标题: IIC模块化编程,使用PCF8591输出正弦波 [打印本页]
作者: zjc666321    时间: 2018-7-2 13:51
主程序:#include<IIC.h>
sbit  SCL=P2^0;
sbit  SDA=P2^1;
uchar code Tosin[255]={        //定义code数组,放在rom中。
0x80,0x83,0x86,0x89,0x8D,0x90,0x93,0x96,
0x99,0x9C,0x9F,0xA2,0xA5,0xA8,0xAB,0xAE,
0xB1,0xB4,0xB7,0xBA,0xBC,0xBF,0xC2,0xC5,
0xC7,0xCA,0xCC,0xCF,0xD1,0xD4,0xD6,0xD8,
0xDA,0xDD,0xDF,0xE1,0xE3,0xE5,0xE7,0xE9,
0xEA,0xEC,0xEE,0xEF,0xF1,0xF2,0xF4,0xF5,
0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,
0xFD,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,
0xFD,0xFC,0xFB,0xFA,0xF9,0xF8,0xF7,0xF6,
0xF5,0xF4,0xF2,0xF1,0xEF,0xEE,0xEC,0xEA,
0xE9,0xE7,0xE5,0xE3,0xE1,0xDE,0xDD,0xDA,
0xD8,0xD6,0xD4,0xD1,0xCF,0xCC,0xCA,0xC7,
0xC5,0xC2,0xBF,0xBC,0xBA,0xB7,0xB4,0xB1,
0xAE,0xAB,0xA8,0xA5,0xA2,0x9F,0x9C,0x99,
0x96,0x93,0x90,0x8D,0x89,0x86,0x83,0x80,
0x80,0x7C,0x79,0x78,0x72,0x6F,0x6C,0x69,
0x66,0x63,0x60,0x5D,0x5A,0x57,0x55,0x51,
0x4E,0x4C,0x48,0x45,0x43,0x40,0x3D,0x3A,
0x38,0x35,0x33,0x30,0x2E,0x2B,0x29,0x27,
0x25,0x22,0x20,0x1E,0x1C,0x1A,0x18,0x16,
0x15,0x13,0x11,0x10,0x0E,0x0D,0x0B,0x0A,
0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,
0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,
0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,
0x0A,0x0B,0x0D,0x0E,0x10,0x11,0x13,0x15,
0x16,0x18,0x1A,0x1C,0x1E,0x20,0x22,0x25,
0x27,0x29,0x2B,0x2E,0x30,0x33,0x35,0x38,
0x3A,0x3D,0x40,0x43,0x45,0x48,0x4C,0x4E,
0x51,0x55,0x57,0x5A,0x5D,0x60,0x63,0x66,
0x69,0x6C,0x6F,0x72,0x76,0x79,0x7C
                  uint i;
                I2C_init();
                 for(i = 255; i > 0; i--)
             I2C_TransmitData(0x40, Tosin[i]);
             //0 0-analogue output enable glag  0 0 analogue  input programming ,0 0-auto analogue increase flag 11-通道选择位
头文件:
#ifndef __IIC_H__
#define __IIC_H__
#include"reg52.h"
#include"intrins.h"
#define uchar unsigned char        //定义无符号字符型变量
#define uint  unsigned int  //定义无符号整型变量
void  I2C_init();         //IIC初始化
void  I2C_Start();  //IIC开始
void  I2C_Stop();         //IIC停止
void  Master_ACK(bit i); //主机发送非应答和应答
bit   Test_ACK();                  //从机应答和非应答检测
void  I2C_send_byte(uchar byte);         //IIC发送一字节数据,8位
uchar I2C_read_byte();                                //IIC读取一字节数据,8位
bit   I2C_TransmitData(uchar ADDR, DATA);   //IIC发送一字节数据,给总线上的从机发送。bit返回值函数用来检测一字节数据是否发送成功给从机。
uchar I2C_ReceiveData(uchar ADDR);          //IIC接收一字节数据,从总线的从机上接收数据。uchar返回值函数用来返回从从机所读取的一字节数据。
void delay_5us();                //5us延时函数
void delayms(uint z);        //ms级延时函数
#endif//定义结束
头文件对应的.c文件:
#include<IIC.h>
#include<reg52.h>
uchar device_ADDR=0x90;        //在这里可以改器件地址
sbit SCL=P2^0;
sbit SDA=P2^1;
/*I2C初始化*/
void I2C_init()
        SDA = 1;
        _nop_();
        SCL = 1;
        _nop_();
/*I2C起始信号*/
void I2C_Start()
        SCL = 1;
        _nop_();
        SDA = 1;
        delay_5us();
        SDA = 0;
        delay_5us();
/*I2C终止信号*/
void I2C_Stop()
        SDA = 0;
        _nop_();
        SCL = 1;
        delay_5us();
        SDA = 1;
        delay_5us();
/*主机发送应答*/
        SCL = 0; // 拉低时钟总线允许SDA数据总线上的数据变化
        _nop_(); // 让总线稳定
        if (i)         //如果i = 1 那么拉低数据总线 表示主机应答
                SDA = 0;
                SDA = 1;         //发送非应答
        _nop_();//让总线稳定
        SCL = 1;//拉高时钟总线 让从机从SDA线上读走 主机的应答信号
        delay_5us();
        SCL = 0;//拉低时钟总线, 占用总线继续通信
        _nop_();
        SDA = 1;//释放SDA数据总线。
        _nop_();
/*检测从机应答*/
bit Test_ACK()
        SCL = 1;
        delay_5us();
        if (SDA)
                SCL = 0;
                _nop_();
                I2C_Stop();
                return(0);
                SCL = 0;
                _nop_();
                return(1);
/*发送一个字节*/
        uchar i;
        for(i = 0 ; i < 8 ; i++)
                SCL = 0;
                _nop_();
                if (byte & 0x80)
                        SDA = 1;
                        _nop_();
                        SDA = 0;
                        _nop_();
                SCL = 1;
                _nop_();
                byte <<= 1;        // 0101 0100B
        SCL = 0;
        _nop_();
        SDA = 1;
        _nop_();
   /*I2C 读一字节*/
        uchar dat,i;
        SCL = 0;
        _nop_();
        SDA = 1;
        _nop_();
                SCL = 1;
                _nop_();
                if (SDA)
                         dat |= 0x01; //
                        dat &=  0xfe;        //1111 1110
                _nop_();
                SCL = 0 ;
                _nop_();
                if(i < 7)
                        dat = dat << 1;
        return(dat);
/*I2C发送数据*/
        I2C_Start();
        I2C_send_byte(device_ADDR+0);  //器件地址+0;写入,1010,0000=0xa0.
        if (!Test_ACK())
                return(0);
        I2C_send_byte(ADDR);    //写入IIC总线上的哪一个存储单元,如果是PCF8591的话,就是控制字
        if (!Test_ACK())
                return(0);
        I2C_send_byte(DATA);
        if (!Test_ACK())
                return(0);
        I2C_Stop();
        return(1);
/*I2C接收数据*/
        uchar DATA;
        I2C_Start();
        if (!Test_ACK())
                return(0);
        I2C_send_byte(ADDR); //从哪个存储单元读取数据,例如AT24C02的话,有256个字节存储单元(256*8=2048位。)ADDR可以是0-255之间的数。
        //如果是PCF8591的话,ADDR就是控制字,控制字假如为0000 0010.则读取通道2上的模拟量转化为的数字量。
        Master_ACK(0);                 //
        I2C_Start();
        I2C_send_byte(device_ADDR+1); //发送一字节从机地址,且方向为1,为写
        if (!Test_ACK())
                return(0);
        DATA = I2C_read_byte();
        Master_ACK(0);
        I2C_Stop();
        return(DATA);
/*5us延时函数*/
void delay_5us()
        _nop_();
/*1Ms延时*/
        uint x,y;
        for(x = z; x > 0; x--)
                for(y = 114; y > 0 ; y--);
这是一个简单一点的程序,以后看情况加其他波形和波形按键选择。PCF8591是8位DA输出。Vref接的+5V。希望在这里得到大家的指正,同时欢迎大家一起交流学习!
proteus仿真图
proteus仿真图
正弦波形图
正弦波形图
作者: zjc666321    时间: 2018-7-2 13:54
那个数码管模块是不需要的。。可以不看
