag,unsigned char col,unsigned char n);
void display(void);
void tanhao_disp(unsigned char pag,unsigned char col,unsigned char *chinese2);
void qingping_disp1(unsigned char pag,unsigned char col,unsigned char *chinese2);
void qingping_disp2(unsigned char pag,unsigned char col,unsigned char *chinese2);
检测忙状态左
unsigned char busy;
while(busy&0x80)
busy=read_state_addr_1;
检测忙状态右
unsigned char busy;
while(busy&0x80)
busy=read_state_addr_2;
写命令左
busy_check_1();
write_cmd_addr_1=command;
写命令右
busy_check_2();
write_cmd_addr_2=command;
写数据左
busy_check_1();
write_data_addr_1=dis_data;
写数据右
busy_check_2();
write_data_addr_2=dis_data;
清内存左
void clear_1(void)
unsigned char i;
unsigned char k;
write_cmd_1(Page_Add+0);
write_cmd_1(Col_Add+0);
for(i=0;i<8;i++)
write_cmd_1(Page_Add+i);
for(k=0;k<64;k++)
//write_data_1(0x00);
qingping_disp1(i,k,qingping);
清内存右
void clear_2(void)
unsigned char i;
unsigned char k;
write_cmd_2(Page_Add+0);
write_cmd_2(Col_Add+0);
for(i=0;i<8;i++)
write_cmd_2(Page_Add+i);
for(k=0;k<64;k++)
//write_data_2(0x00);
qingping_disp2(i,k,qingping);
显示汉字16*16左
unsigned char i=0;
unsigned char j=0;
for(i=0;i<2;i++)
write_cmd_1(Page_Add+pag+i);
write_cmd_1(Col_Add+col);
for(j=0;j<16;j++)
write_data_1(Chinese_character[n][16*i+j]);
显示汉字16*16右
unsigned char i=0;
unsigned char j=0;
for(i=0;i<2;i++)
write_cmd_2(Page_Add+pag+i);
write_cmd_2(Col_Add+col);
for(j=0;j<16;j++)
write_data_2(Chinese_character[n][16*i+j]);
显示叹号'!'
unsigned char i=0;
unsigned char j=0;
for(i=0;i<2;i++)
for(j=0;j<8;j++)
write_data_2(chinese2[8*i+j]);
清屏左
unsigned char i=0;
unsigned char j=0;
for(i=0;i<2;i++)
for(j=0;j<8;j++)
write_data_1(chinese2[8*i+j]);
清屏右
unsigned char i=0;
unsigned char j=0;
for(i=0;i<2;i++)
for(j=0;j<8;j++)
延时子程序
void delay(unsigned int k)
unsigned int i;
unsigned int j;
for(i=0;i<k;i++)
for(j=0;j<20;j++);
LCD显示子程序
…………限于本文篇幅 余下代码请从51黑下载附件…………
12864液晶滚动显示.rar
(111.53 KB, 下载次数: 75)
2018-6-24 12:44 上传
点击文件名下载附件
下载积分: 黑币 -5
lsp1998
2019-6-8 19:06
拜托,你这程序也是牛逼。我真心不懂。
那个p接口怎么接?
