标题: 大佬帮忙看看c程序哪里少了点什么 感谢万分 [打印本页]
作者: 扫福11 时间: 2018-6-29 10:10
1.实验目的
掌握SPI总线的ADC0832模数转换的使用方法。
2.实验内容
利用ADC0832采集直流0~5V的电压,并在LCD1602上显示结果。
C语程序
#include <reg52.H>
#include"LCD1602.h"
#include"ADC0832.h"
uchar Voltage = 0;
/*主函数*/
LCD1602_init();
LCD1602_string(1,1," ADC0832 Test");
LCD1602_string(2,1," Voltsge: V");
Voltage = adc0832(1);
Display_2num_dot(2,10,Voltage*50/255);
#include<reg52.h>
#include<intrins.h>
#define unit unsigned int
sbit ADCS =P1^5;
sbit ADDI =P3^2;
sbit ADDO =P1^7;
sbit ADCLK=P1^6;
uchar adc0832(uchar channel)
uchar i=0;
uchar dat=0;
if(channel==0)channel=2;
if(channel==1)channel=3;
ADDI=0;ADCS=1;ADCLK=0;
ADDI=1;ADCS=0;ADCLK=1;
ADCLK=0;ADCLK=1;
ADDI=channel&0x1;
ADCLK=0;ADCLK=1;
ADDI=(channel>>1)&0x1;
ADCLK=0;ADDI=1;
dat=0;
for(i=0;i<8;i++)
dat|=ADDO;
ADCLK=1;
ADCLK=0;
dat<<=1;
if(i==7)dat|=ADDO;
ADCS=1;ADCLK=0;ADDO=1;
return(dat);
#ifndef __ADC0832_H__
#define __ADC0832_H__
unsigned char adc0832(unsigned char channel);
#endif
作者: 菜鸡养成攻略 时间: 2018-6-29 17:40
#include<reg52.h> #include<intrins.h> #define uchar unsigned char #define unit unsigned int sbit ADCS =P1^5; sbit ADDI =P3^2; sbit ADDO =P1^7; sbit ADCLK=P1^6;应该放在主函数前面吧
作者: 扫福11 时间: 2018-6-30 11:57
还有没有什么错呢,大哥。谢谢
Powered by Discuz! X3.1 |
